Jack Allison wrote:
Oops...meant to post in r.a.o...bah, stupid fingers! Piper has a new service bulletin, SB1161 that calls for inspection of the rib just inboard of the landing gear and aft of the main spar. http://www.newpiper.com/company/Publ...20Insp-Mod.pdf The SB requires putting the plane on jacks and removing the gear side brace and bracket. As 04T is in for the annual, we figured it was a good time to have the SB performed. It turns out we have cracks on both sides of the rib and they're bad enough that the repair kit announced in the SB can't be used. Solution: two new ribs. Cost for parts: 1.1 AMU. Labor is unknown at the moment but the shop is putting together an estimate. At least I can split the repair bill three ways...but it's still gonna put a dent in the flying funds. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
the rib just inboard of the landing gear and aft of the main spar. As 04T is in for the annual, we figured it was a good time to have the SB performed. It turns out we have cracks on both sides of the rib and they're bad enough that the repair kit announced in the SB can't be used. Solution: two new ribs. Cost for parts: 1.1 AMU. Labor is unknown at the moment but the shop is putting together an estimate. Augh! That really, really sucks, Jack. Two good things: 1. It sounds like the kind of thing that only gets worse over time. You are wise to get it over and done with now. 2. You caught it far enough before OSH as to not interfere with your trip. (Well, unless your shop REALLY sucks.) THAT could have ruined your whole summer. I'll bet this problem is going to rival the Lycoming crankshaft AD by the time all is said and done. There are a LOT of Piper retracts out there. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Augh! That really, really sucks, Jack. Yes, suckage level is extremely high. Right at the one year ownership point too. Oh well, I'll have some great show and tell pictures for Oshkosh. What an excuse to have folks crawl around in the grass under my plane :-) Two good things: 1. It sounds like the kind of thing that only gets worse over time. You are wise to get it over and done with now. Yep, and if it becomes an AD, I'd expect we will have permanently complied by replacing the ribs. 2. You caught it far enough before OSH as to not interfere with your trip. (Well, unless your shop REALLY sucks.) THAT could have ruined your whole summer. Also very true. I'll bet this problem is going to rival the Lycoming crankshaft AD by the time all is said and done. There are a LOT of Piper retracts out there. It's going to be interesting to see how many folks opt for performing the SB and how many find cracks. I only know of one other aircraft that found cracks (Dick Russ's Lance)...but it's still very early with this one. I'm also very interested to see if this does become an AD. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
("Jack Allison" wrote)
Yes, suckage level is extremely high. Right at the one year ownership point too. Oh well, I'll have some great show and tell pictures for Oshkosh. What an excuse to have folks crawl around in the grass under my plane :-) "...suckage level is extremely high." Agreed! :-( I'll have to gauge your temperature in a few months before we decide to offer ribs at the Rec.Aviation N40 cookout this year. Good luck harboring your AMU's. Montblack |
Montblack wrote:
I'll have to gauge your temperature in a few months before we decide to offer ribs at the Rec.Aviation N40 cookout this year. So long as you don't charge $.55 AMUs plus $.05 AMU crating fee per rib, cook up all the ribs you want (or have Joe cook 'em up! Good luck harboring your AMU's. I think I'll have to rob the flying fund for the next few months. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Bummer on the rib.
Glad you did the inspection though. After the repair is done you'll sleep better. Jim "Jack Allison" wrote in message . .. Jack Allison wrote: Oops...meant to post in r.a.o...bah, stupid fingers! Piper has a new service bulletin, SB1161 that calls for inspection of the rib just inboard of the landing gear and aft of the main spar. http://www.newpiper.com/company/Publ...20Insp-Mod.pdf The SB requires putting the plane on jacks and removing the gear side brace and bracket. As 04T is in for the annual, we figured it was a good time to have the SB performed. It turns out we have cracks on both sides of the rib and they're bad enough that the repair kit announced in the SB can't be used. Solution: two new ribs. Cost for parts: 1.1 AMU. Labor is unknown at the moment but the shop is putting together an estimate. At least I can split the repair bill three ways...but it's still gonna put a dent in the flying funds. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
On Wed, 29 Mar 2006 20:06:32 -0800, Jack Allison
wrote: Jack Allison wrote: Oops...meant to post in r.a.o...bah, stupid fingers! Piper has a new service bulletin, SB1161 that calls for inspection of the rib just inboard of the landing gear and aft of the main spar. That really should be for the pilots who do full stall landings from 10 feet up. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com http://www.newpiper.com/company/Publ...20Insp-Mod.pdf The SB requires putting the plane on jacks and removing the gear side brace and bracket. As 04T is in for the annual, we figured it was a good time to have the SB performed. It turns out we have cracks on both sides of the rib and they're bad enough that the repair kit announced in the SB can't be used. Solution: two new ribs. Cost for parts: 1.1 AMU. Labor is unknown at the moment but the shop is putting together an estimate. At least I can split the repair bill three ways...but it's still gonna put a dent in the flying funds. |
| Cracked ribs | Jack Allison | Piloting | 17 | April 1st 06 10:14 AM |
| Cracked cylinder: Typical cause? | Peter R. | Owning | 19 | October 9th 04 05:24 AM |
| Testing Stick Ribs | Bob Hoover | Home Built | 3 | October 3rd 04 03:30 AM |
| Heat treating wing ribs | Holger Stephan | Home Built | 13 | February 4th 04 12:59 AM |
| Is a cracked vent SCAT tube an urgent problem? | Ben Jackson | Owning | 18 | September 20th 03 04:31 AM |
