IFR GPS replace DME / ADF?
Old May 7th 06, 01:35 AM posted to rec.aviation.ifr
Default IFR GPS replace DME / ADF?
Hello,
I'm new to IFR and just learning... if our plane doesn't have an ADF or
a DME... can we legally use, say a garmin 430, to do a NDB approach?
Also, can these garmin 430/480/530 units get you the DME?
Also, are RNAVs still used often?
Thanks,
-dr
Old May 7th 06, 02:00 AM posted to rec.aviation.ifr
An IFR certifed GPS can replace a NDB or DME waypoint or fix, but you can
not use it to do an NDB or DME arc approach. That being said, there will
probably be aGPS approach similar to the NDB approach at whatever airport
you go to.
The GARMIN 430/530/480 can get you a distance to a waypoint that will be
very close to a DME distance (remember DME measures slant height, GPS
measures lateral distance)
A NON IFR GPS can NOT legaly replace a NDB or DME fix.
RNAV's are still used. There are a lot of installed KNS-80's out there
Hope that helps.
Ian
Hello,
Thanks,
-dr
Old May 7th 06, 02:03 AM posted to rec.aviation.ifr
Thanks Ian!
Old May 10th 06, 02:14 PM posted to rec.aviation.ifr
Hello everyone,
I just wanted to post that the Initial poster is using a canadian email
address and the rules in canada are a little bit different with regards
to the use of a GPS to fly a DME arc.
In Canada AIC 27/05 says:
6.0 Use of GNSS in Lieu of Ground-based Aids GNSS may be used to
identify all fixes defined by distance measuring equipment (DME), VOR,
VOR/DME and NDB, including fixes that are part of any instrument
approach procedure, to navigate to and from these fixes along specific
tracks, including arcs, and to report distances along airways or tracks
for separation purposes, subject to the following conditions:
Regards,
If you are looking for canadian rules, I strongly suggest that you
refer to Transport Canada website.
Old May 11th 06, 02:29 AM posted to rec.aviation.ifr
Thanks!
Old May 8th 06, 02:00 PM posted to rec.aviation.ifr
Newps wrote:
Why not? If you'll go direct with a handheld then why not shoot an NDB
approach with an IFR certified panel mount GPS such as a 430?
For one reason, the approach won't be in the GPS database.
We should replace planes with tie-fighters !!! Dan Simper Naval Aviation 5 February 6th 05 06:20 PM
Help! rebuild or replace Stamo engine In Falke? Ian Walton Soaring 2 September 5th 04 07:02 AM
Replace (Fix) ADF? Tom Nery Owning 32 November 3rd 03 03:30 PM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 09:41 AM
best source to replace missing cowl fastener Craig Owning 5 August 25th 03 08:07 PM
