Considering building a Fly Baby
Old June 5th 06, 03:30 AM posted to rec.aviation.homebuilt
Default Considering building a Fly Baby
I am 65, retired and don't have a license to fly anything. I am fairly good
with woodworking (built a few pieces of furniture and my father was a master
carpenter) and have the basic shop tools so was considering a Fly Baby. Any
advice or opinions from you folks that have 'done it'?
Kind regards,
Terry Judkins
http://home.comcast.net/~suptjud
Old June 5th 06, 05:13 AM posted to rec.aviation.homebuilt
good with woodworking (built a few pieces of furniture and my father was
a master carpenter) and have the basic shop tools so was considering a
Fly Baby. Any advice or opinions from you folks that have 'done it'?
Best advice I got is, if you want to build it, then build it.
Ron W might try to talk you out of it.
But he won't try real hard...
Have fun, Terry.
You've earned it.
Richard
Old June 5th 06, 05:39 AM posted to rec.aviation.homebuilt
No! No! For gawd's sake, run away! We want to keep all the fun for
ourselves! :-)
If you haven't yet, I suggest you check out my Fly Baby web page:
http://www.bowersflybaby.com/
You should be able to get all the info you'd need, either there or with the
Yahoo discussion group:
http://groups.yahoo.com/group/flybabylist/
The group archives are open to the public.
Old June 5th 06, 01:19 PM posted to rec.aviation.homebuilt
Thanks! I have read your web site (some of it more than once).
My son-in-law is building an RV7 and my nephew is a licensed instructor so I
should have some good support in the endeavor. Just might 'do it'.
good
master
Any
ourselves! :-)
Old June 5th 06, 03:30 PM posted to rec.aviation.homebuilt
How tall are you?
How flexible are you?
Find someone that has one and see how easily you can get in and out.
At 6'3", it was too small for me.
Old June 5th 06, 03:55 PM posted to rec.aviation.homebuilt
How tall are you?
Depends on how the person is put together, and what kind of mods are made during
construction. The designer was 6' 2", so you probably are proportionately
longer the legs than he was. Chris Brown is 6' 5" and did a few mods to the
airplane he bought.
For more details, see "Fly Babies for the Big and Tall":
http://www.bowersflybaby.com/tech/room.html
Certainly should find one first, to see how the stock fit is.
Old June 5th 06, 05:47 PM posted to rec.aviation.homebuilt
I put about 15 hours on a Flybaby built by a tech college in the 70s and
it was a neat airplane except for the lack of a shock absorbing landing
gear. It depends totally on soft tires for shock absorbtion, so taxing
on the ground it follows every ground contour like a two-wheeled
wheelbarrow. In spite of the lack of spring gear I was successful at
making it bounce about 4 feet in the air during a sloppy full stall
landing one time.
Also if control cable is used for flying wire (as this one did) it
stretches quite a lot under load. In a 2G turn the upper cables would
curve back about an inch or so as they went slack which was somewhat
disconcerting at first. You have to be very confident in your
nicropress skills. If I was building one I would use 1x19 cable instead
of 7x19 with terminal swages instead of nicropress, or better yet
streamline rod.
John
How tall are you?
airplane he bought.
Old June 5th 06, 07:43 PM posted to rec.aviation.homebuilt
streamline rod.
You absolutely need to read this article about streamline rod and the
Fly Baby on Ron's website:
http://www.bowersflybaby.com/safety/hinton.htm
Kinda surprised me too
Streamline rod seems like a good idea on the surface, but it's not
always the best solution for all types of aircraft. Well, the article
explains it best.
Old June 9th 06, 12:31 AM posted to rec.aviation.homebuilt
Jim Carriere wrote:
instead of 7x19 with terminal swages instead of nicropress, or better
yet streamline rod.
explains it best.
Yeah that's an eye opener all right. Thanks for bringing it up. Guess
the intersection cross tie used on biplanes mainly to reduce noise from
the wires vibrating has a much more important function that people realise!
John
Video of THERMITE REACTION at WTC on 9/11 Wake UP! Piloting 184 April 7th 06 04:05 AM
Physics Professor's Peer Reviewed Paper on WTC CONTROLLED DEMOLITIONSon 9/11 Frank F. Matthews Piloting 26 March 1st 06 12:13 AM
Scholars for 9/11 Truth -- HTTP://ST911.ORG -- REPLY IN THIS THREAD ONLY TRUTH Piloting 0 February 24th 06 07:00 AM
Fly Baby Plans Off the Market Ron Wanttaja Home Built 9 June 6th 04 02:45 PM
Hispanic Hero Recalls Experiences Otis Willie Military Aviation 0 September 30th 03 10:02 PM
