Hey Guys-
Has anyone ever attempted to install a Hilsch Tube (Vortex Tube) in an aircraft for environmental controls? The setup I see would be very light, a 3 foot long PVC vortex tube (no more than 5 lbs) with a small exhaust turbocharger force-feeding it. Yes the Hilsch tube is not a particularly efficiant cooling mechanism, but exaust-gas pressure is essentially 'wasted energy' anyways. It strikes me that controlling such a mechanism would be trivial (baffle the hot-cold ends of the tube to a controllable valve, and then into the cabin), lightweight, and relatively inexpensive... IT seems to perfect, why hasn't anyone done it before? (Hilsch tubes are already used as cooling mechanisms elsewhere. quick wiki reference- plenty more can be found online- http://en.wikipedia.org/wiki/Vortex_tube -Scott |
![]() EridanMan wrote: Has anyone ever attempted to install a Hilsch Tube (Vortex Tube) in an aircraft for environmental controls? I built one of them in High school as a science fair project. it worked, but was noisy as hell. Usually, vortex tubes are used for spot cooling, due to their low efficiency. One big enough to cool a typical aircraft cabin would be quite large, and as I said, NOISY! Steve |
whoops continuing:
We're talking about using exhaust pressure energy that would be heading out the tail pipe anyways, right? Eh... its all 'armchair engineering', I know- just fun to think about. I can definitely see how such a system might be useful (internal climate control, wing anti-ice) if the engineering hurdles could be worked out (noise, high enough input flow, weight (possibly)) |
EridanMan wrote:
Hey Guys- Has anyone ever attempted to install a Hilsch Tube (Vortex Tube) in an aircraft for environmental controls? The setup I see would be very light, a 3 foot long PVC vortex tube (no more than 5 lbs) with a small exhaust turbocharger force-feeding it. Yes the Hilsch tube is not a particularly efficiant cooling mechanism, but exaust-gas pressure is essentially 'wasted energy' anyways. But, it's not really. Adding extra back pressure to the engine decreases its efficiency. |
And small, unpressurized airplanes don't need cooling. The air outside
is plenty cold. For heat, there's lots to be had from the exhaust or oil with a simple heat exchanger. In a pressurized airplane, I don't think the vortex tube would work. I don't think you can exhaust the cold side into the cabin and the hot side overboard, so I think you're back to conventional AC. |
Yeah... You have a point about how useful it might be (especially for a
Bay area pilot such as myself)... Although - The tube flow is pressurized, so there's no reason that a hirsch tube setup could be used as the preassurization mechanism for an aircraft (assuming the structure can handle it... big assumption)... The only question would be could you maintain a comfortable balance of warm and cold air... I dunno... Probably more effort than its worth, i'll agree, but its still fun to think about. |
The flow tube is pressurized, but I'll bet if the cold side exit is at
a higher pressure than the hot side exit, the pressurized air inside the cabin will just join the pressurized turbocomressed air in exiting to the outside atmosphere. |
The very point of the Turbo is that a well designed turbine (matched to
the expected flow) do not significantly increase backpreassure, but does harvest excess pressure energy. This is the fundamental difference between Turbocharging and Supercharging. |
I bought 2 surplus factory made tubes to experiment with. One thought
was to use some of it's cooling to blow on the radiator and intercooler. They aren't very large and I don't have a pressure graph for them. It is fun to tinker, though. David M. EridanMan wrote: Hey Guys- Has anyone ever attempted to install a Hilsch Tube (Vortex Tube) in an aircraft for environmental controls? The setup I see would be very light, a 3 foot long PVC vortex tube (no more than 5 lbs) with a small exhaust turbocharger force-feeding it. Yes the Hilsch tube is not a particularly efficiant cooling mechanism, but exaust-gas pressure is essentially 'wasted energy' anyways. It strikes me that controlling such a mechanism would be trivial (baffle the hot-cold ends of the tube to a controllable valve, and then into the cabin), lightweight, and relatively inexpensive... IT seems to perfect, why hasn't anyone done it before? (Hilsch tubes are already used as cooling mechanisms elsewhere. quick wiki reference- plenty more can be found online- http://en.wikipedia.org/wiki/Vortex_tube -Scott |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
