Hello all,
I'm just curious as to when the last time was that you used your ADF for actual navigation? Are NDBs common in the US? It seems as though every little airport has an ILS! -dr |
wrote in message oups.com...
Hello all, I'm just curious as to when the last time was that you used your ADF for actual navigation? Are NDBs common in the US? It seems as though every little airport has an ILS! -dr Last Saturday. And the Sunday before that. And on most of my cross-country flights, generally. But ~90% of my ADF usage is supplementary to other navigation. The needle swing when passing an LOM is supplementary, to me. So also, is using the ADF to be ready for a clearance direct to the airport, while being radar vectored and expecting a visual approach. (The latter is exactly how I used my ADF last Saturday.) |
"Nathan Young" wrote in message
... I use it almost every flight for AM radio, not so much for instrument flying, although two of my more frequently used airports (CMI - Champaign, and RFD - Rockford) have LOMs on the ILS, so I occasionally actually use one for navigation. I often use LOMs on ILS approaches too. Seeing that the CDI and ADF lean in opposite directions is an easy way to double-check that you're being properly vectored for the approach. --Gary |
The ADF works great with AM broadcast for VFR long range
direct. Before the days of LORAN and GPS, tracking to some 50,000 Watt clear channel radio was the accepted method. Even works for practicing all those techniques that are never used in the real ATC world of IFR, such as time and distance, bearing change, etc. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Gary Drescher" wrote in message . .. | "Nathan Young" wrote in message | ... | I use it almost every flight for AM radio, not so much for instrument | flying, although two of my more frequently used airports (CMI - | Champaign, and RFD - Rockford) have LOMs on the ILS, so I occasionally | actually use one for navigation. | | I often use LOMs on ILS approaches too. Seeing that the CDI and ADF lean in | opposite directions is an easy way to double-check that you're being | properly vectored for the approach. | | --Gary | | |
Nathan Young wrote: I'm just curious as to when the last time was that you used your ADF for actual navigation? I've been flying instruments for over 10 years. I've never flown a single NDB approach in anger (i.e. other than in training or to pass a checkride) in all that time. Of course, that reflects the kind of flying I do; somebody based at a field with only an NDB approch would obviously have a different story to tell. We pulled all the ADFs out of our club planes a bunch of years ago. I used to use it a lot on X/C trips (VFR or IFR), to tune in NDBs near my route as a double-check on my navigation. Before we had GPS, I found tuning in the LOM to be a useful situational awareness aid on an ILS (if the CDI and ADF needles are pointed in opposite directions while intercepting the localizer, you're going to intercept outside the LOM, which is a good thing). But all that's in the past. At this point, I can't imagine doing any serious IFR flying without a GPS, and once you've got a GPS, there's just absolutely no need for an ADF anymore (except for those very rare exceptions of fields which only have an NDB approach and no GPS overlay, and even then I'm not sure I'd be able to resist the urge to cheat). |
Roy Smith wrote:
once you've got a GPS, there's just absolutely no need for an ADF anymore (except for those very rare exceptions of fields which only have an NDB approach and no GPS overlay, .... and the occasional field where the ATIS/AWOS is on the NDB frequency. |
"Roy Smith" wrote in message
... I've been flying instruments for over 10 years. I've never flown a single NDB approach in anger (i.e. other than in training or to pass a checkride) in all that time. I once made an NDB approach in IMC to a field whose ILS approach was pointing downwind at the time. Usually, though, my use of the ADF is for an ILS's LOM. --Gary |
![]() "Gary Drescher" wrote in message ... I once made an NDB approach in IMC to a field whose ILS approach was pointing downwind at the time. Usually, though, my use of the ADF is for an ILS's LOM. What field? |
Instruement checkride...for real this time (long) | Jack Allison | Piloting | 28 | February 28th 06 03:26 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
