Nav 401L Test Set problem
Old May 20th 06, 08:21 PM posted to rec.aviation.piloting
Default Nav 401L Test Set problem
Sorry if this is the wrong group (probably!)
Please advise a more suitable group
I've got this test set, on the back is a mains socket, all the manuals I've
seen in the uk, show a uk socket. This one has six pins, (its the 110volt
version). It's not clear to me which pins are for which.
Top
Nav Sig
Tone O O Gen
Out Demod
_.-""""-._
/ \ Pwr
| __ __ __ | O Mon
| 1 2 3 | Demod
| __ __ __ |
\ 4 5 6 /
`._ _.'
It's these ones here, 6 is earthed, I think postive + is 5 and 1 (-)
is negative?
Hope this is clear, ascii art is not my strong point!
Old May 21st 06, 11:38 AM posted to rec.aviation.piloting
My guess is that someone replaced the standard socket with a different
one for a special purpose; such as using a large external battery for
extended field use. I know of one 401L modified that way.
Old May 21st 06, 03:39 PM posted to rec.aviation.piloting
manuals I've seen in the uk, show a uk socket. This one has six
pins, (its the 110volt version). It's not clear to me which pins are
for which.
Thanks for the information: I'm not so sure, the hole in the case and the
socket inside are perfectly made (no sign of anything having been altered)
If you've interested I can send you a (small) photo if you send me an email
address (the one I'm posting from works)
TEST PILOTS ACCOUNT OF INFLITE BREAK UP (SR 71) (LONG) caleb Owning 1 January 30th 06 05:01 AM
drug/alcohol testing policy: effective? gatt Piloting 159 January 28th 05 06:19 AM
$2.5M awarded in age/racial bias suit against Boeing over test pilot job tango Piloting 2 November 29th 04 03:41 AM
Propeller for aircraft engine ground test Guy Deraspe Home Built 0 July 21st 04 04:41 AM
Air Force conducts live test of MOAB Otis Willie Military Aviation 0 November 21st 03 10:45 PM
