Best Glide / Rate of Descent
Old May 9th 06, 09:29 PM posted to rec.aviation.piloting
Default Best Glide / Rate of Descent
With the throttle at idle, and plane trimmed for best glide, what is
your plane's descent rate (in fpm)?
I tried this with my Cherokee 180 and found the resulting descent to
be somewhere between 900 and 1000fpm. (This was measured on the VSI,
not via altimeter plus stopwatch, so it is prone to error).
Varying the glide airspeed 5 or 10 mile an hour did not make a big
change in the descent rat, probably 50fpm or so.
Anyone tried the same?
Old May 9th 06, 10:13 PM posted to rec.aviation.piloting
With an MD-80 use Gross Weight plus 100 kts. If you weighed 120,000#, fly
220 knots for best glide ratio.
Darrell R. Schmidt
B-58 Hustler History: (see below)
http://members.cox.net/dschmidt1/
"Nathan Young" wrote in message
Old May 9th 06, 10:19 PM posted to rec.aviation.piloting
Having crashed both, I can definitively state that a C-210 sinks at roughly 700
fpm cleaned up and a Piper Lance comes down at 1100 fpm in the same situation.
While the extra cabin space is nice, the Cherokees are definitely lead sleds
when it comes to power off descents.
Mortimer Schnerd, RN
VE
Old May 11th 06, 12:51 PM posted to rec.aviation.piloting
My Beech 23 is easily out glided with the power off by a comparable
PA-28, so that must make the Beech a super lead sled. G
Old May 11th 06, 03:10 PM posted to rec.aviation.piloting
The short winged Cherokee and Musketeers don't glide as well
as the newer -151 Piper versions.
"B A R R Y" wrote in message
om...
comparable
Old May 9th 06, 10:23 PM posted to rec.aviation.piloting
Did you read Barry Schiff's article on this subject in the May AOPA PILOT?
Bob Gardner
Old May 10th 06, 03:03 AM posted to rec.aviation.piloting
On Tue, 9 May 2006 14:23:16 -0700, "Bob Gardner"
Yep, that's what reminded me that I wanted to post my findings. ( I
had flown the test descents about two weeks ago).
-Nathan
Old May 10th 06, 01:03 AM posted to rec.aviation.piloting
note that: i) the best glide *speed* as indicated in your POH is
given at gross weight; i.e., sticking to this *speed* all alone
with less than full tanks, etc., i.e., lighter, will not work
as well as advertised; and ii) best glide speed does NOT give you
minimum sink.
--Sylvain
Old May 10th 06, 02:37 AM posted to rec.aviation.piloting
Nathan Young opined
I got about the same results with a 172.
-ash
Cthulhu in 2005!
Why wait for nature?
ASW19b best descent rate on approach (full airbrakes) Robert Sharpe Soaring 1 April 30th 05 11:41 AM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
