Does anyone have any recommendations on the appropriate
solar cell technology for in flight recharging of sealed lead acid batteries? Ie Eg what's the recommended regulator technology - is it normal to shunt the solar cells when the battery voltage rises at full charge to prevent overcharging? This seems a little strange to me (ie you allow the solar cells to discharge at high current through a shunt thereby dissapating the full wattage of the solar cells rather than increasing the series impedance in the charging line). Any recommended manufacturers of regulator/shunt units? Any recomended panel suppliers? |
The glider manufacturers, who offer solar panels, only use a couple of
flexible PV panel brands I'm aware of - Stroble (sp?) and one other that Schleicher has just started installing on new ships. As far a solar charge controllers go, there's the cheap switching type, the slightly better pulse width modulated, and the *recommended* Maximum Power Point Tracking (MPPT) type. The MPPT will also use a pulse width modulated output. I've only been able to find one brand of MPPT that is suitable for glider use. See: http://shop.altenergystore.com/itemd...D5~eq~~Tp~.htm Using MPPT can gain as much as 30% more current from a given PV panel array. This is important where maximum output is needed but there is limited room for installing more panels. To learn more about MPPT and how it works, I thing Blue Sky has some good info, see: http://www.blueskyenergyinc.com/pdf/...Edatasheet.pdf all the best, bumper "Dave Sinclair" wrote in message ... Does anyone have any recommendations on the appropriate solar cell technology for in flight recharging of sealed lead acid batteries? Ie Eg what's the recommended regulator technology - is it normal to shunt the solar cells when the battery voltage rises at full charge to prevent overcharging? This seems a little strange to me (ie you allow the solar cells to discharge at high current through a shunt thereby dissapating the full wattage of the solar cells rather than increasing the series impedance in the charging line). Any recommended manufacturers of regulator/shunt units? Any recomended panel suppliers? |
Having used photovoltaics at home for 4 years with no regulator
between the 1250W array and the batteries, I can say this works if there is always a load on the batteries.Not a problem with a house. Recently installed a Blue Sky MPPT 48V 30A controller to add efficiency. I still need to add another 250W of PV, as my electric bill is nearly $40 this year... Bumper's suggested controller will work great in a glider if you're leaving it tied down outside for days. It's highly unlikely that the PV panel will produce enough current to overcharge the battery in flight. Without a charge controller, use a zener diode in series with the panel. You can pick up flexible PV panels on E-Bay. Search for flexible solar panel or powersheet. A 5W powersheet will be about $80-100 US. You could probably fit 12V 10W behind the canopy, above the spar. If you're recharging the batteries on the ground pre/post flight, use at least a 25W panel (the bigger the better), and a charge controller. Jim |
JS wrote:
snip If you're recharging the batteries on the ground pre/post flight, use at least a 25W panel (the bigger the better), and a charge controller. Bigger is better only if you need the current, otherwise, it's just bigger and more expensive. * If you run a radio and vario, and fly less than 5 hours a day and put out the panel when you land, then reorient it in the evening for the morning sun, a 5 watt panel will likely be adequate. * If you run a radio, vario, GPS logger, Ipaq, transponder with encoder, and fly 6 or 7 hours a day, you'll need that 25 watt panel to fully charge every day. 5 watt panel ~$100; 25 watt panel ~ $300. I fit the second case, but opted for a 15 watt panel because I have a large battery, so I don't have to fully recharge in one day. If I fly 3 days out of 4, the battery stays charged. Another option is to have two battery packs, one of which charges while the other is flying. That charges it during the peak of the day, and so it doesn't need nearly as big a panel. If you can change packs easily, it's worth considering, as it's cheaper and more flexible. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
Jim,
It is very remarkable you have been able to do this to your batteries for four years without damage. I wouldn't recommend it for large solar systems. However, for an in-flight use, where the pv is basically augmenting the battery supply a charge controller isn't needed. With longer term charging & sustaining an inexpensive controller is essential if you want to get the full life out of the batteries. Regarding your need for 250 more watts: You might want to do some math as it looks like you are right on with what you have now. PV's today are going for between $4 and $6 per watt, so your 250 W would cost you around $1,000 at the bottom end not including freight, mounting, and labor. So at $40/year savings it would take you the life of the PV to earn back your expense, not considering present dollar value or roi on the $1000 if you didn't spend it. Sounds like you planned your system very, very well! |
"Go" wrote in message oups.com... However, for an in-flight use, where the pv is basically augmenting the battery supply a charge controller isn't needed. Until somebody forgets that there is no controller and the glider happens to spend a few days out of the trailer... I have ruined enough batteries from overcharging to have finally had the lesson forever drilled into my head; charge controllers are cheap and necessary. With longer term charging & sustaining an inexpensive controller is essential if you want to get the full life out of the batteries. I agree. Regards, Vaughn |
Good point.
Vaughn Simon wrote: Until somebody forgets that there is no controller and the glider happens to spend a few days out of the trailer... I have ruined enough batteries from overcharging to have finally had the lesson forever drilled into my head; charge controllers are cheap and necessary. |
If the charger is simply a "sustainer" you can get by without a charger
controller. That reduces the losses or expense of the conttroller. If you need to use a controller, it might be noted that the military prefers to use a shunt charge controller, rather than a series one. The main reason for this is the controller usually fails open. An open series controller will not charge. However, an open shunt conytroller will continue to charge (but not control). Note that a charge controller is not a regulator. It does not limit current. There is a nice section on charge controllers for photovoltaic systems in a book entitled "Emergency Power for Radio Communications" published by ARRL, ISBN 0-87259-933-1. It can be ordered at www.arrl.org for $19.95. Colin |
Dave Sinclair wrote: Does anyone have any recommendations on the appropriate solar cell technology for in flight recharging of sealed lead acid batteries? Ie Eg what's the recommended regulator technology - is it normal to shunt the solar cells when the battery voltage rises at full charge to prevent overcharging? This seems a little strange to me (ie you allow the solar cells to discharge at high current through a shunt thereby dissapating the full wattage of the solar cells rather than increasing the series impedance in the charging line). Any recommended manufacturers of regulator/shunt units? Any recomended panel suppliers? The main issue for in-flight solar charging is where do you put the dog goned panel? Rigid panels can only be put inside the cockpit, so a thin, flexible panel. These are available, but at a jaw-dropping price. A reasonable alternative to solar charging is to use a bigger battery (or more of them). You can still charge with solar, but it is on the ground. That is how I keep my batteries charged in my DG400, and it really makes a BIG difference. I used to charge them while I was assembling using the car. The battery voltage would indicate that they were charged (13.9 V), but they weren't. I would really find this out if I had any difficulty starting and had to crank more than usually. At times I would have give up and pull my car over for a jump start (not a pleasant task when you are by yourself!). Now I have no problem cranking, even if I have to crank it a lot. And I have plenty of reserve capacity to start it again after I have landed from a 4-5 hour flight. And these are 3 year old SLA type batteries. I use a 20 W panel with a solar charge controller. No need for a fancy MPPT type, because I have plenty of time to charge the batteries. It is a PWM controller with anti-sulfating circuitry (I have previously posted the source of the panel and controller). Some year I am going to locate a higher engery density battery in the SLA form factor, such as a lithium-ion or a nickle-metal hydride. But so far no luck. You can have battery packs made out of individual cells, but they are VERY expensive and come with no warranty. Tom Seim DG400 Richland, WA |
Found this while looking for something else. Don't know if the price
is fair. http://www.costco.com/Browse/Product...nav=&brows e= |
| SoLong Solar-Electric UAV 48 hour flight | Larry Dighera | Piloting | 6 | September 25th 16 09:01 PM |
| Solar Airplane, Piccard&A-rabs | Jim Culp | Soaring | 1 | April 1st 05 04:27 AM |
| Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Piloting | 7 | March 14th 05 08:36 AM |
| Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Soaring | 7 | March 14th 05 08:36 AM |
| Gliding electic flight - cells which one? | max christoffersen | Soaring | 1 | November 30th 03 10:06 PM |
