Hummel Aviation at Sun and Fun?
Did anyone see them? Specifically, did anyone see the Ultracruiser
Plus there? I have some detail questions I'm dying to ask. |
flybynightkarmarepair wrote:
Did anyone see them? Specifically, did anyone see the Ultracruiser Plus there? I have some detail questions I'm dying to ask. Haven't heard yet. What kind of questions? Inquiring minds, and all that... Richard |
("cavelamb" wrote)
Did anyone see them? Specifically, did anyone see the Ultracruiser Plus there? I have some detail questions I'm dying to ask. Haven't heard yet. What kind of questions? Inquiring minds, and all that... I like the Hummels! Ok, the Hummel UltraCruiser ....PLUS. (Headroom is always "one" of my concerns - in cars, too. 6-2 ...tall torso) For those unfamiliar with Morry and his design: http://www.thayne.us/uc/contact.asp http://www.thayne.us/uc/ http://www.flyhummel.com/ucarticle.htm http://www.hummelbird.com/index.htm http://www.hummelbird.com/morry.htm http://www.flyhummel.com/ultra_cruiser_plus.htm Thought I'd better throw this one in vBg http://www.ultralightnews.com/sunfun...tracruiser.htm http://moonsdesigns.com/ultracruiser/ http://www.hummelengines.com/ http://www.flyhummel.com/catalog/index.html http://www.barnstormers.com/listing.php?mode=usersearch&user=billydee&PHPSESSI D=10f9cfd7361072d8b8 Montblack http://www.greenskyadventures.com/acforsale/forsale.htm 2005 New Hummell Ultracruiser - Never flown. It has a Used globel 4 stroke engine, basic insterments, oil pressure, oil temp, air spd and altimiter. Also has brakes. Would like to swap it for a single place or 2 place highwing of equal value. I am asking $7.000 us dollars or best offer. (207) 498-3297 Allen Northern Maine 02/15/06 |
Is this particular aircraft considered an Ultra Light? If so, I think
I might have just found my Colorado project... Also, what is the max size in the cockpit? They indicate 6 foot and over 200 pounds...I'm curious how the cockpit could be configured. Looking through the websites above...thanks in advance, all! |
DABEAR wrote: Is this particular aircraft considered an Ultra Light? If so, I think I might have just found my Colorado project... It looks like the "UltraCruiser" was made to get by as an ultralight. You MIGHT be able to call it an UL, but you'd have to grit your teeth. It's right on the edge of being too fast and too heavy. It's a 60-80 mph cruise, the UL limit is 55 kts MAX. The lightest version's listed weight is *exactly* the maximum weight for an UL, the stall speed is 25-28 MPH and the spec is 24 kts. The other versions are clearly too heavy and fast. |
Richard Riley wrote: DABEAR wrote: Is this particular aircraft considered an Ultra Light? If so, I think I might have just found my Colorado project... It looks like the "UltraCruiser" was made to get by as an ultralight. You MIGHT be able to call it an UL, but you'd have to grit your teeth. It's right on the edge of being too fast and too heavy. It's a 60-80 mph cruise, the UL limit is 55 kts MAX. The lightest version's listed weight is *exactly* the maximum weight for an UL, the stall speed is 25-28 MPH and the spec is 24 kts. The other versions are clearly too heavy and fast. Too bad you're not in Canada. Even the original Hummel Bird can be registered as an ultralight here. See : http://www.tc.gc.ca/civilaviation/ge...htm#Definition An excerpt: 2.1 Definition A basic ultra-light aeroplane shall be defined as either: a single-seat ultra-light aeroplane pursuant to Subpart 101, Part 1 of the Canadian Aviation Regulations; A two seat instructional ultra-light aeroplanes pursuant to Subpart 101, Part 1 of the Canadian Aviation Regulations; or an aeroplane having no more than two seats, designed and manufactured to have a maximum take-off weight of 544 kilograms and a stall speed in the landing configuration (Vso) of 39 knots (45 mph) or less indicated airspeed at the maximum take-off weight. 544 Kg = 1198 lb. Pretty good, huh? Dan |
DABEAR wrote:
Is this particular aircraft considered an Ultra Light? If so, I think I might have just found my Colorado project... Also, what is the max size in the cockpit? They indicate 6 foot and over 200 pounds...I'm curious how the cockpit could be configured. Looking through the websites above...thanks in advance, all! You'd fit just fine. But no, it's not likely going to qualify as a US UL. Richard |
