No FAF on an ILS approach...?
Old December 22nd 03, 09:37 PM
John Harper
Default No FAF on an ILS approach...?
I flew the San Jose (KSJC) ILS 30L approach on Sunday, and
noticed that there is no charted FAF, i.e. no Maltese Cross. I
use Jepp plates but I just looked at the NOS plate on the AOPA
site and it's the same. There's also no OM - although there is
an MM.
Seems strange - anyone have any idea why? I thought that all
approaches had to have an FAF?
John
Old December 22nd 03, 09:48 PM
Stan Gosnell
"John Harper" wrote in news:1072129171.853216@sj-
nntpcache-3:
an MM.
An ILS has a Final Approach Point, not a FAF. This is the point at which
you intercept the glideslope at the procedure turn altitude. LOMs are
being decommissioned, and outer markers seem to be receiving little
maintenance, since they aren't required. You will see an altitude on the
chart, showing the altitude at which you should intercept the glideslope,
and this is the FAP. Its only practical use is to make sure you're on the
true glideslope.
Regards,
Stan
Old December 22nd 03, 10:46 PM
Gary Drescher
"Stan Gosnell" wrote in message
true glideslope.
According to the AIM's Pilot/Controller Glossary, precision approaches also
have FAFs, but with a lightning-bolt designation rather than a Maltese
Cross.
--Gary
Regards,
Stan
Old December 24th 03, 03:54 AM
Hilton
an MM.
Stan,
You are not quite correct.
Every ILS (in the US) has a FAF at the point where you intersect the
glideslope per the chart or per ATC altitudes. A FAP occurs on
non-precision approach when, for example, the VOR is situated on-field and
no specific point can be identified on the approach using DME etc.
Procedure turn has nothing to do with it. You could do a procedure turn,
step down a few times, then intersect the glideslope at the FAF.
LOMs are
true glideslope.
Correct me if I'm wrong, but you seem to imply that the LOM occurs at the
glideslope intersect point (FAF). Usually, LOMs occurs after starting the
descent on the GS.
Hilton
Old December 22nd 03, 10:40 PM
Gary Drescher
"John Harper" wrote in message
news:1072129171.853216@sj-nntpcache-3...
an MM.
A precision approach FAF is designated by a lightning bolt, not by a Maltese
Cross. (See the AIM Pilot/Controller Glossary).
--Gary
John
Old December 22nd 03, 11:46 PM
Steven P. McNicoll
an MM.
The Maltese cross identifies the final approach fix only on non-precision
approaches. It's commonly seen on ILS approach plates because most of them
also have localizer minimums, but this one does not.
Old December 23rd 03, 01:11 AM
John Clonts
"Steven P. McNicoll" wrote in message
nk.net...
an MM.
them
Well said
Old December 23rd 03, 12:59 AM
John Clonts
an MM.
John
The cross denotes the FAF for a non-precision approach. You will often see
them on ILS profiles only because many ILS approach plates depict localizer
approaches as well. But the SJC ILS 30L plate does not -- see the note
about flying the LOC DME.
Cheers,
John Clonts
Temple, Texas
N7NZ
The perfect approach Capt.Doug Home Built 25 December 3rd 04 03:37 AM
Garmin 530 VOR Approach Using GPS or VLOC Rich Instrument Flight Rules 3 November 28th 03 04:08 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
DME req'd on ILS (not ILS-DME) approach? Don Faulkner Instrument Flight Rules 13 October 7th 03 03:54 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
