There's a NOTAM out for KSAC ILS-2 which states that the following
note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? Thanks, -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "Mark Hansen" wrote in message ... There's a NOTAM out for KSAC ILS-2 which states that the following note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? There are two current NOTAMs for SAC. The one you mentioned, and one showing the VOR unserviceable. Without the VOR an ADF is needed for the missed approach. |
On 05/02/06 17:14, Steven P. McNicoll wrote:
"Mark Hansen" wrote in message ... There's a NOTAM out for KSAC ILS-2 which states that the following note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? There are two current NOTAMs for SAC. The one you mentioned, and one showing the VOR unserviceable. Without the VOR an ADF is needed for the missed approach. Thanks Stephen. The VOR being OTS is temporary. It will be out from 9:00AM to 4:00PM on Wednesday (local time). I was under the impression that the change to the SIAP was permanent... Because it was done via an FDC NOTAM. Perhaps I'm off base there? They said it was AMDT 22C. So will they then come out with an AMDT 22D which says to remove the note? I just didn't think they would make a permanent change (FDC) to the SAIP for a temporary condition. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "Mark Hansen" wrote in message ... The VOR being OTS is temporary. It will be out from 9:00AM to 4:00PM on Wednesday (local time). I was under the impression that the change to the SIAP was permanent... Because it was done via an FDC NOTAM. Perhaps I'm off base there? They said it was AMDT 22C. The NOTAM says "WIE UNTIL UFN", With Immediate Effect Until Further Notice. It may not be pernanent. So will they then come out with an AMDT 22D which says to remove the note? I just didn't think they would make a permanent change (FDC) to the SAIP for a temporary condition. Once you've spent a few years reading these things you stop trying to find any logic in them. The VOR outage justifies the amendment to the IAP, but it's possible they're unrelated. |
Mark Hansen wrote:
On 05/02/06 17:14, Steven P. McNicoll wrote: "Mark Hansen" wrote in message ... There's a NOTAM out for KSAC ILS-2 which states that the following note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? There are two current NOTAMs for SAC. The one you mentioned, and one showing the VOR unserviceable. Without the VOR an ADF is needed for the missed approach. Thanks Stephen. The VOR being OTS is temporary. It will be out from 9:00AM to 4:00PM on Wednesday (local time). I was under the impression that the change to the SIAP was permanent... Because it was done via an FDC NOTAM. Perhaps I'm off base there? They said it was AMDT 22C. So will they then come out with an AMDT 22D which says to remove the note? I just didn't think they would make a permanent change (FDC) to the SAIP for a temporary condition. They don't issue Permanent FDC NOTAMS (which is what one is when it amends the procedure from 22B to 22C). They will sometimes issue a temporary FDC NOTAM for a facility outage, but never for one day. These NOTAMS are geared to NACO charts. NACO cannot chart a T FDC NOTAM. They must chart a P FDC NOTAM. |
On 05/02/06 18:57, Mark Hansen wrote:
On 05/02/06 17:14, Steven P. McNicoll wrote: "Mark Hansen" wrote in message ... There's a NOTAM out for KSAC ILS-2 which states that the following note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? There are two current NOTAMs for SAC. The one you mentioned, and one showing the VOR unserviceable. Without the VOR an ADF is needed for the missed approach. Thanks Stephen. Oh ... rats. I meant "Steven", of course. Sorry about that. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
There's a NOTAM out for KSAC ILS-2 which states that the following note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? Thanks, ADF is required for the transition from COUPS. |
On 05/03/06 06:19, Sam Spade wrote:
Mark Hansen wrote: There's a NOTAM out for KSAC ILS-2 which states that the following note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? Thanks, ADF is required for the transition from COUPS. That's interesting. In all the times I've flown that in training, I think we've always just used the localizer. However, in looking at the chart now, the feeder route says "1400 NoPT 015 TO LOM". However, if you're coming in from COUPS, wouldn't you be on the localizer before you get to the LOM? After all, by this point, you're already on the GS. Why would anyone fly the ADF to the LOM on this approach? Also, what changed such that the ADF is required now, and wasn't before? Was it always required, but the chart just didn't say so, and they are now correcting that? Thanks, -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
On 05/03/06 06:19, Sam Spade wrote: Mark Hansen wrote: There's a NOTAM out for KSAC ILS-2 which states that the following note should be added to the planview: "ADF Required". Why is ADF required for this IAP? The marker beacon should tell you when you're over the LOM, and the missed approach procedure says you need to hold at the VOR or the NDB. Is there some requirement for the use of the ADF which I'm not seeing? Thanks, ADF is required for the transition from COUPS. That's interesting. In all the times I've flown that in training, I think we've always just used the localizer. However, in looking at the chart now, the feeder route says "1400 NoPT 015 TO LOM". However, if you're coming in from COUPS, wouldn't you be on the localizer before you get to the LOM? After all, by this point, you're already on the GS. Why would anyone fly the ADF to the LOM on this approach? Also, what changed such that the ADF is required now, and wasn't before? Was it always required, but the chart just didn't say so, and they are now correcting that? Thanks, There is a lot of subjectivity in procedure design. According to my source, and I quote: "This is one of those old ILS procedures done by some of our old pilot/developers years ago. The in NoPT route goes to the LOM, one reason for ADF required, and the procedure was generating too many questions. We have it on the list to fix." |
![]() Sam Spade wrote: There is a lot of subjectivity in procedure design. According to my source, and I quote: "This is one of those old ILS procedures done by some of our old pilot/developers years ago. The in NoPT route goes to the LOM, one reason for ADF required, and the procedure was generating too many questions. We have it on the list to fix." The ADF Required note now appears in the published procedure updated May 11. So why doesn't it say ADF or RADAR required? Why can't you get vectors to final and shoot this approach without an ADF (assuming the VOR is in service)? Peter |
tailwheel endorsement | Jose | Piloting | 65 | April 27th 06 01:59 AM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
