There's two GPS approaches into KDMW; the RNAV (GPS) RWY 16 and the RNAV
(GPS) RWY 32. http://www.myairplane.com/databases/...s/05533R16.pdf http://www.myairplane.com/databases/...s/05533R34.pdf Both start from off-airway IAF's, with no feeder routes. Both use the same missed approach fix. Yet, one is marked "Radar Required" and the other isn't. Anybody have any clue why? Secondary question -- I thought the concept of these pure GPS approaches was to lay out 3 IAF's in a T pattern. Why no outside IAF's, and no PT? Both of these seem kind of ugly if you start them from a course 180 degrees off the FAC. |
![]() Roy Smith wrote: There's two GPS approaches into KDMW; the RNAV (GPS) RWY 16 and the RNAV (GPS) RWY 32. http://www.myairplane.com/databases/...s/05533R16.pdf http://www.myairplane.com/databases/...s/05533R34.pdf Both start from off-airway IAF's, with no feeder routes. Both use the same missed approach fix. Yet, one is marked "Radar Required" and the other isn't. Anybody have any clue why? Secondary question -- I thought the concept of these pure GPS approaches was to lay out 3 IAF's in a T pattern. Why no outside IAF's, and no PT? Both of these seem kind of ugly if you start them from a course 180 degrees off the FAC. Is FOUST on an airway? If it isn't then the facility needs to use at least a radar monitor to get you there. As to the "T" design, that is the design objective, but in crowded airspace like that the ATC folks probably told the procedures designers "Don't do that here." |
![]() Roy Smith wrote: Secondary question -- I thought the concept of these pure GPS approaches was to lay out 3 IAF's in a T pattern. Why no outside IAF's, and no PT? Both of these seem kind of ugly if you start them from a course 180 degrees off the FAC. As to a large course change, the procedures designer is supposed to annotate course-change limitations for procedure entry. See KUDD RNAV 10. But, they haven't started "enforcing" that requirement of TERPs until the last couple of years. |
AIM 5-4-5, figures 5-4-10 and onward, show some alternatives to the basic T.
Not a complete answer to your question, but... Bob Gardner "Roy Smith" wrote in message ... There's two GPS approaches into KDMW; the RNAV (GPS) RWY 16 and the RNAV (GPS) RWY 32. http://www.myairplane.com/databases/...s/05533R16.pdf http://www.myairplane.com/databases/...s/05533R34.pdf Both start from off-airway IAF's, with no feeder routes. Both use the same missed approach fix. Yet, one is marked "Radar Required" and the other isn't. Anybody have any clue why? Secondary question -- I thought the concept of these pure GPS approaches was to lay out 3 IAF's in a T pattern. Why no outside IAF's, and no PT? Both of these seem kind of ugly if you start them from a course 180 degrees off the FAC. |
Roy Smith wrote in
: There's two GPS approaches into KDMW; the RNAV (GPS) RWY 16 and the RNAV (GPS) RWY 32. http://www.myairplane.com/databases/...dfs/05533R16.p df http://www.myairplane.com/databases/...dfs/05533R34.p df Both start from off-airway IAF's, with no feeder routes. Both use the same missed approach fix. Yet, one is marked "Radar Required" and the other isn't. Anybody have any clue why? It appears to me that they made a mistake on the GPS Rwy 16 by not making radar required. There is no way to fly the approach if you're coming from the south, since it's marked PT NA. Secondary question -- I thought the concept of these pure GPS approaches was to lay out 3 IAF's in a T pattern. Why no outside IAF's, and no PT? Both of these seem kind of ugly if you start them from a course 180 degrees off the FAC. Yabbut, lots of them don't have that. All the GPS approaches to Scholes Field, Galveston, TX are without a T, and all are marked radar required. They are too close to HOU and EFD to have people flying long procedure turns, so they just have a straight-in approach, with radar required to get to the FAC. The approaches you referenced look the same, but I don't have any charts handy to see what else is near. I think both approaches should have radar required. -- Regards, Stan |
Stan Gosnell me@work wrote:
It appears to me that they made a mistake on the GPS Rwy 16 by not making radar required. OK, that makes sense. There is no way to fly the approach if you're coming from the south, since it's marked PT NA. My first reaction was "What do you mean it's marked PT NA?". Then I saw the notation on the vertical profile view. There's no "NoPT" on the plan view. Another charting error? Hmm, the 34 doesn't have either NoPT on the plan view or PT NA on the profile. I guess that also makes sense since the only way to fly it on vectors. I just did some hunting around, and it looks like NACO takes chart corrections via email, . I guess I'll drop them a line and see what they say. |
![]() "Roy Smith" wrote in message ... Stan Gosnell me@work wrote: It appears to me that they made a mistake on the GPS Rwy 16 by not making radar required. OK, that makes sense. There is no way to fly the approach if you're coming from the south, since it's marked PT NA. My first reaction was "What do you mean it's marked PT NA?". Then I saw the notation on the vertical profile view. There's no "NoPT" on the plan view. Another charting error? Hmm, the 34 doesn't have either NoPT on the plan view or PT NA on the profile. I guess that also makes sense since the only way to fly it on vectors. There is no PT identified on the chart so it needs no "NoPT" to tell you not to PT. The NoPT is (I think) only shown on segments of an approach that have PTs (the approach has PT) but where some IAF do not require a PT and some do. As for the Radar required - check the 2 NM and 1.1 NM points on the chart - it looks like they have it there for that? (Though I suppose your GPS might be able to tell you that but it probably is not a waypoint). I just did some hunting around, and it looks like NACO takes chart corrections via email, . I guess I'll drop them a line and see what they say. |
![]() Richard Hertz wrote: There is no PT identified on the chart so it needs no "NoPT" to tell you not to PT. The NoPT is (I think) only shown on segments of an approach that have PTs (the approach has PT) but where some IAF do not require a PT and some do. Jeppesen doesn't chart "Procedure Turn N/A" which is quite different than "NoPT." "NoPT" is used only on segments of an IAP that has a course reversal and a segment so marked does not require the course reversal. Jeppesen's view is that the lack of a course reversal (PT or HIL) makes it self-evident that the course reversal is not authorized. As for the Radar required - check the 2 NM and 1.1 NM points on the chart - it looks like they have it there for that? (Though I suppose your GPS might be able to tell you that but it probably is not a waypoint). Yes, your GPS can tell you and, no, it is not a waypoint. It is an Along Track Distance (ATD) fix, which is like a DME stepdown fix. AIM 1-1-19-13 "13. Unnamed stepdown fixes in the final approach segment will not be coded in the waypoint sequence of the aircraft's navigation database and must be identified using ATD. Stepdown fixes in the final approach segment of RNAV (GPS) approaches are being named, in addition to being identified by ATD. However, since most GPS avionics do not accommodate waypoints between the FAF and MAP, even when the waypoint is named, the waypoints for these stepdown fixes may not appear in the sequence of waypoints in the navigation database. Pilots must continue to identify these stepdown fixes using ATD." |
Is this any different than what I wrote?
I agree, NoPT is not the same as PT not authorized, but I was trying to correct what I thought was an error in Roy's reasoning... Perhaps I did not make myself clear. wrote in message ... Richard Hertz wrote: There is no PT identified on the chart so it needs no "NoPT" to tell you not to PT. The NoPT is (I think) only shown on segments of an approach that have PTs (the approach has PT) but where some IAF do not require a PT and some do. Jeppesen doesn't chart "Procedure Turn N/A" which is quite different than "NoPT." "NoPT" is used only on segments of an IAP that has a course reversal and a segment so marked does not require the course reversal. Jeppesen's view is that the lack of a course reversal (PT or HIL) makes it self-evident that the course reversal is not authorized. As for the Radar required - check the 2 NM and 1.1 NM points on the chart - it looks like they have it there for that? (Though I suppose your GPS might be able to tell you that but it probably is not a waypoint). Yes, your GPS can tell you and, no, it is not a waypoint. It is an Along Track Distance (ATD) fix, which is like a DME stepdown fix. AIM 1-1-19-13 "13. Unnamed stepdown fixes in the final approach segment will not be coded in the waypoint sequence of the aircraft's navigation database and must be identified using ATD. Stepdown fixes in the final approach segment of RNAV (GPS) approaches are being named, in addition to being identified by ATD. However, since most GPS avionics do not accommodate waypoints between the FAF and MAP, even when the waypoint is named, the waypoints for these stepdown fixes may not appear in the sequence of waypoints in the navigation database. Pilots must continue to identify these stepdown fixes using ATD." |
!FDC 4/3343 DMW FI/T CARROLL COUNTY REGIONAL/JACK B. POAGE FIELD,
WESTMINSTER, MD RNAV (GPS) RWY 16, ORIG... UNYTS WP: CHANGE FIX DESCRIPTION FROM (IAF) TO (IF). RADAR REQUIRED. "Stan Gosnell" me@work wrote in message ... Roy Smith wrote in : There's two GPS approaches into KDMW; the RNAV (GPS) RWY 16 and the RNAV (GPS) RWY 32. http://www.myairplane.com/databases/...dfs/05533R16.p df http://www.myairplane.com/databases/...dfs/05533R34.p df Both start from off-airway IAF's, with no feeder routes. Both use the same missed approach fix. Yet, one is marked "Radar Required" and the other isn't. Anybody have any clue why? It appears to me that they made a mistake on the GPS Rwy 16 by not making radar required. There is no way to fly the approach if you're coming from the south, since it's marked PT NA. Secondary question -- I thought the concept of these pure GPS approaches was to lay out 3 IAF's in a T pattern. Why no outside IAF's, and no PT? Both of these seem kind of ugly if you start them from a course 180 degrees off the FAC. Yabbut, lots of them don't have that. All the GPS approaches to Scholes Field, Galveston, TX are without a T, and all are marked radar required. They are too close to HOU and EFD to have people flying long procedure turns, so they just have a straight-in approach, with radar required to get to the FAC. The approaches you referenced look the same, but I don't have any charts handy to see what else is near. I think both approaches should have radar required. -- Regards, Stan |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
Horsepower required for level flight question... | BllFs6 | Home Built | 17 | March 30th 04 12:18 AM |
Ham sandwich navigation and radar failure | David Brooks | Instrument Flight Rules | 47 | December 31st 03 12:15 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Marine Radar in a plane? | Jay Honeck | Home Built | 31 | August 13th 03 06:56 PM |
