I've pretty much made up my mind to use a PDA w/Flash GPS. Prices for
these things range from $65-150. Can anyone relate good or bad experience with any particular brand/model? Thanks. Mike |
Mike wrote:
I've pretty much made up my mind to use a PDA w/Flash GPS. Prices for these things range from $65-150. Can anyone relate good or bad experience with any particular brand/model? Thanks. I've been using the Transplant CF GPS that Paul sells. http://www.soarmn.com/cumulus/transplant.htm It works just find on my hx4705 iPAQ w/SeeYou Mobile. Jeremy |
I use the same hardware combination that Jeremy uses, but for vehicle
navigation with TomTom Navigator 5. The only problem I've had is that the Transplant CF GPS receiver has never worked by itself; I only get satellite fixes when I have the optional remote antenna attached. Be aware also that the GPS card (at least the Transplant model) extends the height of the PDA by 2 - 2.5". ~ted/2NO |
I use the Transplant with a 5450. I've only used it a half dozen or so
times but it seems to work fine so far. I have had problems starting Mobile CU unless I first run the CruxView software (it comes with Transplant) and get a good gps fix. That could be a problem with the gps, the ipaq, mcu, or maybe even the operator. At any rate, I'm pleased with it and have a very portable, easy to use system. (and the mcu log files are readily accepted on OLC) Doug |
I don't have an opinion about the card beyond that I have seen them and
they work. However this combination will not work for badge or contest work. You have to have an FAI approved logger. |
ContestID67 wrote:
I don't have an opinion about the card beyond that I have seen them and they work. However this combination will not work for badge or contest work. You have to have an FAI approved logger. Assuming we're talking about contests in the US, flight data recorded by a PDA is not legal for contests, but you don't necessarily need an FAI approved flight recorder. Flight data from handheld GPS units, and other forms of off-the-shelf GPS recording devices, can be used at any SSA sanctioned contests. Examples are the SN10, newer Garmin or Magellan handhelds with (GPS) altitude recording, and Bluetooth GPS receivers with logging capability (which is a nice combo with a Bluetooth equipped PDA). To collect US Team points, however, one needs an FAI approved flight recorder... Marc |
I've used a Haicom 303MMF in an iPAQ 3859 with good luck for the last year
and 1/2. It has worked well with GPS-Log, SeeYou Mobile, and iNAV iGuidance for vehicle navigation, i.e., retrieves. This particular CF GPS had a few nice features - internal battery to remember last location, firewire connection to be used with laptop, remote antenna capable, CF card folds under received making it sturdier when stored. John Scott "Mike" wrote in message oups.com... I've pretty much made up my mind to use a PDA w/Flash GPS. Prices for these things range from $65-150. Can anyone relate good or bad experience with any particular brand/model? Thanks. Mike |
| Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 10:08 PM |
| Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 05:15 AM |
| OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 11:43 PM |
| Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 06:39 AM |
| Rallye/Koliber AD's and opinions | R. Wubben | Piloting | 2 | October 16th 03 06:39 AM |
