Recently, I found a link to a very simple, yet useful flight planning sight.
If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
I don't know if this is the one you are talking about but you might take a
look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
Yes, that is the one. Thank you.
"Harry Gordon" wrote in message ... I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
Harry,
Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
Ross Richardson wrote:
Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. Ross, I saw this somewhere else. Click on the course "line" and then right click on the course line. You can then pick properties and you can input the wind data from the briefing. The drawback is that it uses those winds for the whole flight. Chris |
I know I can do that, but according to AOPA this program should pick up
the winds aloft and calculate your flight plan. The "tech" that I have talked to said it worked fine for him on the same route that I have been experimenting with. Ross Chris Ehlbeck wrote: Ross Richardson wrote: Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. Ross, I saw this somewhere else. Click on the course "line" and then right click on the course line. You can then pick properties and you can input the wind data from the briefing. The drawback is that it uses those winds for the whole flight. Chris |
I know I can do that, but according to AOPA this program should pick up the winds aloft and calculate your flight plan. The "tech" that I have talked to said it worked fine for him on the same route that I have been experimenting with. Ross Chris Ehlbeck wrote: Ross Richardson wrote: Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. Ross, I saw this somewhere else. Click on the course "line" and then right click on the course line. You can then pick properties and you can input the wind data from the briefing. The drawback is that it uses those winds for the whole flight. Chris It seems I've never been able to get it to import the winds automatically either. Which is why most of the time, I'll use Golden Eagle. |
Ross, sorry for the delay in responding.
No, I don't have a problem. However, you have to request the weather information via the flight planner AND you have to have an account set up with DUAT. Immediately upon receiving the weather, the NAV LOG should update automatically. Hope that helps. I will be checking back again and if you have any question please feel free to ask. If necessary, I do whatever research I can to help you, but the AOPA flight planner should do everything you want, with a few exceptions :-). Harry "Ross Richardson" wrote in message ... Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
I have found the magic decoder ring that makes the AOPA RTFP work
correctly. As folks have said, plan the flight, go to the weather tab and get the weather, and the nav log and flight plans should update correctly. Well, they do ONLY if when getting the weather you ask for FAA weather. You cannot ask for only Plain Language. I clicked on FAA weather along with the Plain language and it worked. I closed the application and started all over again with asking for only the Plain Language weather and the navlog and flight plan did NOT update. Double clicking on the weather box again I checked the FAA weather and connected again and the nav log and flight plan worked. YOU MUST REQUEST THE FAA WEATHER. Harry Gordon wrote: Ross, sorry for the delay in responding. No, I don't have a problem. However, you have to request the weather information via the flight planner AND you have to have an account set up with DUAT. Immediately upon receiving the weather, the NAV LOG should update automatically. Hope that helps. I will be checking back again and if you have any question please feel free to ask. If necessary, I do whatever research I can to help you, but the AOPA flight planner should do everything you want, with a few exceptions :-). Harry "Ross Richardson" wrote in message ... Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message . .. Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. -- Regards, Ross C-172F 180 hp KSWI |
Ross, thank you. After reading your note, I remembered someone a long time
ago had mentioned the same thing. I always request the FAA weather so I guess I had forgotten about that little inconsistency. Glad you found the answer. Harry "Ross" wrote in message news:dHY_f.7605$Q92.1640@trnddc04... I have found the magic decoder ring that makes the AOPA RTFP work correctly. As folks have said, plan the flight, go to the weather tab and get the weather, and the nav log and flight plans should update correctly. Well, they do ONLY if when getting the weather you ask for FAA weather. You cannot ask for only Plain Language. I clicked on FAA weather along with the Plain language and it worked. I closed the application and started all over again with asking for only the Plain Language weather and the navlog and flight plan did NOT update. Double clicking on the weather box again I checked the FAA weather and connected again and the nav log and flight plan worked. YOU MUST REQUEST THE FAA WEATHER. Harry Gordon wrote: Ross, sorry for the delay in responding. No, I don't have a problem. However, you have to request the weather information via the flight planner AND you have to have an account set up with DUAT. Immediately upon receiving the weather, the NAV LOG should update automatically. Hope that helps. I will be checking back again and if you have any question please feel free to ask. If necessary, I do whatever research I can to help you, but the AOPA flight planner should do everything you want, with a few exceptions :-). Harry "Ross Richardson" wrote in message ... Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message . .. Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. -- Regards, Ross C-172F 180 hp KSWI |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
AirPlan Flight Planning Software Update | Dean Wilkinson | Products | 0 | October 25th 04 11:22 PM |
