Can anyone ID this engine?
Old March 11th 06, 07:57 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default Can anyone ID this engine?
("Flyingmonk" wrote)
From a down aircraft in Cambodia?
http://i2.tinypic.com/r7pq4z.jpg
2 + 2 + 2 cylinder engine?
45 degree + 45 degree + 45 degree?
What is it?
Montblack
Monk posted this engine link over in RAP.
Old March 11th 06, 09:36 PM posted to rec.aviation.homebuilt
Montblack
Don't recognize the engine but looks like 60 degrees + 60 degrees and
120 degrees total.
Any indications this is an aircraft engine?
Big Johnb
On Sat, 11 Mar 2006 13:57:40 -0600, "Montblack"
What is it?
Montblack
Old March 12th 06, 12:03 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
What is it?
Montblack
Looks like an air compressor.
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old March 12th 06, 03:08 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
What is it?
Montblack
My thoughts exactly---one bank looks smaller than the others--but that
might be the viewpoint--Incidentally, there were quite a few "W"
configured engines made just after WW-I ---Jerry
Old March 12th 06, 10:02 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
In article , says...
They look the same to me . . .
Wonder what the crank looks like - 3 main bearings?
GF
Old March 12th 06, 12:01 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
What you have in the picture, seems to be a French Lorraine 12 Ed aircraft
engine, circa year 1922. It is a liquid-cooled W-type engine (yes, 60+60=120
degrees most probably), but instead of 6-cylinder configuration, it's a
12-cylinder layout (believe or not). Capacity 24,4 litres, dry weight 425
kg. Power output 450 hp.
Check out this link. It has a picture of the engine.
http://www.planes-and-tanks.com/EngineShop/lorraine.htm
"Montblack" kirjoitti
What is it?
Montblack
Old March 12th 06, 03:24 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Yes, that's it...
"JP" wrote in message ...
"Montblack" kirjoitti ...
What is it?
Montblack
Old March 12th 06, 05:13 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
("JP" wrote)
60+60=120 degrees most probably), but instead of 6-cylinder configuration,
it's a 12-cylinder layout (believe or not). Capacity 24,4 litres, dry
weight 425 kg. Power output 450 hp.
Thanks for the link!
About the web page:
When you click on "Aircraft Engines" to see more engines - that link doesn't
work.
Simply turn the capital "E", in the web address, into a lower case "e" for
the "Aircraft Engines" link on the Lorraine page to work. (IE 6.0 and
Firefox/Mozilla)
1922 (French) Lorraine aircraft engine in Cambodia
940 lbs
450 hp
12 cylinder
Montblack
Old March 12th 06, 06:12 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Montblack wrote:
("JP" wrote)
aircraft
configuration,
About the web page:
doesn't
work.
Firefox/Mozilla)
940 lbs
450 hp
12 cylinder
Montblack
Thanks Monty. Looks like I'm not the only one who does that.
Got a short giggle at the Allison 1710 - in metric???
Old March 17th 06, 04:35 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Yes I reckon I can , it's a Soc Nationale de Construction de Moteurs
(Lorraine-Dietrich) see the V12 version Page 95 World Encyclopaedia of Aero
Engines by Bill Gunston ISBN 1-85260-163-9
Ian Kentish in Bendigo AU
36:46:13 S ---- 144:15:466
Few things are harder to put up with than the annoyance of a good example.
The secret of life is honesty and fair dealing. If you can fake that ,
you,ve got it made !
And a fine beer can be judged by one sip but it's better to be sure !!!
"Montblack" wrote in message
What is it?
Montblack
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
