Say Altitude.
Old April 5th 04, 01:29 AM
Hankal
Default Say Altitude.
Long CX IFR at 7000
Controller comes on "say Altitude" My response "7000" He says you show 300
feet lower and gives me the altimer reading. I confirm. He says "turn off you
mod C"
I comply.Look at my GPS which is at 7060.
I go down 50 feet the gps stays at 7060. I go up 100 feet the gps stays at
7060.
The controller comes back and says" I think this is due to a cold front in my
flight area.
15 miles further my GPS altitude goes to 7000. I queery ATC to turn on my mod
C. He concurs my altitude at 7000.
Request lower for decend for landing. The gps works fine now, ATC is happy.
HAS ANYONE ELSE EVER EXPERINCED THIS?
Old April 5th 04, 01:50 AM
Bob Gardner
Many times. Glitches can occur with their software. My most common
experience was having one controller tell me to turn off the altitude
squawk, being handed off to another sector, asking the new controller if I
should try Mode C again and having no further problems. Don't sweat it. If
they don't like what they are seeing they will ask for verbal altitude
reports.
Bob Gardner
"Hankal" wrote in message
Long CX IFR at 7000
300
you
mod C"
7060.
my
flight area.
mod
happy.
Old April 5th 04, 04:58 AM
EDR
In article , Hankal
7060.
GPS altitude is only accurate to +/-150 feet.
It is a "rough" reference, not to be considered "precise".
Old April 5th 04, 06:51 PM
Bob Gardner
You're right. AIM 1-1-20(a)(8) tells us that we should not use GPS altitude.
When WAAS is in common use this will probably change.
Bob Gardner
"EDR" wrote in message
In article , Hankal
at
7060.
Old April 5th 04, 07:37 PM
Tarver Engineering
"Bob Gardner" wrote in message
news:R0hcc.78998$K91.171081@attbi_s02...
altitude.
The altitude error is part of the WGS-84 model and is not a WAAS issue any
longer. The CNX-80 provides VNAV capability through the use of pressure
altitude from a transponder source and the pilot's baro correction input;
married to a partial TAWS data base. GPS/WAAS is not likely to become an
acceptable substitute for pressure altitude. Larger airplanes use air data
derived pressure altitude in conjunction with GPS for improved RNP
capability.
Old April 6th 04, 12:09 AM
Bob Gardner
I think the whole WAAS thing is in flux. The AIM gets wordier and more
difficult to interpret with each change to its discussion of GPS. IMHO,
until there are a whole lot of WAAS capable boxes flying in the system we
will be flailing about in the dark.
Did you see the change to the AIM with regard to a reversed W on approach
plates? Doesn't create much confidence in the system.
Bob Gardner
"Tarver Engineering" wrote in message
altitude.
data
capability.
Old April 6th 04, 02:53 AM
Tarver Engineering
news:%Glcc.191812$_w.1879080@attbi_s53...
I believe that VDL will be more of a factor moving forward than WAAS will
be. FAA has spent a lot of money on space based WAAS while being in
posession of a lot of underused VHF bandwidth.
altitude.
any
input;
an
data
capability.
Old April 6th 04, 02:28 PM
You're right on. And, in an effort to sell LPV (WAAS) minimums, the friendlies
"tweaked" the VNAV missed approach criteria so that VNAV minimums will increase,
all to make WAAS look better.
Old April 6th 04, 01:46 AM
Hankal
I was not using the GPS for altitude. Always use the altimeter
The altimeter was showing 7000.
ATC was showing 6700
Gps was 7060. However when I changed altitude the gps stayed frozen at 7060.
Hank
Old April 6th 04, 02:11 AM
William W. Plummer
altitude.
7060.
Aren't controllers supposed to tell you to turn off your altimeter and go to
VFR when an error that big is detected?
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 03:29 PM
High Altitude operations (Turbo charge???) Andre Home Built 68 July 11th 03 11:59 PM
