Hello:
Retired Engineer. Have always been interested in carrier catapaults. I have tried to find a good, relatively technical, description on the web with some diagrams or pix of the aircraft hold-back mechanism that's used immediately prior to launch that restrains the plane. Doubt that they still use breakable (frangible) type of bolts, but perhaps ? Do they ? Anyone know of any good sources to learn more about how this is actually done, and what these mechanisms look like ? Thanks, B. |
![]() "Robert11" wrote in message . .. Hello: Retired Engineer. Have always been interested in carrier catapaults. I have tried to find a good, relatively technical, description on the web with some diagrams or pix of the aircraft hold-back mechanism that's used immediately prior to launch that restrains the plane. Doubt that they still use breakable (frangible) type of bolts, but perhaps ? Do they ? The 'breakable' holdback certainly is still in use today. It's not a bolt, but looks more like a 'double mushroom' where the center has been machined down to certain specs. It is designed to separate at a predetermined stress point. |
Robert11 wrote:
Hello: Retired Engineer. Have always been interested in carrier catapaults. I have tried to find a good, relatively technical, description on the web with some diagrams or pix of the aircraft hold-back mechanism that's used immediately prior to launch that restrains the plane. Doubt that they still use breakable (frangible) type of bolts, but perhaps ? Do they ? Anyone know of any good sources to learn more about how this is actually done, and what these mechanisms look like ? Thanks, B. The tension bar contains a breakable link that looks like a piece of 2-1'2" diameter steel shafting about 3" long was chucked in a lathe and parted in the middle except for the last 1/2" to 3/4". They are color-coded by aircraft type. http://www.tpub.com/content/aviation...s/14014_86.htm (figure 4-16) http://www.tpub.com/content/aviation...s/14018_27.htm Rick |
![]() Doubt that they still use breakable (frangible) type of bolts, but perhaps ? Do they ? Anyone know of any good sources to learn more about how this is actually done, and what these mechanisms look like ? I have one in front of me, from my first S-3 launch. My half (other half stays in the shuttle until the deck crew discards it) looks like half of a palm-sized purple yo-yo. Each a/c type used a different color as each a/c had a slightly different holdback fitting. v/r Gordon |
![]() "Gordon" wrote in message ps.com... Doubt that they still use breakable (frangible) type of bolts, but perhaps ? Do they ? Anyone know of any good sources to learn more about how this is actually done, and what these mechanisms look like ? I have one in front of me, from my first S-3 launch. My half (other half stays in the shuttle until the deck crew discards it) looks like half of a palm-sized purple yo-yo. Each a/c type used a different color as each a/c had a slightly different holdback fitting. Agreed. And they are NOT interchangeable deliberately so Sailors don't screw up and put the wrong one in. If the wrong holdback fitting *could* be installed (with the associated incorrect release pressure), the results could be disastrous. The cat could either release without enough steam pressure to get the aircraft fully airborne or the 'live cat' could just sit there without enough pressure to break the holdback (instead of actually launching the aircraft) until the steam pressure is bled off (aborting the cat shot). |
half stays in the shuttle until the deck crew discards it) looks like half of a palm-sized purple yo-yo. Each a/c type used a different color as each a/c had a slightly different holdback fitting. Agreed. And they are NOT interchangeable deliberately so Sailors don't screw up and put the wrong one in. If the wrong holdback fitting *could* be installed (with the associated incorrect release pressure), the results could be disastrous. The cat could either release without enough steam pressure to get the aircraft fully airborne or the 'live cat' could just sit there without enough pressure to break the holdback (instead of actually launching the aircraft) until the steam pressure is bled off (aborting the cat shot). What?! Are you suggesting squids occasionally eff-up? ![]() ok, ok, I'll agree - if we CAN screw something up, at some point, some kid will. I watched an A-3 take off once, followed by an A-7... Problem? The cat was not reset and the Corsair was tossed off the boat "with alacrity", causing noticible damage (belly pan detached during the blistering fast takeoff run among other problems). Whenever someone makes a device idiot proof, along come better idiots! v/r Gordon |
Hi,
Thanks for info. a. What happens to the piece of the breakable link that is part of the bar that stays with the plane ? Does it go flying with the plane to be removed later, or... ? b. Any info on the newer, I think, types of hold-back mechanism that do not utilize the breakable bar, but apparently use some type of captivated spring/cam mechanism as part of the bar (permanently) ? Thanks again, Bob ---------------------------------- "Robert11" wrote in message . .. Hello: Retired Engineer. Have always been interested in carrier catapaults. I have tried to find a good, relatively technical, description on the web with some diagrams or pix of the aircraft hold-back mechanism that's used immediately prior to launch that restrains the plane. Doubt that they still use breakable (frangible) type of bolts, but perhaps ? Do they ? Anyone know of any good sources to learn more about how this is actually done, and what these mechanisms look like ? Thanks, B. |
![]() "Robert11" wrote in message news ![]() Hi, Thanks for info. a. What happens to the piece of the breakable link that is part of the bar that stays with the plane ? Does it go flying with the plane to be removed later, or... ? Yes, and it is later removed by the Plane Captain as part of the "Turn Around Inspection" after landing. b. Any info on the newer, I think, types of hold-back mechanism that do not utilize the breakable bar, but apparently use some type of captivated spring/cam mechanism as part of the bar (permanently) ? Not part of the Steam Catapult system. The holdback may change with the next generation of launch systems. |
![]() "Robert11" wrote in message news ![]() Hi, b. Any info on the newer, I think, types of hold-back mechanism that do not utilize the breakable bar, but apparently use some type of captivated spring/cam mechanism as part of the bar (permanently) ? Thanks again, Bob Yes, they're called RRHAs (Repeatable Releasable Holdback Assembly). They're a one-piece bar that fits into the back of the (A/C's) strut and on the strut there are two metal plates that sandwich the holdback bar. In order to launch, the bar must have enough force applied to it for it to slide past the metal plates/springs. It's basically like some cabinet doors that have the little pokey thing that have to slide inbetween two springs in order to open... they come in different shapes and sizes for different airplanes so they don't get one with the wrong-sized "fist". Since nothing breaks during launch, they can be reused. They just have to be inspected every once in a while to make sure there's no stresses inside the bar that might make it break, and also to make sure the fist hasn't worn down too much. Jason |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
