I need direction to a map written for the Control Manager which
includes the yoke pedals and throttle quadrant - ideally the map should include set ups for 1,2,3,or 4 engine jets, turbos and piston. I can't believe that CH products doesn't have a programmer employed that could supply their products with user friendly software that works. |
Did you try the CH Map program that came with the unit? It is a very nice
program and works well. The CHMap allows you to do do basic or more advanced control schemes.. Or you can just go into the FS controls setup and assign the axis there. James Jahns wrote: I need direction to a map written for the Control Manager which includes the yoke pedals and throttle quadrant - ideally the map should include set ups for 1,2,3,or 4 engine jets, turbos and piston. I can't believe that CH products doesn't have a programmer employed that could supply their products with user friendly software that works. -- Brett I. Holcomb Remove R777 to email |
Just went into FS4 and did the assignments there. Then I tried FSUIPC
do get the thrust reverse to work, failed. |
Thanks for the direction. The attempts that I have made using the
Control manager and writting maps and using FS9 assignments with FSUIPC settings failed miserably - I am able to get most of the functions working but fine tuning and reverse thrust are still a problem. I am bombarding CH with my needs with no response. If anyone has written a successful map ? I am about to purchase the Goflight Captains console and hopefully the systems function well allieveating my needs for CH prods to work. James Jahns wrote: I need direction to a map written for the Control Manager which includes the yoke pedals and throttle quadrant - ideally the map should include set ups for 1,2,3,or 4 engine jets, turbos and piston. I can't believe that CH products doesn't have a programmer employed that could supply their products with user friendly software that works. |
Check out the CH forums on the web site and see if you get help there. Also
check out www.stickworks.com. The CH software will do what you want and do it very well. However, in some cases - such as reverse thrust - it takes a lot of work to get it working. I had trouble with that when I first tried it. James Jahns wrote: Thanks for the direction. The attempts that I have made using the Control manager and writting maps and using FS9 assignments with FSUIPC settings failed miserably - I am able to get most of the functions working but fine tuning and reverse thrust are still a problem. I am bombarding CH with my needs with no response. If anyone has written a successful map ? I am about to purchase the Goflight Captains console and hopefully the systems function well allieveating my needs for CH prods to work. James Jahns wrote: I need direction to a map written for the Control Manager which includes the yoke pedals and throttle quadrant - ideally the map should include set ups for 1,2,3,or 4 engine jets, turbos and piston. I can't believe that CH products doesn't have a programmer employed that could supply their products with user friendly software that works. -- Brett I. Holcomb Remove R777 to email |
Saitek X-45 and CH Yoke and Rudder pedals | wan2fly99 | Simulators | 0 | March 11th 06 01:05 PM |
What to do with my Elite pedals? | Aake | Simulators | 5 | November 28th 03 08:28 PM |
What to do with my Elite pedals? | news.ericsson.se | Simulators | 4 | November 25th 03 07:22 PM |
What to do with my Elite pedals? | Simulators | 0 | November 24th 03 12:40 PM | |
CFS-1 and CH Yoke / Pedals | Andy & Lucinda | Simulators | 3 | September 4th 03 01:14 PM |
