I'm an retired Navy pilot with lots of time (6000)--but nothing in the past 15 years--but my children are now moving all over the country and I'd like to get back into the air to visit them. I know little about the general aviation market or products but I'm partial to twin engines if only because they gives you an option when the weather deteriorates and so does one engine. I'm looking for the following:
reliable and affordable--under $200K 4-passenger capability (real passengers--none of my kids are under 6') twin preferred--or logic why a single engine is not really an emergency range: 1000 NM speed: 160 KIAS + pressurized cabin (a preference but not a requirement) reasonable IFR package--but state of the art not needed Some idea of annual maintenance costs I need to be planning on What aircraft would you recommend I be looking into? Thanks from general aviation rookie with less than 50 hours of Cesnna 150 time from the 1960s. |
("Tailhook" wrote)
[I didn't know what to snip g] reliable and affordable--under $200K Thanks from general aviation rookie with less than 50 hours of Cesnna 150 time from the 1960s. Here's one for around $400K .....partnership? :-) http://www.diamond-air.at/en/products/DA42/index.htm http://www.diamondair.com/aircraft.php?PHPSESSID=671daa05c9d24f23f9b4e6c87f6 12754 Diamond DA-42 Twin Star Diesel. Amazing plane. Not sure if the diesel version is available, yet, in the US - this summer probably. Don't buy the non-diesel option. Wait for the diesel. 80% Power Range: .....917 NM Time:...........5.3 hrs Speed: ......172 kts Gal/hr: ........12.5 total 60% Power Range: ...1,129 NM Time:.........7.48 hrs Speed: ......151 kts Gal/hr: ........8.8 total Montblack |
Without reading the other responses.. Piper Seneca II Turbo
most can be had with average radios for about $150K What was your Navy Twin time in, and hopefully NOT centerline thrust. BT "Tailhook" wrote in message ... I'm an retired Navy pilot with lots of time (6000)--but nothing in the past 15 years--but my children are now moving all over the country and I'd like to get back into the air to visit them. I know little about the general aviation market or products but I'm partial to twin engines if only because they gives you an option when the weather deteriorates and so does one engine. I'm looking for the following: reliable and affordable--under $200K 4-passenger capability (real passengers--none of my kids are under 6') twin preferred--or logic why a single engine is not really an emergency range: 1000 NM speed: 160 KIAS + pressurized cabin (a preference but not a requirement) reasonable IFR package--but state of the art not needed Some idea of annual maintenance costs I need to be planning on What aircraft would you recommend I be looking into? Thanks from general aviation rookie with less than 50 hours of Cesnna 150 time from the 1960s. -- Tailhook |
BTIZ
The only centerline thrust time I had was back in flight school. After that it was all 2 & 4 engine--Carrier On Board Delivery (COD) C-1 (twin R1820 radials) & C-2 (twin T-56 truboprop) during Vietnam, P-3 oceanographic research and hurricane hunters for 4 more years (4-T56-turbos), and 13 more years of carrier E-2 (more T-56's--4000+ hours in 3 versions of Hawkeyes). Thanks for the tips. At least your pointing me along a valid path for getting back into this. I may end up having to go to some kind of partnership but I'm just getting serious on the search. I do appreciate the help. Tailhook |
Well it won't go quite that fast, and it's not pressurized, it's a
single, but it will carry 4 and it will go anywhere reliably, a Cessna 182 (or 182RG if you want the extra speed). Standard issue all american airplane. Hard to beat. $100-$150 per hour. In the Piper line, a Cherokee 235 Pathfinder or Cherokee 236 are the ones. $100-150 per hour. If you REALLY have to have pressurized and that sort of range, you are above your budget because neither a Cessna 210P or a Piper Malibu have that kind of range, though they come close (both are pressurized). $150-200 per hour Something like a Beech Baron 58P will do what you want, but believe me it will COST to buy and COST to run. But it's pressuriized, a twin and plenty fast. With long range tanks it might go 1000 NM, I dunno. If you have the bucks, its the one to have. $200-250 per hour. (The per hour figures are based on 200 hours a year and are rough estimates). |
On Tue, 7 Mar 2006 22:38:10 +0000, Tailhook
wrote: I'm an retired Navy pilot with lots of time (6000)--but nothing in the past 15 years--but my children are now moving all over the country and I'd like to get back into the air to visit them. I know little about the general aviation market or products but I'm partial to twin engines if only because they gives you an option when the weather deteriorates and so does one engine. I'm looking for the following: reliable and affordable--under $200K 4-passenger capability (real passengers--none of my kids are under 6') twin preferred--or logic why a single engine is not really an emergency range: 1000 NM speed: 160 KIAS + pressurized cabin (a preference but not a requirement) reasonable IFR package--but state of the art not needed Some idea of annual maintenance costs I need to be planning on Check out risingup.com. It has a performance database of nearly all production GA planes. You can search for aircraft types based upon performance parameters. Then use aso.com or controller.com to get an idea of the aircraft price range. The 1000nm range is going to eliminate a lot of aircraft. Also, that is a really long time to stay aloft if you are flying at 160kts. As you get into your search, remember that the purchase price only scratches the surface on aircraft expenses. Insurance + hangar fees + maintenance + fuel & oil costs can be quite large, particularly on a larger engined twin. I would budget at least $20k / year to fly a Baron or similar twin (not including acquisition or loan costs). -Nathan |
production GA planes. You can search for aircraft types based upon performance parameters. Then use aso.com or controller.com to get an idea of the aircraft price range. The 1000nm range is going to eliminate a lot of aircraft. Also, that is a really long time to stay aloft if you are flying at 160kts. As you get into your search, remember that the purchase price only scratches the surface on aircraft expenses. Insurance + hangar fees + maintenance + fuel & oil costs can be quite large, particularly on a larger engined twin. I would budget at least $20k / year to fly a Baron or similar twin (not including acquisition or loan costs). -Nathan[/quote] Now this is the kind of information I'm looking for! It took me a few years to find this site but this is really helpful stuff and should help me refine the differences between nice to haves and needs. I'll check out the sites further. Thanks a lot, Nathan. Should help me get through some of the chaff out there--data but not information I can use. Appreciate the help. Tailhook |
Tailhook wrote:
I'm an retired Navy pilot with lots of time (6000)--but nothing in the past 15 years--but my children are now moving all over the country and I'd like to get back into the air to visit them. I know little about the general aviation market or products but I'm partial to twin engines if only because they gives you an option when the weather deteriorates and so does one engine. I'm looking for the following: reliable and affordable--under $200K 4-passenger capability (real passengers--none of my kids are under 6') Not doubting that you need this, but I think many buyers overestimate the need for weight capacity, unless they have some experience in the GA environment and know what their mission profile is. Many people find they make many trips by themselves or with a single passenger. Just think critically about this requirement, is all I'm saying. twin preferred--or logic why a single engine is not really an emergency Look around on avweb.com and aopa.org and other places for statistics on relative accident rates twins vs. singles. You might decide the difference is not worth the huge bump in operating costs. There are times and places, of course, where a twin has an obvious safety advantage. range: 1000 NM I think it will open up the range of options consdirably if you are willing to make two 500 nm hops. speed: 160 KIAS + pressurized cabin (a preference but not a requirement) Given pressurized, I think any pressurized aircraft will meet the speed requirement handily. As soon as you say 'pressurized', you are going way up the scale toward the high-end, at least from my lowly point of view. reasonable IFR package--but state of the art not needed Some idea of annual maintenance costs I need to be planning on $100-$200/hr overall operating costs (incl fuel) for a typical piston single, probably toward the higher end since you have a large weight capacity requirement, which drives you toward larger airplanes and bigger engines. There's a lot of variability in operating costs from individual to individual, and airplane to airplane, and year to year. Hard to predict. You need a flexible budget. Multi-hundred dollar surprises are common, and multi-thousand dollar surprises are not uncommon. The above is for non-pressurized, pressurized is going to bump that even higher. Don't have any experience with twins, but it will be still more, of course. What aircraft would you recommend I be looking into? Thanks from general aviation rookie with less than 50 hours of Cesnna 150 time from the 1960s. Good luck with your search, and keep us in the loop! Dave |
Tailhook wrote:
reliable and affordable--under $200K Anytime you are talking about pressurized aircraft - and multi engine you are talking more than $200K. According to your performce requirements a Kingar 90 would fit the bill but I don't think you can find one for $200k. I wouldn't rule out single engine airplanes, there are many that could meet your mission for a lot less cost than a twin. |
Take a look at the Cessna 340 and the Cessna 400 series, particular
the 414 and 421. These will be above your $200K range, but are fast, pressurized twins. Also, understand the wing spar AD on the 400 series Cessnas before buying one. If you eliminate the pressurization requirement, look at the Cessna 310, Beech Barons (55 and 58 models) and the Piper Aztec. Of the bunch, the Aztec is the slowest, but also the cheapest to buy. You can find a really nice Aztec for well under $200K. Moving a bit more into the rarer category, the Twin Aerocommander and Piper Aerostar are possibilities. I'd also reccommend either getting a copy of the Aviation Consumer's Used Aircraft Buyer's Guide, or subscribing to the montly Aviation Consumer publication which includes access to their web site. Then you can access the used aircraft articles online. http://www.aviationconsumer.com/ Another good publication to get a subscription to is Trade-A-Plane, the bible for the GA aircraft market. Again, subscribing to the print copy gets you online access to their database which is a good place to shop and get a feel for the market. http://www.trade-a-plane.com/index.shtml Good luck. Ronnie "Tailhook" wrote in message ... I'm an retired Navy pilot with lots of time (6000)--but nothing in the past 15 years--but my children are now moving all over the country and I'd like to get back into the air to visit them. I know little about the general aviation market or products but I'm partial to twin engines if only because they gives you an option when the weather deteriorates and so does one engine. I'm looking for the following: reliable and affordable--under $200K 4-passenger capability (real passengers--none of my kids are under 6') twin preferred--or logic why a single engine is not really an emergency range: 1000 NM speed: 160 KIAS + pressurized cabin (a preference but not a requirement) reasonable IFR package--but state of the art not needed Some idea of annual maintenance costs I need to be planning on What aircraft would you recommend I be looking into? Thanks from general aviation rookie with less than 50 hours of Cesnna 150 time from the 1960s. -- Tailhook |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
