![]() I have the current Jepp LO 47 chart and there's something odd around the SEG (Sellinsgrove) VOR (just north of HAR). The MEAs around the VOR are in the 4000' range, except for V106 to RASHE, which is 14000'. I sent a note to Jepp querying this. They claim it's correct, based on navaid reception. I still find this hard to swallow. 14,000??? C'mon. And if so, why isn't there a MOCA for the segment? There's a 6000 MEA / 3900T for the next segment. Anyone have a NOAA chart? Does it have the same MEA? Anyone know the MVA for the area? Anyone have a topo/sectional map of the area to explain the mysterious navaid reception issue? Morris (who cannot be the first person to have noticed this) |
Journeyman wrote:
I have the current Jepp LO 47 chart and there's something odd around the SEG (Sellinsgrove) VOR (just north of HAR). The MEAs around the VOR are in the 4000' range, except for V106 to RASHE, which is 14000'. I sent a note to Jepp querying this. They claim it's correct, based on navaid reception. I still find this hard to swallow. 14,000??? C'mon. And if so, why isn't there a MOCA for the segment? There's a 6000 MEA / 3900T for the next segment. Anyone have a NOAA chart? Does it have the same MEA? Anyone know the MVA for the area? Anyone have a topo/sectional map of the area to explain the mysterious navaid reception issue? Morris (who cannot be the first person to have noticed this) Same on the NOAA chart. Knowing the terrain I would agree it has to be a mistake. |
![]() I've noticed it, and I've flown that segment way below 14K (albeit /G) so I've no idea what's going on. There is a ridge that might block reception on the south edge of the airway, so perhaps that's the issue given how close the VOR is to start of the ridge... |
In article .com, Mike Granby wrote:
There is a ridge that might block reception on the south edge of the airway, so perhaps that's the issue given how close the VOR is to start of the ridge... That must be it. Thanks for all the replies. Morris |
Similarly, there's one from Madison, Wisconsin to Chicago with something
like a 10,000 MEA. The best I can tell is that there's one hill in the flats of Wisconsin that limits the signal, but it's not obvious. Journeyman wrote: I have the current Jepp LO 47 chart and there's something odd around the SEG (Sellinsgrove) VOR (just north of HAR). The MEAs around the VOR are in the 4000' range, except for V106 to RASHE, which is 14000'. I sent a note to Jepp querying this. They claim it's correct, based on navaid reception. I still find this hard to swallow. 14,000??? C'mon. And if so, why isn't there a MOCA for the segment? There's a 6000 MEA / 3900T for the next segment. Anyone have a NOAA chart? Does it have the same MEA? Anyone know the MVA for the area? Anyone have a topo/sectional map of the area to explain the mysterious navaid reception issue? Morris (who cannot be the first person to have noticed this) |
The sectional chart may help, but you can find the law that
establishes an airway, each one has a public statement. In that discussion you will find many answers. If you want to see real odd altitudes, look around Key West for the safe quadrangle altitude, it is about 14,000 last time I looked. Why? Because they sometimes have a tethered balloon and radar up looking at the drug smugglers. "David Kazdan" wrote in message . com... | Similarly, there's one from Madison, Wisconsin to Chicago with something | like a 10,000 MEA. The best I can tell is that there's one hill in the | flats of Wisconsin that limits the signal, but it's not obvious. | | Journeyman wrote: | I have the current Jepp LO 47 chart and there's something odd around | the SEG (Sellinsgrove) VOR (just north of HAR). The MEAs around the | VOR are in the 4000' range, except for V106 to RASHE, which is 14000'. | | I sent a note to Jepp querying this. They claim it's correct, based | on navaid reception. I still find this hard to swallow. 14,000??? | C'mon. And if so, why isn't there a MOCA for the segment? There's | a 6000 MEA / 3900T for the next segment. | | Anyone have a NOAA chart? Does it have the same MEA? Anyone know | the MVA for the area? Anyone have a topo/sectional map of the area | to explain the mysterious navaid reception issue? | | Morris (who cannot be the first person to have noticed this) |
In article f989g.18838$ZW3.12367@dukeread04,
says... Why? Because they sometimes have a tethered balloon and radar up looking at the drug smugglers. Yes, but that's different from reception issues. I think Mike's answer is probably closer - because the VOR is close to the ridge, that gives rise to some seemingly wierd MEA's, without anything untoward inthe MOCA. Puts a kink in your plans though, if you weren't planning (or cannot do) 14000. GF |
Greg Farris wrote: In article f989g.18838$ZW3.12367@dukeread04, says... Why? Because they sometimes have a tethered balloon and radar up looking at the drug smugglers. Yes, but that's different from reception issues. I think Mike's answer is probably closer - because the VOR is close to the ridge, that gives rise to some seemingly wierd MEA's, without anything untoward inthe MOCA. Puts a kink in your plans though, if you weren't planning (or cannot do) 14000. GF Take a look at some of the airways in western CT based on the LGA VOR. The MEA's make no sense based on terrain alone. I'm told the problem is that the VOR is nestled in among the hangars and other buildings and the signal suffers. |
Journeyman wrote:
I have the current Jepp LO 47 chart and there's something odd around the SEG (Sellinsgrove) VOR (just north of HAR). The MEAs around the VOR are in the 4000' range, except for V106 to RASHE, which is 14000'. /snip/ You wanna see something really wild? Go to http://idisk.mac.com/scottdb-Public and look at the "HiMEA" file. Right in the middle, the transitional MEA for V462 is listed as 88000 between FAGIN and NONDA. This obviously should be 8800, but I don't think it is just a typo on Jepp's part. When our company's flight planning software generates a low altitude route through this area, it actually bypasses that one segment, since our planes can't climb that high. Makes me think that the data is bad from the FAA. Happy Flying! Scott Skylane |
Scott Skylane wrote:
You wanna see something really wild? Go to http://idisk.mac.com/scottdb-Public Wish I could, but you don't like my browser. and look at the "HiMEA" file. Right in the middle, the transitional MEA for V462 is listed as 88000 between FAGIN and NONDA. This obviously should be 8800, but I don't think it is just a typo on Jepp's part. When our company's flight planning software generates a low altitude route through this area, it actually bypasses that one segment, since our planes can't climb that high. Makes me think that the data is bad from the FAA. That's the Alaska airway V462, not the Federal airway V462, right? The ATA-100 AWY file effective June 08, 2006 shows a MOCA of 12200 and an MEA of 14000 between FAGIN and NONDA. |
Weather chart oddity? | Dylan Smith | Piloting | 8 | April 21st 06 04:47 PM |
EGT gage oddity; stuck valve, other?? | Bob Fry | General Aviation | 8 | January 11th 05 04:42 AM |
EGT gage oddity; stuck valve, other?? | Bob Fry | Owning | 5 | January 11th 05 04:42 AM |
