Piper SB1161/rib replacement update
Old April 29th 06, 11:34 PM posted to rec.aviation.owning
Default Piper SB1161/rib replacement update
Updated pictures he
http://s66.photobucket.com/albums/h2...ardrider/Ribs/
Right wing is done. Left wing top rivet work is done and bottom rivet
work is in progress. Should be airworthy before the end of next week.
GNS-430 is back from Garmin (had to comply with an AD and get a hardware
& software update done).
Cheapest part installed on the plane to date: $6 luggage door strap from
Ground Tech. Has absolutely nothing to do with the rib repair...but
it's nice to know that not *everything* costs an arm and a leg. Well,
ok, nearly everything...but at least not a luggage door strap.
Jack Allison
PP-ASEL-Instrument Airplane
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old April 29th 06, 11:43 PM posted to rec.aviation.owning
You bought a luggage door strap?
Mary cut the little latchy thing out of our old grody one, inserted
said latchy thing into a piece of rip-stop nylon strap she had laying
around her sewing room, and I screwed it the other end into place.
Cost: Priceless! :-)
(Did you see they now make a gas piston opener for our luggage door?)
Jay Honeck
Iowa City, iA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 30th 06, 02:56 AM posted to rec.aviation.owning
Yes, I did. $6 from Ground Tech. Cheap cheap! Well, ok, not as cheap
as Mary and her sewing expertise but when you factor in that it took me
a whopping 10 minutes of my time (5 noodling around their website, 5
more on the phone with them)...it's pretty hard to beat.
But is it a PMA part? :-)
Yes. Very cool but, IMHO, very over priced. IIRC, something like .179
AMU. Cool but I'll take the $6 strap
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old April 30th 06, 02:03 AM posted to rec.aviation.owning
Keep puttering on the "little things", it'll keep your mind off the big
things.
They should have at least had the heart to send a free box of Kleenex when
they sold you those ribs. Maximum royal suckage.
Glad it's coming together.
Old April 30th 06, 03:04 AM posted to rec.aviation.owning
That's ok, I can always drown my sorrows in free coffee and donuts at
the shop on Saturday mornings.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old April 30th 06, 12:21 AM posted to rec.aviation.owning
How many AMU's is all this going to set you back Jack? Sounds salty....
I am crossing my fingers that the 9 AMU annual of last year dosn
repeat itself next month for annual # 2 (please no flames about the
difference between an annual as most of us refer to it as, and the
technical annual inspection).
Jon Kraus
'79 201
4443H @ TYQ
Jack Allison wrote:
Updated pictures he
Old April 30th 06, 03:00 AM posted to rec.aviation.owning
Estimate was 50-70 hours labor at $70/hr. Parts were 1.2 AMUs. Do the
math and it's just south of 5 AMUs on the low side. We don't like to
think about the high side. The labor estimate was purposely high as the
shop doesn't like to overrun. One nice thing is that they didn't track
the number of hours on the right wing as they had extra learning curve
time to deal with. They're going to take the number of hours for the
left wing (which is taking much less time) and double it. I'll be sure
to post the final AMU amount. Kleenex gladly accepted.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old April 30th 06, 02:20 PM posted to rec.aviation.owning
I was thinking it woulod be in the 5 AMU range (just a guess)... It
sounds like the shop is being fair to you and that is good.. The last
fuel tank repair we had a new shop make they ran WAY over their estimate
of hours but still honored their original amount. We appreciated that
and will take 43H there for our next annual.
On a good not 5 AMU's divided by 3 is a lot easier to choke down than a
sole ownership would be. :-)
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Old April 30th 06, 01:17 AM posted to rec.aviation.owning
On Sat, 29 Apr 2006 15:34:26 -0700, Jack Allison wrote:
Updated pictures he
Dayem Jack,
This hurts just looking at the pictures!
Hope you get 'er up and flying soon! Will there be rigging adjustments
need to be done after your first beta flight?
Allen
Old April 30th 06, 03:02 AM posted to rec.aviation.owning
Updated pictures he
Dayem Jack,
Yep, it's pretty sad to see how many rivets needed to be drilled out.
Felt like a kit builder's nightmare.
Probably. The plane was slightly out of rig and we were going to
address that while it was down for the annual. We'll test fly and see
how any normal (as in part of the annual) control cable tension
adjustments may or may not have addressed the issue and go from there.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Piper SB No 836 (alluminum wire replacement) Mike Noel Owning 11 August 3rd 05 08:05 AM
Rogue's Gallery Update -- Talk about diversity! Jay Honeck Home Built 52 May 11th 05 05:18 PM
Rogue's Gallery Update -- Talk about diversity! Jay Honeck Owning 51 May 11th 05 05:18 PM
Rogue's Gallery Update -- Talk about diversity! Jay Honeck Piloting 52 May 11th 05 05:18 PM
replacement rotating beacon for 64 piper cherokee Patrick Mathews Owning 2 October 1st 03 01:55 PM
