Approach Timer Frustration
Old January 15th 04, 06:44 PM
Andrew Sarangan
Default Approach Timer Frustration
Over the years I have been using various digital timers, but so far I
have not been satisfied with any of them. The LCD displays make them
difficult to read when viewing at different angles. The right seat
pilot (or CFII) cannot see the digits. Lack of illumination in most
units is another big problem for night use. Size is another issue.
Most of the timers appear to be way too bulky for their function. For
example, the ASA timer is larger than any instrument in the cockpit.
If you install it on your yoke clip, it would cover up half of the
approach chart. For some reason, the manufacturers seem to be obsessed
with presenting large digit displays. That may be good for home or
outdoor use, but there is really no need for the digits to be 10
times larger than the font size on the approach charts.
For a long time I have been looking for a very small timer (1" x 1")
with an LED display (not LCD) that could be glued to the yoke clip.
With LED displays, battery life could be a problem, but one could
easily solve that by having an on/off switch (most timers seem to run
continuously regardless of use). Any ideas where I may find such a
device?
Old January 15th 04, 07:48 PM
EDR
In article , Andrew
Wait until you get older, then tell me you don't need big numbers.
Old January 15th 04, 08:13 PM
Ron Natalie
"Jim" wrote in message ...
It seems to me that West Bend Co. makes most of the timers I've seen. Maybe
they have something smaller.
Of course, they also make some of the most inaccurate timers as well. Some
here have noticed that they can run almost 100% off when the batteries start
to go.
Old January 15th 04, 08:42 PM
Jim Weir
I used a West Bend kitchen timer for the tank timer on Voyager. I bought Dick's
unit and my unit at the same time in 1984. Mine has never been turned off and
is still on the panel of the 182, ticking away.
"Jim"
-It seems to me that West Bend Co. makes most of the timers I've seen. Maybe
-they have something smaller.
http://www.rst-engr.com
Old January 15th 04, 09:09 PM
S Narayan
Got the Radio Shack count up/down timer which can be set easily. It is big
though (2" or so on a side). I connected an external AAA battery and put in
a red LED across the speaker. I can now see when the timer expires with the
flashing LED since I doubt I could hear the speaker go off.
Here's the link for the timer.
http://www.radioshack.com/product.as...gory%5Fname=CT
LG%5F010%5F002%5F002%5F000&product%5Fid=63%2D878
Maybe
Jim Burns III
Remove "nospam" to reply
Old January 16th 04, 01:13 AM
Casey Wilson
"S Narayan" wrote in message
in
Can you provide a schematic? Please.
Old January 16th 04, 09:33 PM
S Narayan
"Casey Wilson" wrote in message
big
in
I don't have the timer with me now, but IIRC, I experimented by putting
several types of LEDs across the speaker inside, and it worked. In fact, the
speaker works while the LED flashes. I didn't care if the speaker died, so I
used the largest LED I had. I believe, there is some some kind of a
charge-pump type circuit which steps up the voltage to tens of volts to
drive the piezo type speaker. The somewhat high voltage won't hurt the LED,
since the speaker driver cannot provide much current. The whole timer used
to run off a 1.5V button cell. The standby current drain is around 5uA and
putting an external AAA battery will keep it going as long as the battery
manages to stay alive which may be a several years. The self discharge may
be higher than what the timer needs!
Old January 17th 04, 12:04 AM
Casey Wilson
I
LED,
Okay, now I've got it. I was confused over what you did with the battery.
Now I see all you did was supplement the main unit battery -- it had nothing
directly to do with the LED which simply parallels the pizeo transducer.
Thanks.
Old January 16th 04, 01:20 AM
Hankal
I have a 3 function clock made by Westbend. It is fastened by velcro to the
left hand panel in front of the door. C172.
I time my XC legs and my approaches.
Hank N1441P
How much protection on approach? Michael Instrument Flight Rules 20 January 15th 04 06:58 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 06:20 AM
DME req'd on ILS (not ILS-DME) approach? Don Faulkner Instrument Flight Rules 13 October 7th 03 04:54 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 06:22 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
