I have seen a few gliders that had yaw strings attached with something
other than the white tape most of us use. It was either a clear tape or clear sticker. If any of you use something other than the white tape to attach your yaw string please share what you use. Thanks! |
Bruno wrote: I have seen a few gliders that had yaw strings attached with something other than the white tape most of us use. It was either a clear tape or clear sticker. If any of you use something other than the white tape to attach your yaw string please share what you use. Thanks! Scotch clear packing tape. Cut it into a little triangle (for style points), stick the yarn on (I prefer green - with a knot at both ends), and carefully place dead center on canopy, as far back as you can stand. Doesn't shrink or leave much residue like white tape. And you can kinda see through it... I also it to cover the big horizontal tail attachment opening on my LS6 - one piece fits perfectly. Kirk 66 |
Nyal Williams wrote:
I have seen a glider that had a very small, round hole for the yaw string drilled in the canopy. The owner tied knots inside and out, tighly against the hole. That was probably 35 years ago and I don't remember what or who. I would not recommend it. Kinda suck when, after your buddies ask why you fly slow and sideways, you realize you drilled 1 cm to starboard. Shawn |
I saw one stuck on with a drop of clear RTV (silicone rubber). When I
asked about it, the owner said it stuck up into the airflow a bit better and was a little more responsive. He also commented that he didn't fix his gaze on it nearly so often as the little triangle of white tape that he used in the past. I think I'll try that soon, unless someone tells me that the RTV will damage my plexiglass. Jack Womack PIK-20B N77MA (TE) |
On 12 Apr 2006 13:18:52 -0700, "Jack" wrote:
I saw one stuck on with a drop of clear RTV (silicone rubber). When I asked about it, the owner said it stuck up into the airflow a bit better and was a little more responsive. He also commented that he didn't fix his gaze on it nearly so often as the little triangle of white tape that he used in the past. I think I'll try that soon, unless someone tells me that the RTV will damage my plexiglass. My partners and I used to keep our yaw string suspended about 3/4" above the surface on a piece of wire bent to shape and taped into place. It gave a little better precision by keeping the string out of the canopy's boundary layer, which was prone to a bit of hysteresis. However, we eventually decided it wasn't enough of an improvement to offset the pain in the butt of removing it every time we put the canopy cover on, so we gave it up. Just be sure you use *metric* yaw string on a German ship. rj |
Does anyone know who still supplies these canopy holes?
"Nyal Williams" wrote in message ... I have seen a glider that had a very small, round hole for the yaw string drilled in the canopy. The owner tied knots inside and out, tighly against the hole. That was probably 35 years ago and I don't remember what or who. I would not recommend it. At 18:00 12 April 2006, wrote: Bruno wrote: I have seen a few gliders that had yaw strings attached with something other than the white tape most of us use. It was either a clear tape or clear sticker. If any of you use something other than the white tape to attach your yaw string please share what you use. Thanks! Scotch clear packing tape. Cut it into a little triangle (for style points), stick the yarn on (I prefer green - with a knot at both ends), and carefully place dead center on canopy, as far back as you can stand. Doesn't shrink or leave much residue like white tape. And you can kinda see through it... I also it to cover the big horizontal tail attachment opening on my LS6 - one piece fits perfectly. Kirk 66 |
Are you looking for the EASA approved ones or the traditional ones ?
"Phil Jeffery" wrote in message ... Does anyone know who still supplies these canopy holes? "Nyal Williams" wrote in message ... I have seen a glider that had a very small, round hole for the yaw string drilled in the canopy. The owner tied knots inside and out, tighly against the hole. That was probably 35 years ago and I don't remember what or who. I would not recommend it. |
Milspec holes are the best, but expensive.
Hard to find now, due to extensive use in Iraq and Afghanistan - especially the 5.56 and 7.62 mm sizes. Kirk |
| 60 Year Old Duct Tape | Jay Honeck | Piloting | 11 | January 15th 06 07:52 PM |
| Gap Tape | TJ | Soaring | 0 | October 22nd 05 05:18 AM |
| Teflon gap seal tape... | Marc Ramsey | Soaring | 10 | April 3rd 05 05:35 PM |
| BrandNew-Vector Heavy Duty Plastic Construction Tape Dispenser 13 Peaces Left | [email protected] | Aviation Marketplace | 0 | April 30th 04 12:43 AM |
| TURBULATOR TAPE ON VENTUS B | Ventus B | Soaring | 5 | February 18th 04 09:27 PM |
