We have a doctor who just bought a 206 and after less than a month the
chopper has been sent for a new engine. I heard he had a "Hot Start" and burned out the engine. While I'm both fixed wing and helicopter certified I have zero experience with jets so what did he do? And what's it gonna cost him? |
The indication of a hot start is when the TOT (turbine outlet temp) runs
away and goes far too high. Internally its casued when the flameball does not form correctly as a result of too much fuel, too high of a pre-existing temperature, or incorrect/sufficient airflow. It requires an inspection and if he melted enough stuff it could cost around $90,000. Bart "601XL Builder" wrDOTgiacona@coxDOTnet wrote in message ... We have a doctor who just bought a 206 and after less than a month the chopper has been sent for a new engine. I heard he had a "Hot Start" and burned out the engine. While I'm both fixed wing and helicopter certified I have zero experience with jets so what did he do? And what's it gonna cost him? |
OUCH! :-(
"B4RT" wrote in message ... The indication of a hot start is when the TOT (turbine outlet temp) runs away and goes far too high. Internally its casued when the flameball does not form correctly as a result of too much fuel, too high of a pre-existing temperature, or incorrect/sufficient airflow. It requires an inspection and if he melted enough stuff it could cost around $90,000. Bart "601XL Builder" wrDOTgiacona@coxDOTnet wrote in message ... We have a doctor who just bought a 206 and after less than a month the chopper has been sent for a new engine. I heard he had a "Hot Start" and burned out the engine. While I'm both fixed wing and helicopter certified I have zero experience with jets so what did he do? And what's it gonna cost him? |
Well they yanked off the rotor blades and put the 206 on a truck so my
bet is he burnt up what could be burnt. Steve R wrote: OUCH! :-( "B4RT" wrote in message ... The indication of a hot start is when the TOT (turbine outlet temp) runs away and goes far too high. Internally its casued when the flameball does not form correctly as a result of too much fuel, too high of a pre-existing temperature, or incorrect/sufficient airflow. It requires an inspection and if he melted enough stuff it could cost around $90,000. Bart "601XL Builder" wrDOTgiacona@coxDOTnet wrote in message ... We have a doctor who just bought a 206 and after less than a month the chopper has been sent for a new engine. I heard he had a "Hot Start" and burned out the engine. While I'm both fixed wing and helicopter certified I have zero experience with jets so what did he do? And what's it gonna cost him? |
He must be very new to turbines. Had to be more than a hot start, must
have been a fire. Hot start usually would just require inspection of the burner can. Removing can and power turbine would probably be something a mechanic could do on site in a few hours and ship to facilitate the inspection. Moving the complete helicopter is a waste unless being returned to seller as a warranty return. A simple hot start only requires a flight test procedure and at the worst can be flown to a repair facility with in reasonable distance. "601XL Builder" wrDOTgiacona@coxDOTnet wrote in message ... Well they yanked off the rotor blades and put the 206 on a truck so my bet is he burnt up what could be burnt. Steve R wrote: OUCH! :-( "B4RT" wrote in message ... The indication of a hot start is when the TOT (turbine outlet temp) runs away and goes far too high. Internally its casued when the flameball does not form correctly as a result of too much fuel, too high of a pre-existing temperature, or incorrect/sufficient airflow. It requires an inspection and if he melted enough stuff it could cost around $90,000. Bart "601XL Builder" wrDOTgiacona@coxDOTnet wrote in message ... We have a doctor who just bought a 206 and after less than a month the chopper has been sent for a new engine. I heard he had a "Hot Start" and burned out the engine. While I'm both fixed wing and helicopter certified I have zero experience with jets so what did he do? And what's it gonna cost him? |
Wow,
"..at the worst can be flown..." ? WTF DUDE!. Are you crazy? I don't want to be harsh, but if you do have a hot start call a factory authorized repair station for your engine or aircraft (in this case Rolls Royce / Bell) and follow THEIR advice. DO NOT FLY YOUR MACHINE unless you get sage wisdom and authorization from one of these. Bart "RPE" wrote in message . com... He must be very new to turbines. Had to be more than a hot start, must have been a fire. Hot start usually would just require inspection of the burner can. Removing can and power turbine would probably be something a mechanic could do on site in a few hours and ship to facilitate the inspection. Moving the complete helicopter is a waste unless being returned to seller as a warranty return. A simple hot start only requires a flight test procedure and at the worst can be flown to a repair facility with in reasonable distance. do |
![]() "RPE" wrote in message . com... He must be very new to turbines. Had to be more than a hot start, must have been a fire. Hot start usually would just require inspection of the burner can. Removing can and power turbine would probably be something a mechanic could do on site in a few hours and ship to facilitate the inspection. Moving the complete helicopter is a waste unless being returned to seller as a warranty return. A simple hot start only requires a flight test procedure and at the worst can be flown to a repair facility with in reasonable distance. Sorry, I disagree (with that very last part). I've released a lot of aircraft as "Certified Safe for Flight" and I would NOT allow even a one-way flight after an event like that. If the bird is down, it's DOWN. Aircrew lives depend on my signature and I don't take that lightly. They can 'fly' it over on the back of a trailer. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Question for Pressurised Baron pilots | DeltaDeltaDelta | Piloting | 12 | December 4th 03 01:54 PM |
