Legality of a flight
Old May 30th 06, 03:50 AM posted to rec.aviation.piloting
Default Legality of a flight
Consider this scenario; Using FAA (USA) regulations.
A passenger wins a raffle prize or makes a donation to a charity, school
fund-raiser etc to win something. The winning item is an airplane
ride. The airplane ride is flown by a private pilot, who pays the
expense for the plane (rental, fuel, or time in her own plane). The
plane only lands at the same airport as it departs. In other words, the
passenger paid money, with the expectation of an airplane ride, although
the money isn't spent on the plane or pilot. Is this legal?
Change the scenario to the pilot has a commercial rating. Does this
change the answer to the question?
Finally, if the airplane ride is to a destination at another airport and
then returning (after a few hours, overnight, weekend etc.) How does
this change the answers?
Old May 30th 06, 04:04 AM posted to rec.aviation.piloting
"John" wrote in message ...
ride. [...] In other words, the
Yes.
No.
As far as I know, it doesn't. The key to the flight is the charitable
donation aspect, and I don't recall seeing any exclusion with respect to the
exact nature of the flight.
I have heard differing opinions from people with respect to whether their
local FSDO requires a drug test for such donations, but that's the only
complication I'm aware of.
Pete
Old May 30th 06, 04:51 AM posted to rec.aviation.piloting
The way I read the FARs, the private pilot needs to have 200 hours unless he
has a commercial rating. In addition, you need to go thru the AOPA waver to
avoid having to take the drug test. Finally, you have to land at the
originating airport and can't fly more than 25 miles from the originating
airport unless the aircraft is being operated by a 121 or 135 carrier.
Personally, I haven't done this yet, so it would be worth doing your own
detailed investigation of the FARs.
Mike Schumann
Yes.
No.
the exact nature of the flight.
Pete
Old May 30th 06, 10:15 PM posted to rec.aviation.piloting
"Mike Schumann" wrote in message
news:9jPeg.9452
he has a commercial rating. In addition, you need to go thru the AOPA
waver to avoid having to take the drug test.
Can somebody elaborate on this? I'm looking at the form right now, and it
says:
"Under FAA Exemption No. 7112D, the event sponsor must provide the AOPA
member-pilot with a statement indicating that neither the event sponsor nor
any participating pilot operating under this exemption has operated more
than four similar events during the calendar year."
So, if I read this correctly, IF YOU'RE AN AOPA member, you can fill out the
form and be exempted so long as the charity organization doesn't conduct
these sorts of flights more than four times a year. I presume that the
AOPA has some arrangement with the FAA that it extends to its members, and
that the four-event maximum is to prevent bogus "charity" airlines.
Am I correct and, if so, WTH does drug testing have to do with any of it?
-c
Old May 30th 06, 05:17 AM posted to rec.aviation.piloting
You need to file the proper charity flight notification with the FAA
and meet the FAR requirements for charity flight (200 hrs, etc). Also,
you will need to use the AOPA drug test exemption. I've done this and
it worked out well. Being commercial means you don't need to notify the
FDSO ahead of time.
-Robert
Old May 30th 06, 05:32 AM posted to rec.aviation.piloting
No, unless the flight complies with FAR 61.113(d).
It's not legal unless it complies with either 61.113(d) or the
following list: 135.249, 135.251, 135.253, 135.255, and 135.353 (per
135(1)(a)(5)).
It's not legal unless it complies with either 61.113(d) or the entirety
of Part 119 and any applicable parts of parts 121, 125, or 135.
Old May 30th 06, 05:57 AM posted to rec.aviation.piloting
Brien K. Meehan wrote:
135(1)(a)(5)).
yep, but these concern flight for compensation or for hire; does it
apply to such operations? note that I am not saying you are wrong,
just wondering.
--Sylvain
Old May 30th 06, 05:52 AM posted to rec.aviation.piloting
as far as I understand it, yes it is legal, however:
The pilots must be at least a private pilot (not recreational or sport);
61.101(e)(13) and 61.315(c)(10)
Other than that relevant regs is 61.113(d) providing that -- I
summarize some key points, but refer to the regs -- the sponsor,
i.e., charitable organization, notifies the local FSDO at least
7 days ahead of time and in doing so provides some documentation
which includes the credentials of the pilots involved; if
the pilots are private pilots, they must have at least 200 hours
of *flight time* (I don't see anywhere that it has to be PIC nor
that said flight time has to be all in same category/class). The
flights have to be day VFR, no acro, no formation flights...
Now a commercial pilots would necessarily meet these requirements.
As for the other questions however, i.e., flight to another
destination, overnight stay, etc. I don't see it described as
an exception of part 119.1(e)... but, folks who fly Angel
Flights do that routinely, so how does it work? what are the
chapter and verses that apply? or do they operate under specific
Letter of Agreement (or whatever other waiver?)
Note that since you will have to talk to the FSDO anyway, you
might as well as them the question, in addition of course to
asking these nice folks from AOPA,
--Sylvain
Old May 30th 06, 06:20 AM posted to rec.aviation.piloting
but, folks who fly Angel Flights do that routinely, so how does it work?
Angel Flight is specially recognized by the FAA. It operates almost as
an exempt 135 operation. The FAA has tried to kill it a couple of times
but politics won't let it happen. After 9/11 when only part 135 could
go VFR, Angel Flight was flying VFR too. A couple high profile
accidents and it would probably gone quickly though.
-Robert
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
