I am back to pulling the warrior back into the hanger with a winch. I tried modifying a small briggs and stratton powered "mule" to the cherokee towbar attachment but could not get the control I wanted. So now, I need the experience of anyone else who has rigged up a winch with extended control. I have a Harbor Freight winch which will do just fine to pull a warrior up a slight incline but the switch which controls the direction of the spool has a 6 foot wire. I want to stand in front of the plane with the towbar in hand to do the guiding. This means I need something like a 50 foot extension to the switch control wire, doable but clumsy using a 4 conductor cable with #14 wires. I could rig up a smaller wire system with relays and transformers, etc but that gets even more clumsy and prone to failure. I have thought about standing in the hanger at the back of the plane and controling the winch with the exsisting setup but then I lose the steering option I have from the front. It should be mentioned that I have 8 inches outside of each wingtip to the i-beams. Easily doable but with a pucker factor component. I would like to hear from anyone who has a similar rigup and how suggestions to living with the system, especially if you have tought of something different. Thanks, Leo |
You need to do what my hanger neighbor did. He went down to the pawn shop
and bought an riding lawn mower for next to nothing. He had a tow bar mounted to the front and now uses it to both take his Beech 36 out of the hanger but to put it back in as well. The nice thing about it is he can still use it to mow the 10ft wide fire alley between the hangers. wrote in message ups.com... I am back to pulling the warrior back into the hanger with a winch. I tried modifying a small briggs and stratton powered "mule" to the cherokee towbar attachment but could not get the control I wanted. So now, I need the experience of anyone else who has rigged up a winch with extended control. I have a Harbor Freight winch which will do just fine to pull a warrior up a slight incline but the switch which controls the direction of the spool has a 6 foot wire. I want to stand in front of the plane with the towbar in hand to do the guiding. This means I need something like a 50 foot extension to the switch control wire, doable but clumsy using a 4 conductor cable with #14 wires. I could rig up a smaller wire system with relays and transformers, etc but that gets even more clumsy and prone to failure. I have thought about standing in the hanger at the back of the plane and controling the winch with the exsisting setup but then I lose the steering option I have from the front. It should be mentioned that I have 8 inches outside of each wingtip to the i-beams. Easily doable but with a pucker factor component. I would like to hear from anyone who has a similar rigup and how suggestions to living with the system, especially if you have tought of something different. Thanks, Leo |
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message ... You need to do what my hanger neighbor did. He went down to the pawn shop and bought an riding lawn mower for next to nothing. He had a tow bar mounted to the front and now uses it to both take his Beech 36 out of the hanger but to put it back in as well. The nice thing about it is he can still use it to mow the 10ft wide fire alley between the hangers. The eight of us in the hangar row have a similar set up (we share a lawn tractor..."donated" by a gentleman that bought a fancy schmantzy new one) but it doesn't do too well on snow and ice. |
NRP: Sorry I didn't answer all your question. The winch is Harbor
Freight's "440 lb capacity electric hoist, # 40765-vga". Leo |
| Winch operations | Edward Winchester | Soaring | 7 | April 13th 06 12:24 PM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
