Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Need help with Narco LORAN LRN 840
Old March 17th 06, 09:13 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Default Need help with Narco LORAN LRN 840
I got an old NARCO LRN-840 LORAN-C that I want to reanimate. Sadly I
only got the unit itself, no manuals or cables. What I need is a pinout
of the rear card-edge connector and informations about what voltage it
requires etc. If someone has a manual as pdf or any other electronic
format it would be great if he'd mail that to me.
Benjamin
Old March 17th 06, 11:14 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Google returned these...
Classified Ads ... standard six pack inst; KMA ZOTSO sound
panel; Narco LRN 840 Loran C; King KY 197 TSO Com; ... Loran
C - NARCO CP136. NARCO M12D Navcom, King ADF KR86. ...
www.navionsociety.org/
Classified_Ads/classified_ads.html - 26k - Cached - Similar
pages
Narco LRN Series Narco LRN-840 Loran-C Nav. System
Installation/Operation Manual 1986 · Narco LRN-840 Loran-C
Nav. System Installation/Operation Manual 1986 ...
http://www.esscoaircraft.com/Narco_L...ies_s/2081.htm -
47k - Cached - Similar pages
Essco Aircraft Manuals and Pilot Supplies. We are the
Aircraft ... 30374, Narco LRN-840 Loran-C Nav. System
Installation/Operation Manual 1986. 2092, Narco Mark 12
Squelch Modification Maintenance Manual ...
www.esscoaircraft.com/pindex.asp?offset=8000 -
102k - Cached - Similar pages
Central Air Parts Inc., Aircraft GPS & Loran ... KING,
LORAN, 8002, $50.00. MICRO LOGIC, LORAN, ML-6500, $75.00.
NARCO, LORAN, LRN-840, $150.00. ROSS, LORAN, LCA-200,
$75.00. STS, LORAN, C-110, $50.00. TEXAS ...
www.cent-air.com/gps.htm - 18k - Supplemental Result -
EASTERN AVIONICS INTERNATIONAL, INC. 8000 Skylane Way USA
(941)637 ... ... LRN-840 U LORAN C, 200 WP, RTE, $789 -
$1105 1 CDI, NAV, POS, GRI, DB! ... W/ANT/VFR ONI ONI-7000 U
OFFSHORE NAV ULTIMATE $14559 - $20383 1 LORAN C, ...
www.avionix.com/inventory.txt - 469k - Cached -
Similar pages
Buy Narco ... glideslope, C $1,227.88. C $1,968.31. -. USA.
Listing has pictures. NARCO- LRN-840 LORAN C NAVIGATION
RECEIVER, C $15.43. 2. USA. Listing ...
narco.bid-on-auctions.ca/ - 101k - Supplemental
Result - Cached - Similar pages
Also check with EAA and your local avionics shop.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Benjamin Gawert" wrote in message
reanimate. Sadly I
need is a pinout
what voltage it
electronic
| Benjamin
Old March 18th 06, 06:54 AM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
[snipped Google results]
Thanks, but that doesn't help me much. I already did a search with
Google but sales ads for aircrafts that have such a LORAN device aren't
really helpful. And buying a manual for a price that is more than this
unit is worth is also not an option.
So if someone out there does have a Narco LRN-840 and a manual please
check out the connector pinout and post it here.
Benjamin
Old March 18th 06, 07:01 AM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Did you contact the EAA, they have a big library.
search with
device aren't
more than this
manual please
| Benjamin
Old March 18th 06, 02:07 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Nope, because in former such cases I only got an advise to ask the
manufacturer.
Benjamin
Old March 18th 06, 04:37 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Former cases from the EAA? Are you a member? If not join?
It is not restricted to USA only.
ask the
| manufacturer.
| Benjamin
Old March 18th 06, 02:42 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Benjamin
Actually, if you READ those google ads, you may notice that SOME are for
sales relating to the literature that you are looking for, not just
aircraft with them installed.
Eastern Avionics, in particular, will likely have what you are looking
for and email you a pinout for less than $20 total. Just in case nobody
happens to have a free copy laying around.
Also check out Ebay, GEBE's Estate Sale.. they have LOTS of old avionics
documentation and I have purchased several items from them in the past.
Again, the price may be quite reasonable (but not free...)
Dave
Old March 19th 06, 08:47 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
aren't really helpful. And buying a manual for a price that is more
than this unit is worth is also not an option.
Benjamin
Well, if YOU had READ my posting you probably would have noticed that I
know that some are selling manuals...
Well, the unit is old and I even don't know if it's working, so 20$ +
shipping + tax (if you look at my email address you might notice that
I'm not in the US) is simply too much just to get the pinout of a few pins.
Benjamin
Old March 21st 06, 02:14 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
What an attitude from someone asking for help, sheesh.
Benjamin
shipping + tax (if you look at my email address you might notice that I'm
Benjamin
Old March 19th 06, 09:27 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
I have an LRN-820, and the pinout may be the same. Looking at the back,
top row of pins (L to R) are 1-12; bottom are A-N. GND is H & J (there
is no I pin). +14/28v is pin 7. Use a multimeter to verify. GND will
be a dead short to the case. Measure +V in to GND: with multimeter set
on high resistance, turning switch on should cause the meter to show an
increasing resistance reading until an electrolytic capacitor fully
charges. Feed in +V thru a 2-3 amp fuse for insurance. Current draw on
the 820 is .5A at 14V; .25A at 28V.
It probably also requires an amplified antenna. Did you get a little
amplifier box which is inserted (near antenna end) in the coax to the
antenna?
Fred F.
Need help with Narco LORAN LRN 840 Benjamin Gawert Owning 18 March 28th 06 11:15 PM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer General Aviation 0 January 23rd 04 02:45 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Aviation Marketplace 0 January 23rd 04 02:44 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Home Built 0 January 23rd 04 02:43 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Products 0 January 23rd 04 02:43 AM
