I'm running a Lyc O-360. Anyone have any experience, good or bad with
any of the air/oil separators? My craft is certified, so I have to use one of the approved ones. $360 seems a little overpriced for about 5 bucks worth of material, but then I don't know what it cost them to get it approved. I'd like to run the full 8 quarts, and one of them claims you can with no oil loss. Thanks in advance. |
Doh. Don't everyone stay home from work answering my inquiry. Right
after I posted, I noticed the search feature at the top of the page and have plenty to read......unless you'd like to add something. I'm kind of leaning toward the M-20. According to their site, the rest are charlatans and their's is the only worthwhile one. But I guess my only STC's choices are it and the Walker.Airwolf. |
For the "other side" of the air/oil separator story read the short
editorial at http://www.sacskyranch.com/eng30.htm |
On 23 May 2006 05:20:22 -0700, "Kensandyeggo"
wrote: Doh. Don't everyone stay home from work answering my inquiry. Right after I posted, I noticed the search feature at the top of the page and have plenty to read......unless you'd like to add something. I'm kind of leaning toward the M-20. According to their site, the rest are charlatans and their's is the only worthwhile one. But I guess my only STC's choices are it and the Walker.Airwolf. I don't trust any company that talks down the competition. OTOH contrary to the site in a link listed on another post, the good ones do not put the crap back in the engine and they are almost a necessity if you have a wet pump which I do on the Deb. Nor do I need to see oil all over the bottom of the plane so I can spot an indication of problems. If you develop bad blow by it'll show up. Mine is a Deshanon which is about 6 inches in diameter and I'd guess about the same height. I'd have to go look at it to be sure. At any rate it works great and they were recommended by the ABS mechanic at one of their clinics. On 25 hour oil changes I do not have to add any oil. It will be down so little it's difficult to say it used any Get a good air/oil separator and I think you'll love it. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
I have an Lyc O-360 and run it at 7 qts. I add at 6. The only time I put
8 qts in is at oil change because of the filter and prop hub. Everything I have heard is that first qt of oil is lost overboard. I get about 12 hours per qt. The engine has about 300 hours on it. Ross KSWI Kensandyeggo wrote: I'm running a Lyc O-360. Anyone have any experience, good or bad with any of the air/oil separators? My craft is certified, so I have to use one of the approved ones. $360 seems a little overpriced for about 5 bucks worth of material, but then I don't know what it cost them to get it approved. I'd like to run the full 8 quarts, and one of them claims you can with no oil loss. Thanks in advance. |
Ross Richardson wrote:
I have an Lyc O-360 and run it at 7 qts. I add at 6. The only time I put 8 qts in is at oil change because of the filter and prop hub. Everything I have heard is that first qt of oil is lost overboard. I get about 12 hours per qt. The engine has about 300 hours on it. If you said the engine had 900 hours on it, I'd think you stole mine. G Who cares about flying with 8 qts.? Fill to 7, add @ 6. |
"Kensandyeggo" wrote: I'd like to run the full 8 quarts, Why? -- Dan C172RG at BFM |
Oh, I don't know......I guess I read or heard somewhere that it's best
to have full oil for best cooling and efficiency, but I'll run seven for now and add at 6. |
"Kensandyeggo" wrote: Oh, I don't know......I guess I read or heard somewhere that it's best to have full oil for best cooling and efficiency, but I'll run seven for now and add at 6. I found that even that was a little too much for my O-360. I add a quart when the level falls a notch below 6. -- Dan C-172RG at BFM |
| Air-Oil Separators | [email protected] | Owning | 5 | June 17th 05 04:13 PM |
| Air/Oil separator Best one for $ | Ron | Home Built | 1 | September 27th 04 01:10 AM |
| M20 Air/Oil Separator | tony roberts | Owning | 2 | September 8th 04 08:06 AM |
| FA: AIRWOLF WALKER AIR/OIL SEPARATOR AFC-W315 - NEW | Mike Ferrer | Aviation Marketplace | 0 | August 29th 04 02:56 AM |
| Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 06:56 PM |
