Hi guys
We are doing a physics project in school concerning the thermodynamics of flight and I have some questions I was hoping you could help me with. I need to estimate how much heat is lost from the cabin to the outside when flying at 10000m. I have calculated the approximate outside temperature given the sea-level temperature but I don't know how planes are insulated! It is my impression that the hull is typically made of an exterior aluminum skeleton followed by the insulation and finally the inner cabin wall. In this setup the main insulation effect will probably come from the insulating material. I expect the insulation to be at least as good as the ones used in modern buildings but I don't know how much of it is used - can you give me some examples of the width of the insulation please? Thank you in advance. Best regards Andreas |
I would be surprised if its nearly as good as what is in building
walls. The insulation on aircraft is much thiner (at least much thiner than the madated insulation for new buildings here in California). The insulation I've seen is between 1/2" and 1" thick compared to 5" or so that you see in modern buildings. -Robert |
Thanks for you reply.
That is surprising! Is it your impression that this applies to most (commercial) airplanes? If not, can you give me an example of an airplane with an insulation thickness like that? Best regards Andreas |
Airplanes that fly at 10000 meters have jet engines that
heat air as a function of just running [ P3 or bleed air] to temperatures above 1,000 F. This highly compressed hot air is manipulated and used for heating and cooling. The use of insulation is limited because of weight and to an extent because of bulk. Airplanes will have 1/4 to 1/2 inch (6mm-13 mm) of a fireproof material. Sound as well as heat insulation are functions of the material. Aircraft ventilation causes a complete change of cabin air every 5-10 minutes, so insulation is not a function, they just dump 100,000s of BTU into the cabin. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Andreas Warberg" wrote in message oups.com... | Thanks for you reply. | | That is surprising! | Is it your impression that this applies to most (commercial) airplanes? | If not, can you give me an example of an airplane with an insulation | thickness like that? | | Best regards | Andreas | |
At least for most General Aviation aorcraft, the primary purpose of fuselage
insulation is for sound deadening, not for heat loss. The insulation is typically closed cell foam, with some level of fire protectant. I suspect that what you will find of insulating value in most small aircraft will be (from inside out): 1. A liner - cloth or vinyl, often padded (maybe 1/4 inch thick) 2. Then maybe one inch of air space 3. Then 1/2 inch insulation 4. Then exterior aluminum (or fabric) MUCH less insulating capability than a modern building. I think you will find a much higher level of insulation in larger aircraft, but again, not likely approaching a building "Robert M. Gary" wrote in message oups.com... I would be surprised if its nearly as good as what is in building walls. The insulation on aircraft is much thiner (at least much thiner than the madated insulation for new buildings here in California). The insulation I've seen is between 1/2" and 1" thick compared to 5" or so that you see in modern buildings. -Robert |
"Andreas Warberg" wrote:
It is my impression that the hull is typically made of an exterior aluminum skeleton followed by the insulation and finally the inner cabin wall. In this setup the main insulation effect will probably come from the insulating material. I expect the insulation to be at least as good as the ones used in modern buildings but I don't know how much of it is used - can you give me some examples of the width of the insulation please? This URL provides some fuselage design considerations: http://adg.stanford.edu/aa241/fusela...sesection.html This quote should get you in the ballpark (I presume you can assume the entire thickness contains insulation for the purpose of this assignment): "Finally, the fuselage frame, stringers, and insulation thickness must be added to determine the fuselage outer diameter. Typically, the outer diameter is about 8% larger than the cabin diameter." Also, it appears some McDonnell Douglas aircraft use metalized Mylar insulation. |
insulation. At least in the GA world most of us are getting rid of our old insulation for modern materals to avoid rust. The old insulation may hold moisture which will eat the plane. -Robert |
Crash In The Nolichucky | W P Dixon | Piloting | 2 | June 22nd 05 04:16 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
The Best Airplane | Veeduber | Home Built | 1 | February 13th 04 05:43 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
