Medical running out?
Old May 27th 06, 05:48 PM posted to rec.aviation.piloting
Default Medical running out?
Went to get my medical early in the month because I knew it would have
to go through FAA channels due to a few small problems. Had all the
proper paper work and test reports filled out in advance and the
Medical Examiner took them to send everything in together. It's now
the end of the month and I get a letter from the FAA saying that they
didn't receive the extra paper work (I am certain my ME screwed up).
The letter says that 'This is not a denial but I have 30 days to send
the paper work before the application is denied'. My ME's office
says not to worry that even though my current medical runs out in
several days the letter gives me a 30 day grace period. This doesn't
sound right to me because the letter says the "application" will be
denied and mentions nothing about my current medical. Anyone have any
experience with this? Does this mean I have to keep the letter with me
in case of a ramp check? I think the ME is giving me a line of crap to
cover their screw up.
JF
Old May 27th 06, 06:55 PM posted to rec.aviation.piloting
Contact the regional medical examiner, contact the AOPA [you
are or should be a member] and follow up within the 30 days.
Sooner the better.
Did you keep copies of all the paperwork you took to the
AME?
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
it would have
Had all the
and the
It's now
saying that they
screwed up).
days to send
office
out in
This doesn't
Anyone have any
letter with me
line of crap to
| JF
Old May 27th 06, 08:35 PM posted to rec.aviation.piloting
The FAA "didn't receive" three consecutive sets of paperwork sent in by no
less than three of my doctors from three different clinics. In all three
instances the doctors were kind enough to give me copies of the required
documents which I then faxed to the FAA. Two of those documents were
received okay, but the FAA told me one fax was "garbled", but enough of the
document was received that they decided to continue my special issuance
anyway. I wouldn't blame your doctor if I was you.
Scott Wilson
Old May 28th 06, 12:02 AM posted to rec.aviation.piloting
I did (fortunatly) keep copies of everything and FAXed them directly to
the FAA doctor that asked for them, then called his office to confirm
they got it. Tuesday I will follow up to make sure it is all they
needed and or is clear enough.
The reason I suspect my ME is because one of the issues was LASIK
surgery. I had the surgeon fill out the required FAA report but when I
gave it to my ME he said it was for them to keep in their files (this
seemed strange to me but I assumed they knew what they were talking
about). The FAA sent me another blank eye form. I am guessing that the
original was still "on file" at my ME's office.
JF
Old May 28th 06, 03:11 AM posted to rec.aviation.piloting
Call out the OKC to the medical office. Depending on your situation they
can fax you an extension if possible or if done in time the actual
medical. I have not had AME problems but several times the timing and the
back log messed things up. The gals in the office were very helpful. Good
luck!
Ron
JF
Old May 28th 06, 11:58 AM posted to rec.aviation.piloting
Yes, I had a similar experience, though in my case the FAA simply
ignored the information the doc sent in. They gave me the 30 days, but
the penalty was not a denial but a special issuance medical.
I am inclined to suspect an FAA screwup, and I would interpret the
letter just as your ME does: you have 30 days FROM THE DATE ON THE
LETTER to provide the information (at least that's what my letter
said), and meanwhile you are good to fly.
You have your medical in your pocket, right? It's valid until the FAA
says it's not valid, which is at the end of the 30 day period of
grace.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Old May 28th 06, 03:19 PM posted to rec.aviation.piloting
grace.
Right, the medical is good until they specifically tell you it isn't.
The letter says that if you don't send them the paperwork in 30 days
they'll deny it (eventually sending you official notification of
that).
This is a big improvement from the way the used to was to not let
the doctor issue you the certificate, pending their review.
The 30 day scare is just to keep you from procrastinating too long.
CFI without commercial? Jay Honeck Piloting 75 December 8th 10 05:17 PM
Student Pilot Who Gets 5 Months for Lying on His Application for Medical [email protected] Home Built 2 June 30th 05 04:00 AM
Sport Pilot cuts off special issuance at the knees Juan~--~Jimenez Home Built 40 August 10th 04 02:19 PM
Question Medical Captain Wubba Piloting 5 June 11th 04 06:12 AM
Question on medical and kidney stones nospam Piloting 13 November 8th 03 08:10 AM
