I can use the club's compressor, but I need to bring my bead-blaster
to that location. Looking for schemes for erecting a temporary, portable sand blasting 'cabinet'. Thinking of something large enough for a rudder or smaller if we can insert half of the work at a time. Thinking of a poly-sheet over a PVC frame about a foot high. Anyone done something similar? - MIke |
"Michael Horowitz" wrote in message
news ![]() I can use the club's compressor, but I need to bring my bead-blaster to that location. Looking for schemes for erecting a temporary, portable sand blasting 'cabinet'. Thinking of something large enough for a rudder or smaller if we can insert half of the work at a time. Thinking of a poly-sheet over a PVC frame about a foot high. Anyone done something similar? - MIke For sandblasting I just lay out a big tarp on the lawn. Set the parts on a basket. Most of the sand stays on the tarp, the rest ends up in the grass Setting buckets around the work helps trap more... 'course sand is cheaper than beads - I don't mind if I loose 5-10%. Wear a good dust mask and goggles. Tyvek coveralls help keep the sand out of your shorts. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Portable GPS w/ VOR? | Mini Moebius | Piloting | 6 | June 3rd 11 12:30 PM |
A Temporary Flight Restriction is like ... | Larry Dighera | Piloting | 1 | August 19th 05 03:21 AM |
Portable Push-To-Talk switch help | Eric Brown | Owning | 9 | April 16th 04 04:26 AM |
