Flying from Buffalo, NY, to Reading, PA, this afternoon, I call up
Cleveland Flight Watch to report a weather pirep. "Visibility is restricted in haze to about one five miles," I include. "45 Whisky," the voice responds, "visibility is considered unrestricted if it is greater than six miles so I am going to put unrestricted." "Huh?" I let slip out, "Really?" "Yes, really," he answers. If this is indeed true, I have been doing it wrong for almost 1,000 hours now. Too late tonight for me to go digging through the AIM, but is this really true? Imagine being VFR through typical New England haze of 7 miles and being told by Fligh****ch that pireps all over the region are reporting unrestricted visibility. That just doesn't seem right. -- Peter |
Now imagine the same thing in SoCal, which is where I learned to fly. I think they have several definitions of "three miles", depending on the day. ![]() Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
It's not a conspiracy of mediocrity, it's due to a technical limitation
of the scatterometer technology used by ASOS's to determine visibility, if I recall correctly. They can only really be accurate out to about 6 miles. A human with a Mark I Eyeball could pick a landmark furthre away and provide a bigger distance, but for all intents and purposes, the max visibility will be defined by the technical limitations of the available data sources. Of course, I might be dramatically incorrect, this was what I learned from my instructor. Ben Hallert PP-ASEL |
of the scatterometer technology used by ASOS's to determine visibility, if I recall correctly. They can only really be accurate out to about 6 miles. Then visibility should be reported as "greater than six" (which I have heard) Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message . com... Then visibility should be reported as "greater than six" (which I have heard) You've heard "greater than six" or "greater than" reported? ASOS reports visibility up to ten miles. |
Ben Hallert wrote:
snip They can only really be accurate out to about 6 miles. A human with a Mark I Eyeball could pick a landmark furthre away and provide a bigger distance, but for all intents and purposes, the max visibility will be defined by the technical limitations of the available data sources. Since the source of a pirep is a pilot, not an automated weather station, and the main recipient of a pirep is a pilot, not an automated weather station, visibility should be reported as an estimation in the pilot's opinion much greater than that which is artificially restricted by automation. In any event, I did call Buffalo FSS late last night to ask the specialist about this and in his opinion the Cleveland specialist was incorrect. Report visibility in the distance we see, were his words. Again, had I been a low time VFR pilot launching on a cross country, I certainly would want to know about haze limiting visibility, for even 10 miles and haze will appear much lower as the sun draws closer to the horizon. -- Peter |
Peter R. wrote:
Again, had I been a low time VFR pilot launching on a cross country, I certainly would want to know about haze limiting visibility, for even 10 miles and haze will appear much lower as the sun draws closer to the horizon. This P6SM stuff is one of the (few) ways the ICAO weather reporting system of TAF and METAR is inferior to our old SA/FA system. The old FAs used to forecast visibility as 10, 15, 20, whatever was appropriate. Now all that just gets folded into P6SM. For somebody planning a VFR X/C (especially a student or inexperienced pilot), there's a big difference between 6 miles and 20 (or even 10). It's not like the computer models can't differentiate between them. It doesn't even take any more characters to transmit. It's just plain dumb that the information exists and is kept hidden. |
![]() "Ben Hallert" wrote in message oups.com... It's not a conspiracy of mediocrity, it's due to a technical limitation of the scatterometer technology used by ASOS's to determine visibility, if I recall correctly. They can only really be accurate out to about 6 miles. A human with a Mark I Eyeball could pick a landmark furthre away and provide a bigger distance, but for all intents and purposes, the max visibility will be defined by the technical limitations of the available data sources. The short answer to the OP question is: YES! This is not so much due to a "technical limitation", as it is due to *history*. The requirements forever (well, at least since the 1950's), have been that .... no restriction to visibility is reported, whenever the visibility is more than 6 statute miles... In other words, an observation may *not* read 7 miles in haze, or 7 miles in mist, etc. *Precipitation* may be reported at visibilities greater than 6, but you do not report non-precipitation-phenomena by itself. You would just report "visibility 7 statute miles", period. Thus, a visibility above 6 statute miles, as per the technical requirement of observing weather, is "not obstructed". Now, in general, when you had manned systems, airports attempted to have visibility markers out to *at least* 15 statute miles, and a report of 15 was the norm for "unrestricted" visibility. Thus, you kind of knew that something was going on, should that station suddenly report "10", or "8", even if he did *not* show the reason. However, with the increasing advent of automated systems, you have lost that extra human insight, because the technical requirement is met by saying.... "greater than 6" equals "not obstructed"..... so you might get "greater than 6" on a day when visibility is 50, and from the same station you get "greater than 6", when visibility is 7. In that sense, I *DO* say that it *is* a conspiracy of mediocrity. To automate things, and to meet only the basic requirements of producing a METAR... a lot of the stringent reporting practices of the 60's and 70's seem to be slipping away. |
Icebound wrote:
In that sense, I *DO* say that it *is* a conspiracy of mediocrity. To automate things, and to meet only the basic requirements of producing a METAR... a lot of the stringent reporting practices of the 60's and 70's seem to be slipping away. Thanks, Ice. I appreciate your knowledgeable weather contributions to this group. -- Peter |
![]() "Icebound" wrote in message Now, in general, when you had manned systems, airports attempted to have visibility markers out to *at least* 15 statute miles, and a report of 15 was the norm for "unrestricted" visibility. When I learned to fly in the Denver area, I got accustomed to wx reports that included "clear and 70". The guys in the tower at Stapleton would just look south. If they could see Pike's Peak, the vis was 70. Easy. Infallible. No gizmo to break. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 04:42 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
