T? or F? Acetone In Fuel Said to Increase Mileage
Old April 14th 06, 01:02 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default T? or F? Acetone In Fuel Said to Increase Mileage
Has this one been around the block a few times?
It was an interesting read.
http://www.pureenergysystems.com/new...00069_Acetone/
"Readily-available chemical added to gas tank in small proportion improves
the fuel's ability to vaporize completely by reducing the surface tension
that inhibits vaporization of some fuel droplets."
http://toyotaownersclub.com/forums/i...howtopic=44575
Chat room chat about acetone - mostly diesel cars.
This is for diesels mostly ...and mogas WITHOUT alcohol in it. A few
ounces/10 gallons is all you use.
Montblack
Old April 14th 06, 01:12 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
30% increase of gas mileage? That's some outrageous claims.
Old April 14th 06, 02:14 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Montblack" wrote in message
In gasoline engines, unburned Hydrocarbons amount to about 1% of the total
fuel, and most of those come from crevices such as the gap around the piston
above the top ring, and around the spark plug - the compression and pressure
rise pushes the mixture into these spots where the flame front is quenched.
The next largest source is a thin layer that is quenched at the cylinder
walls from the heat loss to the metal.
I don't have the numbers handy for diesels, but I'm reasonably confidant
that the percentage isn't a lot different even if the sources are different
(over rich areas in the fuel spray generate soot due to inadequate air and
some of the mixture around the fringe of the spray is too lean to burn).
The fact of the matter is that the moon landings are fake, the alien
autopsies are real, and the thousands of engineers that work for all the
auto companies all around the world (that look at fuel sprays and
combustions with lasers, high speed cameras, optically transparent engines
of all types, computer modeling, etc.) are completely unaware of potential
fuel consumption improvements like this one.
Geoff
Old April 14th 06, 08:51 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
In article , TheSeaHawkatwowwayd0tcom
says...
That's right! ;-)
And advanced concepts like vapor pressure (volatility) are just way out of
their league!
Of course, the vapor pressure of the fuel varies considerably with ambient
temperature, and the designers must optimize all of the fuel delivery and
mixing parameters for an average. Then the fuel product delivered is varied
throughout the year in places where wide seasonal variations could otherwise
make conditions far from the design datum. Perhaps it could happen that someone
in one such place has been able to achieve a slight improvement with a home
brew additive - he'll have to weigh the savings against the increased
maintenance costs in early replacement of all polymerized parts of his fuel
delivery system.
GF
Old April 16th 06, 03:19 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Geoff
It does work or at least helps. I tried to use it after adding
magnets, the little carburetor mini turbos, water injection etc. but
when I found that every time I drove the car, the gas tank was
overflowing I had to quit.
Harry K
Old April 14th 06, 03:05 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Regardless, I wouldn't put that or any other chemical in a fuel system not
specifically designed for it.
__________________________________________________ _______________
Like free stuff?
www.givie.com
Old April 14th 06, 04:20 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Yep. I would not be too keen on putting very much ketones into any fuel
system that has any plastic or rubber parts anywhere in contact with
the fuel.
Old April 14th 06, 12:16 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
the fuel.
Cue the Ketone Cops.
Dan, U.S. Air Force, retired
Old April 14th 06, 09:07 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
On Thu, 13 Apr 2006 22:05:52 -0400, "JohnH"
But if you pu tit in your fiberglass airplane fule tanks they will
start getting larger, well at least between the ribs on the bottom.
OTOH you'll be able to see the ribs on top too.
www.rogerhalstead.com
Old April 14th 06, 12:18 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Gee, if a little acetone will do this much good just think about what
putting MEK into the tank will do for your mileage...
denny, aka P.T. Barnum
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
"Tanks on both" checklist item Koopas Ly Piloting 46 December 12th 03 03:42 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
