Thanks BTIZ. "new pistons and rings" Do you know if the piston change
increased the compression ratio or changed the displacement? or was the change simply necessary to handle the increased RPMs? I believe that Lycon has been working on a STC for several years that would increase the compression ration of the 540 to 10:1, similar to what as it has been supplying to some of the airshow pilots. Not sure how far along they are with the process. Jim BTIZ wrote: Jim, two STCs for the Piper Pawnee First, STC SA1433GL allows upgrade of a Lycoming O-540-B2B5 or B2C5 at 235HP to a O-540-B2B5-CA1D5 or O-540-B2C5-CA1D5 engine at 250HP at 2575RPM. Second STC SA1436GL allows installation of the modified engine into the PA-25-235 airframe. Both are owned by Howard Kron of Howards Aircraft Service in Clara City MN. Both can be found on the FAA web pages if you look up the STC number. The fee to Howard for the STC is cheap, around $200 and the only parts were a different piston and rings into the standard engine. We did this upgrade during an engine overhaul. BT "Jim Burns" wrote in message ... "BTIZ" wrote in message news:VamWf.498$CL6.78@fed1read11... in the 0-540 with a 250HP STC. BT... can you tell us what the 250HP STC entails for the 0-540, the STC holder and which airframes/engine models it is available for? Thanks, Jim |
I did not get to heavily into the details with our Mech and the Engine
Overhaul shop. But I do remember them stating that the different piston had a slightly higher dome creating a higher compression. One thing we did find after we were flying again, we also installed the lightweight Sky Tec Starter and the lighter propeller approved by the original PA-25 Type Certificate. While static run up was within limits according to the STC and TCDS, when taking off with no glider in tow and not maintaining minimum climb airspeed you could go over redline on the tach, any climb speed higher than 70knts requires close attention to the tach redline limits. We are flying approximately 1200# below Max GW with full fuel on board. Don't even feel a 1-26 on tow and the vario is useless to the glider pilot in a 1-26 because it is always going to read over 10knts up. BT "Jim Burns" wrote in message ... Thanks BTIZ. "new pistons and rings" Do you know if the piston change increased the compression ratio or changed the displacement? or was the change simply necessary to handle the increased RPMs? I believe that Lycon has been working on a STC for several years that would increase the compression ration of the 540 to 10:1, similar to what as it has been supplying to some of the airshow pilots. Not sure how far along they are with the process. Jim BTIZ wrote: Jim, two STCs for the Piper Pawnee First, STC SA1433GL allows upgrade of a Lycoming O-540-B2B5 or B2C5 at 235HP to a O-540-B2B5-CA1D5 or O-540-B2C5-CA1D5 engine at 250HP at 2575RPM. Second STC SA1436GL allows installation of the modified engine into the PA-25-235 airframe. Both are owned by Howard Kron of Howards Aircraft Service in Clara City MN. Both can be found on the FAA web pages if you look up the STC number. The fee to Howard for the STC is cheap, around $200 and the only parts were a different piston and rings into the standard engine. We did this upgrade during an engine overhaul. BT "Jim Burns" wrote in message ... "BTIZ" wrote in message news:VamWf.498$CL6.78@fed1read11... in the 0-540 with a 250HP STC. BT... can you tell us what the 250HP STC entails for the 0-540, the STC holder and which airframes/engine models it is available for? Thanks, Jim |
Chevy LS2 and Trans??? any real issues besides weight | MrV | Home Built | 82 | November 18th 05 03:11 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
