differences in loc/dme and loc with dme appch at KRUT?
Old January 24th 04, 12:00 AM
Richard Hertz
Default differences in loc/dme and loc with dme appch at KRUT?
Can anyone point out why the following approaches have minor differences
(specifically the minimums and the MAP):
RUT LOC/DME 19
RUT LOC 19 (with DME)
Old January 24th 04, 12:46 AM
Roy Smith
RUT LOC/DME 19
Beats me. All the minimums for the LOC w/DME are as good or better than
the corresponding values for the LOC/DME. I can't see any reason
anybody would ever want to fly the LOC-DME.
I can only see one possible reason for the LOC-DME to exist, and I'll
admit it's grasping at straws. In the LOC-DME, you start the missed
further out, which may be of some operational advantage to ATC? But
since this is an untowered airport, it's almost certainy "one-in,
one-out", so I can't get too excited about that idea.
Old January 24th 04, 05:12 AM
Steven P. McNicoll
"Roy Smith" wrote in message
Not want to, but may have to if RUT VOR/DME is out of service. The missed
approach procedure for the LOC RWY 19 uses RUT VOR/DME, the procedure for
the LOC/DME RWY 19 does not.
No advantage to ATC in that. If you don't have GPS and the RUT VOR/DME is
out of service, the LOC/DME RWY 19 is your only approach.
Old January 24th 04, 05:26 AM
Roy Smith
In article .net,
"Steven P. McNicoll" wrote:
The missed approach procedure for the LOC RWY 19 uses RUT VOR/DME,
Does it? Yes, it mentions "via RUT VOR/DME" in the missed text, but
there aren't actually any fixes that use DME from RUT. The only DME
callout I see in the missed is GITEW, which is I-RUT 16.4.
I can't see any reason this approach wouldn't be flyable with the RUT
DME out of service, as long as the VOR azimuth was still operating.
Old January 24th 04, 01:09 PM
Steven P. McNicoll
I didn't say the procedure used DME information from RUT VOR/DME. The
navaid is called a VOR/DME. The missed approach procedure includes a climb
to 2600 via direct to the VOR/DME and then the 221 radial from it. You
can't do that if the navaid is out of service.
Old January 24th 04, 01:57 PM
Roy Smith
In article .net,
As long as the VOR portion is working, you can. The status of the DME
portion is immaterial to this approach.
Old January 24th 04, 05:12 PM
The naming convention was changed in TERPs.
Old January 24th 04, 06:07 PM
Steven P. McNicoll
What name are you referring to?
Old January 24th 04, 01:22 AM
Dave S
RUT LOC/DME 19
The DME is required.. and in this approach the DME is co-located with
the localizer for 19.
DME optional, but the DME for use in THIS approach is co-located with
the VOR which is on-field, but sited differently from the Localizer.
I GUESS it gives you the option of using either DME if one happens to be
inop on the ground. the DME mins are in the 800 ft range agl (with
plenty of tall obstructions within 10 miles..) Might make it a little
easier for the commuters to get in there when the weather is bad.. I dunno.
Dave
Old January 24th 04, 03:37 AM
Roy Smith
In article .net,
Dave S wrote:
RUT LOC/DME 19
It looks to me like other than the step-downs at FISER and MAUVE on the
feeder routes, all the DME callouts on both approaches reference I-RUT.
Are you seeing something I'm not?
