Has anyone replaced their Delco Remy voltage regulator (the old
mechanical type for a 50 amp generator) with a new solid state type by Zeftronics? CHief aircraft sells them, just wondering what anyone's experience was. Mine is old, acting up and charging too high. In the old days I guess you could clean the contacts and so forth but I'd rather just replace it. |
![]() kontiki wrote: Has anyone replaced their Delco Remy voltage regulator (the old mechanical type for a 50 amp generator) with a new solid state type by Zeftronics? CHief aircraft sells them, just wondering what anyone's experience was. Mine is old, acting up and charging too high. In the old days I guess you could clean the contacts and so forth but I'd rather just replace it. Little different situation, but my C182L came with a Ford 60A alternator and a vibrating-point electromechanical regulator. I installed a Zeftronics solid-state Alternator regulator per STC years ago, and it has worked flawlessly. |
![]() kontiki wrote: Has anyone replaced their Delco Remy voltage regulator (the old mechanical type for a 50 amp generator) with a new solid state type by Zeftronics? CHief aircraft sells them, just wondering what anyone's experience was. Mine is old, acting up and charging too high. In the old days I guess you could clean the contacts and so forth but I'd rather just replace it. I would keep what you currently have installed and have an A&P reset the voltage back to where it belongs. Resetting the voltages is a simple task with a voltmeter. The old style last forever and changing to a new style will require some FAA paperwork. The A&P will be worth the cost. Stache |
![]() kontiki wrote: Has anyone replaced their Delco Remy voltage regulator (the old mechanical type for a 50 amp generator) with a new solid state type by Zeftronics? CHief aircraft sells them, just wondering what anyone's experience was. Mine is old, acting up and charging too high. In the old days I guess you could clean the contacts and so forth but I'd rather just replace it. Hi, I have a pair of 28 volt/ 50 amp Delco Remy generators. Four years ago, I had the two generators overhauled and replaced the contact type voltage regulators with the solid state Zeftronics units. I am very pleased with the Zeftronics units. I dealt with Aero Tech of Louisville and was happy with their support. The Zeftronics units also have LED indicators and a troubleshooting guide to tell what is going on in the charging system. The folks at Zeftronics are also very helpful. Brian |
![]() kontiki wrote: Has anyone replaced their Delco Remy voltage regulator (the old mechanical type for a 50 amp generator) with a new solid state type by Zeftronics? CHief aircraft sells them, just wondering what anyone's experience was. General statement: The Zeftronics unit is more accurate and more reliable... and cheaper. In general, replacing the old unit (rather than repair) makes a lot of sense. Specific: However, some aircraft will experience electrical noise problems in the avionics after replacement. The digital Zeftronics puts out continuous broadband RF (as opposed to the old mechanical units that put out various pops and clicks at random times). A lot of older Piper's especially tend to have the wiring for the VR (up under the dash) bundled with antenna wires and power lines to the avionics. The result is a "frying bacon" sound on the ADF on the lower bands - especially when tuned to a weak NDB. [The needle will also probably track somewhere well OFF the station.] If you do install one and you have a split master, tune your ADF to a weak low band station. Listen to the noise and observe the needle. Now turn off the alternator/generator. Did the needle move? The noise change? If so, you probably either have to go back to the old style unit, or get used to flying NDB approaches in IFR with the alternator switch off. G |
jmk wrote:
General statement: The Zeftronics unit is more accurate and more reliable... and cheaper. In general, replacing the old unit (rather than repair) makes a lot of sense. Specific: However, some aircraft will experience electrical noise problems in the avionics after replacement. The digital Zeftronics puts out continuous broadband RF (as opposed to the old mechanical units that put out various pops and clicks at random times). A lot of older Piper's especially tend to have the wiring for the VR (up under the dash) bundled with antenna wires and power lines to the avionics. The result is a "frying bacon" sound on the ADF on the lower bands - especially when tuned to a weak NDB. [The needle will also probably track somewhere well OFF the station.] I have had exactly the opposite experience. It is easier to suppress an electronic regulator than it was to suppress the mechanical regulator... ADF (and Loran, remember those?) operate at low-rf frequencies between 100Khz and 500Khz. The "frying bacon" noise that effects these is usually generated by arcing as the brushes jump across the segmented commutator in a generator, or arcing as the brushes rub on the slip-rings in an alternator. This happens regardless if the regulator is mechanical, electronic or is not there at all... Preventing the brush RFI from radiating to the ADF/Loran is accomplished by putting a RFI suppression filter (usually just a coaxial HyPass capacitor) on the output terminal of the gen/alt. http://www.lonestaraviation.com/prod...tor%20Filt er shows such a capacitor. BTW, contrary to what Lonestar claims, putting such a filter on a gen/alt does nothing to cure alternator whine in aircraft audio/intercom systems; only in "bypassing" RFI which would otherwise radiate from the gen/alt and its wiring to the ADF or Loran antenna. Also note that if the aircraft doesn't have an ADF or Loran, then a filter is not even necessary, because the gen/alt brush hash doesn't effect VHF/UHF/GPS receivers... Putting a filter between the gen/alt and the aircraft electrical bus is not without consequence, see: http://www.ntsb.gov/ntsb/brief2.asp?...FA284& akey=1 Shielding the Field wire running between the regulator and the gen/alt is usually sufficient to prevent radiation off the field wire. It matters not if the reg is mechanical or electronic. |
![]() mikem wrote: I have had exactly the opposite experience. It is easier to suppress an electronic regulator than it was to suppress the mechanical regulator... ADF (and Loran, remember those?) operate at low-rf frequencies between 100Khz and 500Khz. The "frying bacon" noise that effects these is usually generated by arcing as the brushes jump across the segmented commutator in a generator, or arcing as the brushes rub on the slip-rings in an alternator. This happens regardless if the regulator is mechanical, electronic or is not there at all... I don't think we actually disagree. First off, the alternator/generator noise is independent of the regulator... If it's arcing and sparking, then that needs to be addressed regardless. Second, the mechanical regulator does put out higher amplitude "spikes" - but they tend to have less power in the higher frequencies than the digital regulator, and they are MUCH MUCH less frequent. [Basically, the mechanical regulator only "adjusts" in a few discrete quantum - whereas the digital unit is constantly switching.] The result is that the pops and clicks from the mechanical regulator don't tend to interfere with the ADF and Loran, whereas the higher constant noise ground floor from the digital unit does. None of this matters if the regulator has proper grounding and shielding, and minimal care is made to not run sensitive antenna wiring and radio power/audio lines bundled with regulator wiring... but in older planes with mechanical regulators they *could* (and hence *did*) get away with it. jmk |
jmk wrote:
mikem wrote: Here's an interesting story for you guys to ponder... Years ago, some time after I installed my Stormscope (and with a fairly new alternator), the anal retentive electrical engineer in me decided to get one of those solid state Zeftronics voltage regulators. It created a phantom storm on the Stormscope. I checked all the grounding, etc, and tinkered with it for a few days, then I re- installed my mechanical regulator. It's been fine ever since. I still have that solid state regulator around somewhere. I'm going to try it again, when I get a chance. --- Jay -- Jay Masino "Home is where the critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
![]() Jay Masino wrote: jmk wrote: mikem wrote: Here's an interesting story for you guys to ponder... Years ago, some time after I installed my Stormscope (and with a fairly new alternator), the anal retentive electrical engineer in me decided to get one of those solid state Zeftronics voltage regulators. It created a phantom storm on the Stormscope. I checked all the grounding, etc, and tinkered with it for a few days, then I re- installed my mechanical regulator. It's been fine ever since. I still have that solid state regulator around somewhere. I'm going to try it again, when I get a chance. Hi Jay, your experience with the solid-state regulator supports jmk's thesis, ie that the mechanical regulator switches infrequently, and generates less interference to your Stormscope than the Zeftronics regulator, which switches on/off at a much higher rate. I recently experimented with a solid-state regulator which switched at about 20 to 40Hz. I also recently tested FAA-PMAed solid-state "linear" regulator, which doesn't switch at all. It is a class A amplifier which smoothly changes the alternator's field current from zero to full-on (about 3A). Maybe you should get one of those to keep your Stormscope happy. |
![]() mikem wrote: The digital Zeftronics puts out continuous broadband RF (as opposed to the old mechanical units that put out various pops and clicks at random times The mechanical regulator operates like a buzzer. I have a couple of sim setups here I use to teach the systems, and in a dark room with the alternator operating you can see the small but constant arcing between the regulator contact points. A capacitor across field and ground kills most of the noise. The inductance of the field winding and the resistors in the regulator maintain a semblance of constant current flow even thought the points are bouncing, and the capacitor reduces the arcing that makes noise and burns the contacts. Works pretty well, even though it's primitive. I do like the constant-current regulator idea, though failure is more likely to be instant and without warning. Worn mechanical regulators will start dropping the output voltage or might stick occasionally. Dan |
Low voltage warning level | markp | Home Built | 1 | December 27th 05 05:11 AM |
Low battery voltage level | markp | Instrument Flight Rules | 8 | December 22nd 05 10:16 AM |
Mooney Low Voltage | [email protected] | Owning | 22 | August 1st 05 01:01 PM |
High Voltage | Jim Rosinski | Piloting | 7 | October 16th 04 10:48 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
