Would someone please give me the specs for the AC-DC transformer for
the ICOM A-23? I've misplaced mine and ICOM wants $40 for a replacement. I can probably do better with a generic one from Radio Shack. I need to know the polarity, DC voltage, and amps. Thanks (Sorry for the cross-post to rec.aviation.piloting, but that group seems more active than the rest.) |
Mine says:
Input: 120VAC 60Hz 4.5W Output: 12VDC 200 mA Class 2 Transformer wrote in message oups.com... Would someone please give me the specs for the AC-DC transformer for the ICOM A-23? I've misplaced mine and ICOM wants $40 for a replacement. I can probably do better with a generic one from Radio Shack. I need to know the polarity, DC voltage, and amps. Thanks (Sorry for the cross-post to rec.aviation.piloting, but that group seems more active than the rest.) |
Sorry, forgot the polarity:
Outer ring -, Inner ring + "Jeremy Lew" wrote in message . .. Mine says: Input: 120VAC 60Hz 4.5W Output: 12VDC 200 mA Class 2 Transformer wrote in message oups.com... Would someone please give me the specs for the AC-DC transformer for the ICOM A-23? I've misplaced mine and ICOM wants $40 for a replacement. I can probably do better with a generic one from Radio Shack. I need to know the polarity, DC voltage, and amps. Thanks (Sorry for the cross-post to rec.aviation.piloting, but that group seems more active than the rest.) |
Thanks!
"rps" wrote:
Thanks! And these little 'wall warts' will work fine, I use a bunch here on my many hand held ham trancseivers...just make sure that the voltage is close and that the polarity is right (and the current at or above specs) -- -Gord. (use gordon in email) |
Gord Beaman wrote:
"rps" wrote: Thanks! And these little 'wall warts' will work fine, I use a bunch here on my many hand held ham trancseivers...just make sure that the voltage is close and that the polarity is right (and the current at or above specs) I've always wondered why equipment manufacturers don't put a full wave bridge (4 diodes) in the battery circuit so it doesn't matter how you insert the batteries (or the polarity of a charger brick). |
![]() "Greg Farris" wrote in message ... In article , says... Sorry, forgot the polarity: Outer ring -, Inner ring + You also need the size - these things come in a million different sizes. The Outside Diameter on mine is 3.5mm. GF Look here. Cheep Cheep! http://www.hosfeltelectronics.com/ |
Icom A6 Radio Registration Problem | Clyde Torres | Home Built | 4 | May 6th 05 12:21 PM |
ICOM IC-A23 Sport | Karl-Heinz Künzel | Piloting | 1 | September 11th 04 06:43 PM |
Need part number for Icom antenna jack | Roy Smith | Owning | 2 | March 17th 04 09:59 PM |
Icom Boom Mike | Kevin Neave | Soaring | 2 | September 25th 03 09:39 AM |
Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio | A. Kay | Aviation Marketplace | 0 | August 23rd 03 08:01 AM |
