Are TSO Instruments required in certificated aircraft? Altimeter,
airspeed , anything..... If yes, where is this specified? I've looked in the FARs and haven't been able to find this yet. Any help would be appreciated. Thanks |
The key words are "not for hire." For a part 91 aircraft (i.e. most of
us here) operating not for hire (i.e. not carrying passengers or cargo for pay) there is very little TSO requirement. I know the transponder must be TSO'd (although the transponder itself is not absolutely required). I was thinking that there is another piece of avionics that requires a TSO, but if there is, I can't recall it at the moment. All the regular stuff (radios, headsets, etc.) do not. When you get into aircraft operating "for hire" (which does NOT include the C-172 you rent at the local FBO) then TSO is required for a lot of the equipment. Otherwise the ONLY advantage to a TSO approval is that it is automatically "data acceptable to the administrator" and may make the STC a bit easier to get if you are putting something unusual into your plane. |
jmk wrote: ...I was thinking that there is another piece of avionics that requires a TSO, but if there is, I can't recall it at the moment. All the regular stuff (radios, headsets, etc.) do not. ELT? |
"mikem" wrote in message oups.com... jmk wrote: ...I was thinking that there is another piece of avionics that requires a TSO, but if there is, I can't recall it at the moment. All the regular stuff (radios, headsets, etc.) do not. ELT? Sort of. You need to read the fine print. Generally, TSOs are not required, except for IFR-approved GPS receivers. The three "gray-area" items are ELTs, altitude encoders, and transponders. The rules require they must "meet the requirements" of the specific TSO. So you can use one of these without a TSO, but the onus is on you to convince the FAA that they meet the TSO requirements. The TSO is "approved data" that shows the compliance. So in the end, it's a lot easier to just buy TSO'd versions of these items. Gerry |
airspeed , anything..... Not unless it's used in operations for hire (rentals and instruction don't count). The problem is, if they're not TSO'd, on what basis are you installing them? To be installed as an aircraft part, whatever you are installing must be a standard part (not applicable to instruments - we're talking hardware, wire, etc.), a TSO'd part, a TC'd/STC'd part, a PMA'd part, or a part manufactured by the owner-operator. Otherwise it's not an aircraft part, and will require a field approval. So let's say you want to install a non-TSO'd altimeter, radio, whatever into your certificated airplane. Sometimes it's easy. Let's say you want to install a KX-170B. It's not TSO'd. But it's manufactured as an aircraft part, with FAA authorization. No problem. Or let's say it's a Magellan 5000 VFR GPS. It has (believe it or not) a Beech PMA. No TSO, but no problem either. It's an aircraft part, the installation is considered a minor alteration these days (at least in some FSDO's), so no worries. But what if it's not? What if the manufacturer has no authorization from the FAA of any kind? Not going to happen. Can't install it. Not unless you get an STC or field approval. Michael |
Michael wrote:
The problem is, if they're not TSO'd, on what basis are you installing them? To be installed as an aircraft part, whatever you are installing must be a standard part (not applicable to instruments - we're talking hardware, wire, etc.), a TSO'd part, a TC'd/STC'd part, a PMA'd part, or a part manufactured by the owner-operator. Otherwise it's not an aircraft part, and will require a field approval.' A TSO isn't approval for isntallation in itself. While my IFR GPS meets the TSO, I also have an STC to cover it's installation in my aircraft. A TSO is just an statement that it meets certain technical standards on which further approvals can be based. |
That is true only for major repairs/alterations. For minor repairs/alterations, a TSO is approval, since it constitutes data acceptable to the administrator. Michael |
Michael wrote:
A TSO isn't approval for isntallation in itself. That is true only for major repairs/alterations. For minor repairs/alterations, a TSO is approval, since it constitutes data acceptable to the administrator. "Data acceptable to the administrator" isn't necessary for things that aren't major alterations. That phrase comes from the major alteration framework. The fact that it is a non-major alteration implies you've used something consistant with the original aircraft design. If the TSO helps you make that decision great, but it's still not installation approval. |
The way I understand the TSO process is that it is a "quality" process
in manufacturing. Kind of like ISO in the non FAA world. It doesn't mean whether or not an item can be installed in a aircraft, but that the manufacture of the part is according to a particular process acceptable to the FAA. I don't think that it makes any difference if the part can be or can't be installed in an aircraft just because it has the TSO label. It allows the FAA to be confident the part is acceptable for installation if they approve it. It's all clear as mud as I see it. I think that you still need a STC or field approval to install a AM/FM CD player whether its TSO'd or not, but the FAA won't have many questions about the player if it is a TSO'd item. Dave Ron Natalie wrote: Michael wrote: A TSO isn't approval for isntallation in itself. That is true only for major repairs/alterations. For minor repairs/alterations, a TSO is approval, since it constitutes data acceptable to the administrator. "Data acceptable to the administrator" isn't necessary for things that aren't major alterations. That phrase comes from the major alteration framework. The fact that it is a non-major alteration implies you've used something consistant with the original aircraft design. If the TSO helps you make that decision great, but it's still not installation approval. |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Minimum Instruments Required? | John A. Landry | Home Built | 5 | October 15th 05 12:27 AM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 28th 04 12:49 AM |
