Fine example of Tarver Engineering release for service
Old February 26th 04, 03:31 AM
running with scissors
Default Fine example of Tarver Engineering release for service
A fine example of the quality results of Tarver Engineering work. As
singed off by John Tarver with applicable 8130.
http://www.aart-jan.net/images/aart_...egtuigwrak.jpg
photograph courtesy of Aart-Jan, (its not tarver in the pic, it's
Aart's father inspecting the fine work completed by John "the splap"
Tarver).
Old February 26th 04, 06:23 AM
Tarver Engineering
"running with losers" wrote in
message om...
"Tarver Engineering" wrote:
"Gord Beaman" wrote in message
"Jim Knoyle" wrote:
Hang on here a second now Jim, you still need two samples. As Dan
says you need 'static pressure' to read the altitude from and you
need 'pitot pressure' (ram air pressure) as well as the static
pressure to derive the airspeed reading from. Sounds like you're
saying that you can read 'both' from just the 'ram air pressure'
alone. Or did I misunderstand you?
Jim has finally figued out what a pitot tube is, but somehow he still wants
to be correct in his archive troll. It is a great paradox.
I know...ain't life a bitch John
-Gord.
Old February 26th 04, 04:56 PM
fudog50
Ummm,
I performed dozens of the old FAR 91.171 (pitot/static annual
checks) and 91.172 (mode 'C' checks) in the early 90's on Pipers,
Cessna, Grumman, Lanceair, Beech, you name it. Also performed all the
calibration and repair necessary, (the lines, indicators, ports, pitot
tubes, etc.) I worked a part time job at a GA avionics shop at Palo
Alto.
IIRC, the only indicator that had both pitot and static inputs
was the VSI/Rate of climb indicator and the internal bellows in the
gauge performed the differential action. Airspeed has pitot inputs
only. Baro Alt. has static port input only. Wish I could draw you a
diagram on here, it would explain everything.
On Wed, 25 Feb 2004 22:23:23 -0800, "Tarver Engineering"
message om...
Old February 26th 04, 05:58 PM
Tarver Engineering
"fudog50" wrote in message
only.
Fascinating, tell us more.
Old February 26th 04, 06:59 PM
Jim Knoyle
message om...
wants
Ummm,
Alto.
Since posting rubbish like he posted below, no amount of diagrams
have helped. It's a case of "That's my story and I'm sticking to it!"
Revealing that in my 37 years up the road at SFO I had done easily
hundreds of low range pitot/static leak tests resulting in the replacement
of dozens of pitot tubes/probes/masts or whatever Tarver wants to
call those pointy things up front, only brought about months of fraud
claims and all of the other bits splaps is well known for.
Requoting Gord's question to me out of context is only his latest.
Pt *still* equals (altitude pressure) + (impact pressure).
JK
http://home.att.net/~j.knoyle/the_ta...hronicles.html
GREAT MOMENTS IN ADA:
"That is the case with all modern transports Gord. Pitot tubes are only
used
for flight test back up instrumentation for modern transports; pitot tubes
have a nasty habbit of atracting mud bees and are therefore not reliable
enough for revenue these past few decades."
-- John Tarver, Skylight Avionics, December 26, 2001
Old February 26th 04, 09:06 PM
Robert Moore
Ummmm.....I think that you definately DO NOT recall correctly!
Static Pressure feeds Altimeter, Airspeed, and VSI.
Pitot Pressure feeds only Airspeed.
The Pitot Pressure from the Pitot Tube is a combination of Static
and RAM pressure. The bellows inside the airspeed indicator
uses the ambient static pressure from the static port to cancel
out the static component from the Pitot Tube leaving only the RAM
component to move the airspeed needle.
Bob Moore
Old February 26th 04, 09:23 PM
Tarver Engineering
"Robert Moore" wrote in message
. 7...
and RAM pressure.
You remember wrong, as usual, Bob.
IAS is one pressure subtracted from the other.
Since the 1960s, large airliners have used a pitot port and a static port.
The Bombardier GBX being a notable exception to modern pitot/static systems,
with it's prominent nose boom and pitot tube.
Old February 27th 04, 03:21 AM
Phil Miller
On Thu, 26 Feb 2004 13:23:52 -0800, "Tarver Engineering"
.7...
and RAM pressure.
Which is exactly what Robert said in the bit you snipped. To wit:
"The bellows inside the airspeed indicator uses the ambient static
pressure from the static port to cancel out the static component from
the Pitot Tube leaving only the RAM component to move the airspeed
needle."
Please provide one reference for this.
Ok...So a pitot tube only exists on a nose boom?
And Bombardier GBX? Are you referring to the Bombardier Global Express?
It's the closest I can find on their web site. If so I can't see a
prominent nose boom in the pictures there. Car to enlighten me?
Phil
Great Tarverisms #7
Pitot: French word meaning tube.
John
alt.disasters.aviation
25 February 2002
Old February 27th 04, 07:06 PM
Bob Moore
Of course...exactly...not rocket science after all...
-Gord.
Old February 27th 04, 07:12 PM
Tarver Engineering
Not even close. Moore is making the same dumbass claim as Knoyle.
The sole reason for using a static port is so the guts can be removed from
the pitot tube, in order to improve reliability. A pitot port produces no
static pressure datum.
Perhaps this will help:
-Gord.
