FYI: I am helping a 210 owner install a FlightCom 403 stereo
panel-mounted intercom. After straightening out some shielding/grounding/wiring/input-level issues, and while testing the unit, I noticed that the music quality through his headphones sounded very "tinny", was obviously lacking in bass response, level was too low to be useable when the engine was running, and it has quite a lot of distortion. I'm used to good sounding stereo in my own a/c, so I have a basis for comparison. btw, I homebrewed my own stereo music switcher from scratch.. I went and got my stereo Lightspeed headsets, no improvement. I went and got my Sony CD DiscMan CD player to use as a music source; no improvement. Next we called customer service at FlightCom. They were very helpful, but I had already tried everything the technician suggested, with no improvement. During the call, the technician mentioned that they had recently done a design change because customers were complaining that the entertainment level was too low relative to the intercom and/or aircraft radios, especially when using MP3 and IPOD players. Without really saying so, he hinted that I might want to undo the ECO change, and offered to email me a schematic/parts-placement diagram. I used the supplied data to "reverse-engineer" their intercom. It became obvious to me that their design change was in-fact responsible for the distortion. They added two resistors to increase the gain of the "input" amplifiers, thinking that would make MP3/IPOD players louder, but what they actually did was to drive the input ampifiers into saturation at normal listening levels. Undoing the change (removing two resistors) reduces the gain back to where it used to be, eliminating the saturation (clipping) and the distortion is gone. However, that left the entertainment level at the headphone outputs too low. I added two resistors (parallel with existing resistors) in the summing network at the main Left & Right output amplifiers, thereby increasing the level of the entertainment without changing the relative loudness of either the intercom or aircraft radios. That still leaves the missing bass response. I analyzed their circuit, and sure enough, each entertainment channel has three coupling capacitors in the path that are too small by an order of magnitude (0.1uF should be 1uF or more, in six places). Sweeping the audio response from the entertainment input to the stereo headphone output in an unmodifed unit shows that the low frequency response is down -3db at 300Hz, and -55db at 20Hz. That is what makes music sound like it is being pushed through a taught string! I sent an email to FlightCom to suggest that they need to hire me as a consultant to fix their design... In summary, the unit as it comes from FlightCom is unacceptable for music quality. Even though you could fix it, how many of you are willing to go through the hassle. In its present state, I can't recommend it to anybody... |
Mikem,
In summary, the unit as it comes from FlightCom is unacceptable for music quality. One name: PS Engineering. -- Thomas Borchert (EDDH) |
mikem wrote:
FYI: I am helping a 210 owner install a FlightCom 403 stereo [snip] Sweeping the audio response from the entertainment input to the stereo headphone output in an unmodifed unit shows that the low frequency response is down -3db at 300Hz, and -55db at 20Hz. That is what makes music sound like it is being pushed through a taught string! I sent an email to FlightCom to suggest that they need to hire me as a consultant to fix their design... In summary, the unit as it comes from FlightCom is unacceptable for music quality. Even though you could fix it, how many of you are willing to go through the hassle. In its present state, I can't recommend it to anybody... Thanks for that writeup Mike, I am shopping for a new intercom (for my 210 no less) and will avoid that one! -- Cheers, John Clonts Temple, Texas N7NZ |
Mike, with all due respects, the designer can only do what the requirements
group tell him or her to do. The design doesn't need "fixing", the requirements need to change. For voice quality intercoms, a bandwidth of 300-3000 Hz is considered entirely adequate. No, it won't reproduce the cannon in the 1812 Overture worth a damn, but it will give entertainment quality sound. It is NOT tin can quality, it is a bit better than telephone quality which is what an intercom was intended to do in the first place. It is YOUR subjective opinion that a low frequency corner of 300 Hz. is inadequate. That may have been the design goal -- intercom quality with lowered rumble and hiss to the music. Purely subjective. Given a 3 dB corner (I would have preferred a 9 dB corner for reasons that will become obvious) and a 20 dB/decade drop per pole, it would appear that there are three poles between input and output that are band limiting. I subjectively agree that two of these are unnecessary, but I'd just as soon start rolling everything off below 300 Hz., albeit not quite this fast. Given your measurements below and postulating three poles lets me guess that the 9 dB (3 dB per pole) is going to be somewhere around 150 Hz. and then the 60 dB point 15 Hz. That is my best guess at what the designer was trying to achieve. The wonderful thing about being the requirements department in the morning and the design department in the afternoon lets me take the heat for the whole damned product {;-). BTW, if what you said was in fact the case, going from a 0.1 uF capacitor (mylar) to a 1 uF capacitor (electrolytic) saves me 3 dB in board real estate and 6 dB in cost. Hell of a tradeoff for better performance -- smaller and cheaper (if the topology allows capacitor polarization). Jim mikem wrote: FYI: I am helping a 210 owner install a FlightCom 403 stereo [snip] Sweeping the audio response from the entertainment input to the stereo headphone output in an unmodifed unit shows that the low frequency response is down -3db at 300Hz, and -55db at 20Hz. That is what makes music sound like it is being pushed through a taught string! I sent an email to FlightCom to suggest that they need to hire me as a consultant to fix their design... |
RST Engineering wrote:
Mike, with all due respects, the designer can only do what the requirements group tell him or her to do. The design doesn't need "fixing", the requirements need to change. For voice quality intercoms, a bandwidth of 300-3000 Hz is considered entirely adequate. No, it won't reproduce the cannon in the 1812 Overture worth a damn, but it will give entertainment quality sound. It is NOT tin can quality, it is a bit better than telephone quality which is what an intercom was intended to do in the first place. It is YOUR subjective opinion that a low frequency corner of 300 Hz. is inadequate. That may have been the design goal -- intercom quality with lowered rumble and hiss to the music. Purely subjective. Maybe subjective, but here are my requirements for the entertainment channel in my airplanes: I use Lightspeed ANR headsets. They do a great job of reducing the ambient cockpit noise in the range from 20 to 250Hz; above that, the noise reduction is equivelent to good passive headsets. Since I am of advanced age and am loosing my high frequency hearing, music sounds best when I can hear the bass, and the bass sounds particularly good when the ANR gets rid of anything that would compete with it. I have taken the Lightspeeds home and compared them to my old expensive Koss (dating myself) stereo headphones that I use for classical music listening after the wife goes to bed. The Lightspeeds are almost as good as the Koss. btw-David Clark and other brands suck in this comparison. If I connect my Sony Walkman CD player to the Lightspeeds, they sound better (richer, fuller bass) than the little headphones that came with the Sony. The level is a little low, but I'll talk about that later. The quality is as good as listening through my home CD deck and Stereo amp. When I use the same Lightspeeds and CD player in the aircraft, I dont want the sound to be made worse by having an intercom in between the CD and the Lightspeeds. The 403 does NOT acheive this requirement! I agree that the frequency response of the aircraft-to-headphones and intercom-to-headphones channels of an aircraft intercom should be constrained to 300-3000Hz, the music channel should not. ... The wonderful thing about being the requirements department in the morning and the design department in the afternoon lets me take the heat for the whole damned product {;-). I dont care if it was the Sales or the Engineering dept that screwed up the 403; it is definitely screwed up! ----------------------------------------------------------------------- More on the Sony output being too low to drive the Lightspeeds: The max loudness is just short of what you would like it to be in the aircraft. It is fine in a quiet living room. The Sony player runs on just two AAs, and can produce a maximum of 3Vp-p (1Vrms) into the LightSpeeds. The Lightspeeds require about 5Vp-p to drive them to an approprate loudness for a noisy cockpit, even with the ANR enabled. The Sony headphones have a lower impedance than the Lightspeeds, so they sound louder... I learned this when I tried to use the Sony CD player with the Sigtronics SPA400 with add-on RES400 stereo music switcher in my Pacer. The RES400 uses a DPDT relay to switch either the aircraft and intercom audio, or the music to the headphones; no amplification, no frequency shaping. It sounds good on the ground, but at takeoff/criuse rpms, the level is just a little low. I ended up building a stereo amp with a gain of about 3 and putting it between the CD output and the input to the RES400. It works so well that I built a similar stereo amp/relay switcher for the 182. When I plugged the same CD player and Lightspeeds as I use in my aircraft into the friends 210, the missing frequency response is glaring... |
Mikem,
The 403 does NOT acheive this requirement! Again, IMHO you got what you paid for. If you want an "entertainment channel" in your aircraft, not an intercom, then you'll have to shell out the dollars for it. -- Thomas Borchert (EDDH) |
| Thread Tools | |
| Display Modes | |
| Updated RST Audio Panel? | N523RV | Home Built | 11 | April 21st 05 02:51 AM |
| Any opinions on Flightcom 403D intercom? | Rob Turk | Home Built | 1 | November 7th 04 03:42 AM |
| Intercom: IntelliVox vs. ENRI | ROBIN FLY | Owning | 4 | December 2nd 03 05:36 PM |
