Hi!
I was told by my mechanic to only pull the prop handle until I could audibly hear a slight pitch change to establish that it was working. However, the aircraft manual says it should be cycled completely, and on a cold engine three times to make sure oil is applied to the governor, or the pitch mechanism. Can someone elaborate on this? What is recommended? Thanks, Frode |
![]() "Frode Berg" wrote in message ... Hi! I was told by my mechanic to only pull the prop handle until I could audibly hear a slight pitch change to establish that it was working. However, the aircraft manual says it should be cycled completely, and on a cold engine three times to make sure oil is applied to the governor, or the pitch mechanism. Can someone elaborate on this? What is recommended? Thanks, Frode POH rules of course, but aside from that, I always liked to exercise a prop through several cycles, especially when cold, just to get everything nice and warm and fluid up there. Dudley Henriques |
The prop governor controls within a range and should hold a
steady rpm within that range. When the run-up is done at say, 2400 rpm the prop should be cycled to the minimum rpm and allowed to stabilize for a few seconds to check that the governor is working properly. On a multiengine airplane the prop should be reduced to just outside the feather detent and allowed to run for several seconds to be sure that the prop isn't feathering at the minimum governed speed [usually 2000 rpm on most piston engines]. If the prop control is not rigged properly the prop will feather too soon. Then the prop feather check should be done. Most props have a certain amount of internal leakage to keep warm oil circulating in the prop hub, but several cycles on a cold engine/prop will assure that the prop does reach proper operating temperatures. In very cold temperatures, I like to vary the rpm every some often to be sure the prop is functioning, but normal internal flow should make this mostly an unneeded habit. Remember, on a single-engine reducing rpm send oil to the prop and on a multi, reducing rpm/feathering drain oil from the prop. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Dudley Henriques" wrote in message ink.net... | | "Frode Berg" wrote in message | ... | Hi! | | I was told by my mechanic to only pull the prop handle until I could | audibly | hear a slight pitch change to establish that it was working. | | However, the aircraft manual says it should be cycled completely, and on a | cold engine three times to make sure oil is applied to the governor, or | the | pitch mechanism. | | Can someone elaborate on this? | | What is recommended? | | Thanks, | | Frode | | POH rules of course, but aside from that, I always liked to exercise a prop | through several cycles, especially when cold, just to get everything nice | and warm and fluid up there. | Dudley Henriques | | |
If all this was meant for me, I'm pretty sure I just might already know
these things :-) Dudley Henriques "Jim Macklin" wrote in message news:yZS2g.6789$ZW3.6526@dukeread04... The prop governor controls within a range and should hold a steady rpm within that range. When the run-up is done at say, 2400 rpm the prop should be cycled to the minimum rpm and allowed to stabilize for a few seconds to check that the governor is working properly. On a multiengine airplane the prop should be reduced to just outside the feather detent and allowed to run for several seconds to be sure that the prop isn't feathering at the minimum governed speed [usually 2000 rpm on most piston engines]. If the prop control is not rigged properly the prop will feather too soon. Then the prop feather check should be done. Most props have a certain amount of internal leakage to keep warm oil circulating in the prop hub, but several cycles on a cold engine/prop will assure that the prop does reach proper operating temperatures. In very cold temperatures, I like to vary the rpm every some often to be sure the prop is functioning, but normal internal flow should make this mostly an unneeded habit. Remember, on a single-engine reducing rpm send oil to the prop and on a multi, reducing rpm/feathering drain oil from the prop. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Dudley Henriques" wrote in message ink.net... | | "Frode Berg" wrote in message | ... | Hi! | | I was told by my mechanic to only pull the prop handle until I could | audibly | hear a slight pitch change to establish that it was working. | | However, the aircraft manual says it should be cycled completely, and on a | cold engine three times to make sure oil is applied to the governor, or | the | pitch mechanism. | | Can someone elaborate on this? | | What is recommended? | | Thanks, | | Frode | | POH rules of course, but aside from that, I always liked to exercise a prop | through several cycles, especially when cold, just to get everything nice | and warm and fluid up there. | Dudley Henriques | | |
No, I know that, I just tacked it on the thread for the
benefit of the others. I think most pilots and many mechanics don't really understand these things, judging by the number of twins that feather before the prop lever gets to the gate. If I win the lottery, odds 146 million to one, we can have that CFI round table and sell tickets to anyone without a CFI. CFIs can come for free. I'll pay for you and me. If I don't win the lottery, it will have to be in Wichita, can't afford to go elsewhere without the lottery. ;-)' -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Dudley Henriques" wrote in message nk.net... | If all this was meant for me, I'm pretty sure I just might already know | these things | :-) | Dudley Henriques | | "Jim Macklin" wrote in message | news:yZS2g.6789$ZW3.6526@dukeread04... | The prop governor controls within a range and should hold a | steady rpm within that range. When the run-up is done at | say, 2400 rpm the prop should be cycled to the minimum rpm | and allowed to stabilize for a few seconds to check that the | governor is working properly. On a multiengine airplane the | prop should be reduced to just outside the feather detent | and allowed to run for several seconds to be sure that the | prop isn't feathering at the minimum governed speed [usually | 2000 rpm on most piston engines]. If the prop control is | not rigged properly the prop will feather too soon. Then | the prop feather check should be done. | | Most props have a certain amount of internal leakage to keep | warm oil circulating in the prop hub, but several cycles on | a cold engine/prop will assure that the prop does reach | proper operating temperatures. | | In very cold temperatures, I like to vary the rpm every some | often to be sure the prop is functioning, but normal | internal flow should make this mostly an unneeded habit. | | Remember, on a single-engine reducing rpm send oil to the | prop and on a multi, reducing rpm/feathering drain oil from | the prop. | | | -- | James H. Macklin | ATP,CFI,A&P | | -- | The people think the Constitution protects their rights; | But government sees it as an obstacle to be overcome. | some support | http://www.usdoj.gov/olc/secondamendment2.htm | See http://www.fija.org/ more about your rights and duties. | | | "Dudley Henriques" wrote in | message | ink.net... | | | | "Frode Berg" wrote in message | | ... | | Hi! | | | | I was told by my mechanic to only pull the prop handle | until I could | | audibly | | hear a slight pitch change to establish that it was | working. | | | | However, the aircraft manual says it should be cycled | completely, and on a | | cold engine three times to make sure oil is applied to | the governor, or | | the | | pitch mechanism. | | | | Can someone elaborate on this? | | | | What is recommended? | | | | Thanks, | | | | Frode | | | | POH rules of course, but aside from that, I always liked | to exercise a prop | | through several cycles, especially when cold, just to get | everything nice | | and warm and fluid up there. | | Dudley Henriques | | | | | | | | |
I've done this a few times myself. :-)
On Usenet, if you underpost someone already in the thread but NOT the original poster, what you post is considered addressed to the person you underposted rather than simply an addition to the general thread. Any general comment should be picked up as a post to the original poster by clicking his/her post for reply. Then the comment appears referenced to the initial question and not the sub poster. I did the same thing once and gave a hundred word "lecture" on how to do a slow roll to one of the world's best acro pilots by accidentally picking him up to underpost instead of the initial poster who had asked about rolls. :-) The pilot I gave the lecture to simply gave me a one word reply "Thanks" with a smilie attached :-) That get together sounds like fun. I'll bring the bottle! Dudley "Jim Macklin" wrote in message news:nZT2g.6827$ZW3.3603@dukeread04... No, I know that, I just tacked it on the thread for the benefit of the others. I think most pilots and many mechanics don't really understand these things, judging by the number of twins that feather before the prop lever gets to the gate. If I win the lottery, odds 146 million to one, we can have that CFI round table and sell tickets to anyone without a CFI. CFIs can come for free. I'll pay for you and me. If I don't win the lottery, it will have to be in Wichita, can't afford to go elsewhere without the lottery. ;-)' -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Dudley Henriques" wrote in message nk.net... | If all this was meant for me, I'm pretty sure I just might already know | these things | :-) | Dudley Henriques | | "Jim Macklin" wrote in message | news:yZS2g.6789$ZW3.6526@dukeread04... | The prop governor controls within a range and should hold a | steady rpm within that range. When the run-up is done at | say, 2400 rpm the prop should be cycled to the minimum rpm | and allowed to stabilize for a few seconds to check that the | governor is working properly. On a multiengine airplane the | prop should be reduced to just outside the feather detent | and allowed to run for several seconds to be sure that the | prop isn't feathering at the minimum governed speed [usually | 2000 rpm on most piston engines]. If the prop control is | not rigged properly the prop will feather too soon. Then | the prop feather check should be done. | | Most props have a certain amount of internal leakage to keep | warm oil circulating in the prop hub, but several cycles on | a cold engine/prop will assure that the prop does reach | proper operating temperatures. | | In very cold temperatures, I like to vary the rpm every some | often to be sure the prop is functioning, but normal | internal flow should make this mostly an unneeded habit. | | Remember, on a single-engine reducing rpm send oil to the | prop and on a multi, reducing rpm/feathering drain oil from | the prop. | | | -- | James H. Macklin | ATP,CFI,A&P | | -- | The people think the Constitution protects their rights; | But government sees it as an obstacle to be overcome. | some support | http://www.usdoj.gov/olc/secondamendment2.htm | See http://www.fija.org/ more about your rights and duties. | | | "Dudley Henriques" wrote in | message | ink.net... | | | | "Frode Berg" wrote in message | | ... | | Hi! | | | | I was told by my mechanic to only pull the prop handle | until I could | | audibly | | hear a slight pitch change to establish that it was | working. | | | | However, the aircraft manual says it should be cycled | completely, and on a | | cold engine three times to make sure oil is applied to | the governor, or | | the | | pitch mechanism. | | | | Can someone elaborate on this? | | | | What is recommended? | | | | Thanks, | | | | Frode | | | | POH rules of course, but aside from that, I always liked | to exercise a prop | | through several cycles, especially when cold, just to get | everything nice | | and warm and fluid up there. | | Dudley Henriques | | | | | | | | |
Jim Macklin wrote:
No, I know that, I just tacked it on the thread for the benefit of the others. I think most pilots and many mechanics don't really understand these things, judging by the number of twins that feather before the prop lever gets to the gate. Thanks, Jim, for the added information. That's how I read your post; not a correction to Dudley's, but rather an addendum for us less knowledgeable. -- Peter |
Jim Macklin wrote:
snip/ Remember, on a single-engine, reducing rpm sends oil to the prop and on a multi, reducing rpm/feathering drains oil from the prop. Well, generally this is true, but not always. Hamilton Standard Hydro-Matic props, as used on the big radials, pump high pressure oil *into* the hub for feathering. If you have complete oil loss, or let the oil get too hot (and thin), you're out of luck for feathering. Happy Flying! Scott Skylane |
That's is true, but except for the Beech 18, are there any
HS props on an airplane under 12,500 pounds? The feathering on the HS is a electrical relay that turns on a high pressure pump that operates at a pressure above governor pressure. The Prop is feathered and the pump shuts off. To unfeather the button is held in so the pump continues to run and that causes the internal valve to move, re-routing the oil so it unfeathers. I wonder many pilots will take this to heart and open their POH to the systems section? -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Scott Skylane" wrote in message ... | Jim Macklin wrote: | | snip/ | Remember, on a single-engine, reducing rpm sends oil to the | prop and on a multi, reducing rpm/feathering drains oil from | the prop. | | | | Well, generally this is true, but not always. Hamilton Standard | Hydro-Matic props, as used on the big radials, pump high pressure oil | *into* the hub for feathering. If you have complete oil loss, or let | the oil get too hot (and thin), you're out of luck for feathering. | | Happy Flying! | Scott Skylane | |
![]() "Jim Macklin" wrote in message news:nqW2g.7077$ZW3.4090@dukeread04... That's is true, but except for the Beech 18, are there any HS props on an airplane under 12,500 pounds? The feathering on the HS is a electrical relay that turns on a high pressure pump that operates at a pressure above governor pressure. The Prop is feathered and the pump shuts off. To unfeather the button is held in so the pump continues to run and that causes the internal valve to move, re-routing the oil so it unfeathers. I wonder many pilots will take this to heart and open their POH to the systems section? -- James H. Macklin ATP,CFI,A&P Oh for the simple life of fighters!! :-) I used Hamilton Standard props quite a lot, but few of them feathered. The 24D50 on my Mustang didn't feather of course :-) If I remember right, the pitch range on my prop was something like 42 degrees. Dudley |
PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 04:41 AM |
Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 03:22 AM |
Pitch and Diameter of 3 blade prop for IO-360 200HP | Bart D. Hull | Home Built | 1 | December 11th 03 11:42 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
