Vectored past the localizer
Old December 23rd 03, 05:38 PM
Doug
Default Vectored past the localizer
Several times, while under IFR flight plan and radar services, I have
been vectored to intercept the localizer and the controller was late
in turning me into the localizer. This usually happens when I need
about a 90 degree turn to the localizer. I have decided not to wait
for his vector and just turn. This has always been when the freq is
busy. There is a very small time window to turn (about 15 seconds), so
if the freq is busy, I can't request a turn before I am past, so now,
if this happens, I just turn. I told a CFII this and he said, ok, but
its not really the legal thing to do. I believe it is the safe thing
to do, and therefore legal. Any opinions from the group?
Old December 23rd 03, 05:49 PM
Steven P. McNicoll
"Doug" wrote in message
om...
While it may or may not be safe, there's no question that it's not legal.
Except in an emergency, no person may operate an aircraft contrary to an ATC
instruction in an area in which air traffic control is exercised. The
controller may be bringing you through the localizer for spacing. He's
supposed to tell you if he's doing that, but the freq's just as busy for him
as it is for you. You may need to prompt him about joining the localizer,
but, of course, the freq's just as busy for you as it is for him.
John Bell
Bad idea. Probably 90% of the time it is O.K., but the other 10% is reason
not to.
I have had many times when controllers have purposefully vectored me through
the localizer and then back on from the other side due to spacing on
traffic. You mentioned that this was happening when the freq was busy.
This is probably also the time when spacing on other traffic could be a
factor.
John Bell
www.cockpitgps.com
om...
Old December 24th 03, 12:20 AM
Mike Beede
not to.
However, I read somewhere that the controller must specifically mention
if they intend to vector you across the localizer. I conclude this is either
incorrect or widely ignored, because the times I've been vectored through
the localizer, no one said anything. I haven't noticed a lot of radio traffic,
either, but they might be talking on another frequency....
Can one of our ATC folks comment on my ill-remembered "fact?"
Mike Beede
Old December 24th 03, 12:33 AM
Roy Smith
not to.
traffic,
Mike Beede
The controller is indeed supposed to tell you if he's planning to vector
you through the localizer. As you've noticed, it's often not done.
This relatively minor transgression on the controller's part, however,
does not justify your deciding to turn to intercept the localizer
without a clearance.
Old December 24th 03, 12:36 AM
Steven P. McNicoll
"Mike Beede" wrote in message
either
traffic,
FAA Order 7110.65N Air Traffic Control
Chapter 5. Radar
Section 9. Radar Arrivals
5-9-3. VECTORS ACROSS FINAL APPROACH COURSE
Inform the aircraft whenever a vector will take it across the final approach
course and state the reason for such action.
NOTE-
In the event you are unable to so inform the aircraft, the pilot is not
expected to turn inbound on the final approach course unless approach
clearance has been issued.
PHRASEOLOGY-
EXPECT VECTORS ACROSS FINAL FOR (purpose).
EXAMPLE-
"EXPECT VECTORS ACROSS FINAL FOR SPACING."
REFERENCE-
FAAO 7110.65, Final Approach Course Interception, Para 5-9-2.
Old December 24th 03, 03:32 AM
Newps
Controllers are required to tell you when you are going to be vectored
across the localizer. If they don't you are required to ask.
Old December 24th 03, 12:37 PM
Ron Rosenfeld
Well, if the pilot thought the clearance was in error, he should ask. But
other than that, where does it say that the pilot is *required* to ask the
controller if he finds he is being vectored across the FAC without being
specifically told that by ATC?
Old December 24th 03, 12:41 PM
Ron Rosenfeld
Never mind, I just found 5-4-3b1b.
Old December 24th 03, 09:19 PM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
AIM 5-4-3.b.1.(b) states; "If approach course crossing is imminent and the
pilot has not been informed that the aircraft will be vectored across the
final approach course, the pilot should query the controller." It does not
say "the pilot is required to query the controller" or "the pilot must query
the controller". Even if it did, the AIM itself says it's nonregulatory.
Aeronautical Engineering Help needed Marc A. Lefebvre US-775 Home Built 94 January 11th 04 12:33 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Established on the approach - Checkride question endre Instrument Flight Rules 59 October 6th 03 04:36 PM
Localizer Back Course vs. ILS ilsub Instrument Flight Rules 8 August 25th 03 04:04 PM
