Broken window in jet plane
Old April 10th 06, 11:09 PM posted to rec.aviation.piloting
Default Broken window in jet plane
Hi. I need help with some data. Today, the plane carrying our
country's president had to get back to the aiport because a crack appeared
in a window. This made front page of evening newspapers and stirred up
a heated discussion in local newsgroups.
That said, one of the regulars says a pilot died in a similar
incident in 1998 when a windshield on a 747 fell off and the pilot was
sucked and froze to death. Is it true? I googled a lot and could only find
links to 'Lost' series websites...
Any mythbusters on site?
Eduardo K. | To put a pipe in byte mode,
http://www.carfun.cl | type PIPE_TYPE_BYTE.
http://e.nn.cl | (from the Visual C++ help file.)
Old April 10th 06, 11:23 PM posted to rec.aviation.piloting
no, but there is this story: http://www.gallagher.com/ejection_seat/
"Eduardo K." wrote in message ...
Old April 10th 06, 11:37 PM posted to rec.aviation.piloting
or follow up this
http://www.washtimes.com/business/20...5651-9524r.htm
and this
http://www.airdisaster.com/forums/sh...ad.php?t=72212
".Blueskies." wrote in message
et...
appeared
find
Old April 10th 06, 11:41 PM posted to rec.aviation.piloting
Any "regular" making such a claim should be able to present a record of such
an incident.
I seriously doubt it did happen, but it's a lot harder to prove the absence
of an event. Just because no one here has heard of it, that's not proof it
didn't happen (though it does strongly suggest it didn't ).
If it actually did happen, it should be trivial for someone claiming it did
to show you a news article or aviation agency report describing the event.
I haven't seen the details of the event as originally stated, but your
description doesn't sound plausible to me. There would be significant
airflow through a window, no doubt, but I doubt it would be enough to suck a
person (whatever is meant by that), and freezing to death would require more
than some localized frostbite.
Sounds like your BS detector got set off, and it also sounds like your BS
detector is working properly.
Pete
Old April 11th 06, 03:58 AM posted to rec.aviation.piloting
There was a case where a mechanic matched new screws from looking at the old
screws, instead of going to the repair book and getting the right screws,
while replacing a windshield in an airliner. The screws he used were
slightly undersized, and they were not able to hold, once they got to a high
pressure differential. On the first (or one of the first) flights, the
windshield blew out. Other pilot, and I think stew, held him from blowing
completely out, but he was most of the way out. I don't remember if he died
or not.
Jim in NC
Old April 11th 06, 12:37 PM posted to rec.aviation.piloting
old screws, instead of going to the repair book and getting the right
screws, while replacing a windshield in an airliner. The screws he used
were slightly undersized, and they were not able to hold, once they got
to a high pressure differential. On the first (or one of the first)
flights, the windshield blew out. Other pilot, and I think stew, held
him from blowing completely out, but he was most of the way out. I
don't remember if he died or not.
He survived to fly again, I saw the documentary. The accident was a
British carrier.
AFAIR, the pilot who held his feet retired, never to fly again...
Old April 11th 06, 02:49 PM posted to rec.aviation.piloting
Here's a story of that one.
http://www.theage.com.au/articles/20...html?from=top5
Bob (Chief Pilot, White Knuckle Airways)
"Morgans" wrote in message
were slightly undersized, and they were not able to hold, once they got to
a high pressure differential. On the first (or one of the first) flights,
the windshield blew out. Other pilot, and I think stew, held him from
blowing completely out, but he was most of the way out. I don't remember
if he died or not.
Jim in NC
Old April 12th 06, 11:39 PM posted to rec.aviation.piloting
On Mon, 10 Apr 2006 at 15:41:35 in message
, Peter Duniho
Something similar did happen in the UK to a BAC 1-11 I think it was. I
recall reading details of the incident.
It occurred because of faulty maintenance. The Captain's screen had been
removed and replaced but almost all of the bolts used were wrong and too
short.
In flight, but not too high as I recall the windshield blew out and the
Captain was pulled partly out though it. Other crew on the flight deck
held on to him and the first officer landed successfully.
The Captain I seem to recall was not seriously injured.
That one definitely happened
David CL Francis
Old April 13th 06, 12:45 AM posted to rec.aviation.piloting
"David CL Francis" wrote in message
I didn't say something similar didn't happen. I said the specific incident
described didn't happen.
Recovery parachutes again! Cub Driver Piloting 35 July 8th 05 12:47 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 12:19 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
