Hello to all,
Do most modern aircraft rely on the GPS for navigation, and to what extent do they rely on it? And is it true that such aircraft's navigation systems use maps 'optimised' for GPS? And finally, if I may, what level of positional accuracy must aircraft relying on GPS for navigation work with at typical altitudes (presumably 20,000 to 40,000 ft)? Are we talking tens of metres, or over a hundred metres? Thanks very much in advance. Regards, David, England. |
![]() "David W" wrote: Hello to all, Do most modern aircraft rely on the GPS for navigation, and to what extent do they rely on it? What kind of modern aircraft are you talking about--bizjets...airliners...military? And is it true that such aircraft's navigation systems use maps 'optimised' for GPS? What does 'optimised' for GPS mean? And finally, if I may, what level of positional accuracy must aircraft relying on GPS for navigation work with at typical altitudes (presumably 20,000 to 40,000 ft)? Are we talking tens of metres, or over a hundred metres? Tens of meters or less. What's behind your questions; what are you trying to get at? If you posted that, you might get more suitable answers. -- Dan C172RG at BFM |
Hi Dan,
Sorry, my questions could have been better posed. Do most modern aircraft rely on the GPS for navigation, and to what extent do they rely on it? What kind of modern aircraft are you talking about--bizjets...airliners...military? I had primarily airliners and military aircraft in mind, but I didn't state it (as would have been helpful). And is it true that such aircraft's navigation systems use maps 'optimised' for GPS? What does 'optimised' for GPS mean? I'm not sure. Somebody with whom I am having a 'debate' has asserted that there is an altitude-dependent error component (if I may call it that) on positions determined by GPS (and I presume that this alleged error component affects the horizontal component of a 3D position, as well as vertical (altitude) component). In his own words: "GPS is optimised for sea level, Blanchefort [a mountaintop ruined castle] is 467 metres above sea level, couple this with a slant range to a satellite of several thousand miles and the curvature of the earth and you have error. At least up to 100 metres..." I personally can find no evidence which supports his claim that a) GPS is optimised for sea level, or b) GPS coordinates obtained at a few hundred metres above (mean) sea level are affected by his alleged altitude-induced error. I replied (verbatim quote - please excuse the sarcastic tone!): "This is really bad news. Modern aircraft - many of which rely heavily on GPS for navigation - are in big trouble then, aren't they? I mean, if the error at just 467 metres above MSL is ''at least up to 100 metres'', then surely it must be several kilometres by the time we get up to altitudes like 30,000 ft., right?" His reply (with some non-essentials removed): "Aircraft ... are using a map optimised to the GPS system and this is the key point which seems to be passing you by." What's behind your questions; what are you trying to get at? If you posted that, you might get more suitable answers. I hope that that is sufficiently answered above. I didn't want to burden this group with extensive background information and endless quotes from this slightly silly debate! Regards, David, England. |
"David W" wrote in message
ups.com... And is it true that such aircraft's navigation systems use maps 'optimised' for GPS? What does 'optimised' for GPS mean? I'm not sure. Somebody with whom I am having a 'debate' has asserted that there is an altitude-dependent error component (if I may call it that) on positions determined by GPS (and I presume that this alleged error component affects the horizontal component of a 3D position, as well as vertical (altitude) component). It is theoretically true that altitude can affect the geometry of the GPS receiver and satellites being received in such a way as to increase error. However, the orbital altitude (10,988 nautical miles) is so much higher than flight altitudes (usually up to 9 or 10 nautical miles at the very most, and for commercial airliners 6 nautical miles give or take is more typical), it's hard to imagine any significant error being caused by that. Even in the most extreme case, an airplane is only going to climb high enough to change the distance to the satellite by 0.05-0.10%. And this assumes the satellite is directly overhead; when it's not, the distances are even greater and altitude even less significant. It's important to note: the GPS system doesn't actually care about elevation. It cares about distances and calculates a 3D position based on measured distances (simplistically stated, anyway). If altitude was a significant problem, then so would any variation in distance from the receiver to the satellite, and the change in that distance due to the relative angle in the sky of the satellite is MUCH greater than any change in elevation possible by an airplane. If altitude caused a problem, the GPS would be incredibly unreliable all the time, since the satellites are rarely directly overhead. Not that your debate partner will see this. He'll just say something about the system being "optimised" for the effects of satellite orbits on the distance between receiver and satellite. But it's true, nonetheless. In his own words: "GPS is optimised for sea level, Blanchefort [a mountaintop ruined castle] is 467 metres above sea level, couple this with a slant range to a satellite of several thousand miles and the curvature of the earth and you have error. At least up to 100 metres..." I still don't know what it means for GPS to be "optimised for sea level". It would be entertaining (though probably not educational) to learn what the guy believes was done to "optimise" GPS for sea level. Certainly is boggles the mind to think that elevation gain results in a 1-to-5 error ratio (that is, 1 unit of error for every 5 units of elevation gain). That's a remarkably fragile system he's describing, and it certainly doesn't apply to GPS as it exists today. [...] His reply (with some non-essentials removed): "Aircraft ... are using a map optimised to the GPS system and this is the key point which seems to be passing you by." More BS. "A map optimised to the GPS system"? Again, even pondering what this could mean is bewildering. Is he saying that, while there's some large error, it's always a known error and so can be compensated for with the map system? Why wouldn't a GPS receiver simply be designed instead to use this known error and correct the calculated position based on that? Of course, that's all theoretical. In reality, there's no "known error" (not in the sense that one knows exactly the magnitude AND direction of the error), and no reason to "optimise" the map "to the GPS system". You get the same map on the ground as you do aloft, and the GPS simply plots your position on the map. It's true that there are different mapping systems in use, but they have to do with how one projects the geometrically perfect information from GPS onto the geometrically imperfect planet we live on. I hope that that is sufficiently answered above. I didn't want to burden this group with extensive background information and endless quotes from this slightly silly debate! Yes, I'd agree it's at least "slightly silly". ![]() people who write stuff that ridiculous into my killfile. Pete |
![]() "David W" wrote: [snip] And is it true that such aircraft's navigation systems use maps 'optimised' for GPS? What does 'optimised' for GPS mean? I'm not sure. Somebody with whom I am having a 'debate' has asserted that there is an altitude-dependent error component (if I may call it that) on positions determined by GPS (and I presume that this alleged error component affects the horizontal component of a 3D position, as well as vertical (altitude) component). In his own words: "GPS is optimised for sea level, Blanchefort [a mountaintop ruined castle] is 467 metres above sea level, couple this with a slant range to a satellite of several thousand miles and the curvature of the earth and you have error. At least up to 100 metres..." Nonsense. Your opponent in the debate is a ninny. I personally can find no evidence which supports his claim that a) GPS is optimised for sea level, or b) GPS coordinates obtained at a few hundred metres above (mean) sea level are affected by his alleged altitude-induced error. [snip] His reply (with some non-essentials removed): "Aircraft ... are using a map optimised to the GPS system and this is the key point which seems to be passing you by." Utter twaddle. There are no such maps. What's behind your questions; what are you trying to get at? If you posted that, you might get more suitable answers. I hope that that is sufficiently answered above. I didn't want to burden this group with extensive background information and endless quotes from this slightly silly debate! No problem. You came to the right place after your opponent introduced his bogus aviation arguments. -- Dan C172RG at BFM |
To the OP:
Your "friend" may be thinking of the "datum plane", which is the almost spherical object that is the mathmatical model of the earth. And there are other navigational systems for aircraft. Military aircraft (IIRC) are inertial guidance systems rather than GPS. Or at least they used to be. |
"David W" wrote:
"Aircraft ... are using a map optimised to the GPS system and this is the key point which seems to be passing you by." Nonesense. Aircraft that are equipped with GPS use the same charts that non-GPS aircraft use. The FAA has a pretty good introduction to GPS as use in aviation in the Airman's Information Manual. The section you want is http://www.faa.gov/ATpubs/AIM/Chap1/aim0101.html#1-1-19. If that doesn't get you direct to the right paragraph, search for "1-1-19. Global Positioning System (GPS)". |
There is really no slant range in GPS Navagation. It is Triangulation &
Timing. You need at least 3 satellites in view to get an accurate 3D position. Distance is determined by accurate timing of how long it takes an encoded signal to reach the GPS reciever. Thus with known distances from 3 satellites you can calculate or triangulate (within the tolerance) the exact position of the GPS reciever. This position includes altitude, although altitude in my experience seems to be less accurate. But for all I know the GPS altitude may be more accurate than altitude read from my altimeter, which is corrected for non standard pressure. Hope this short explanation helps Mark "David W" wrote in message ups.com... What does 'optimised' for GPS mean? I'm not sure. Somebody with whom I am having a 'debate' has asserted that there is an altitude-dependent error component (if I may call it that) on positions determined by GPS (and I presume that this alleged error component affects the horizontal component of a 3D position, as well as vertical (altitude) component). In his own words: "GPS is optimised for sea level, Blanchefort [a mountaintop ruined castle] is 467 metres above sea level, couple this with a slant range to a satellite of several thousand miles and the curvature of the earth and you have error. At least up to 100 metres..." I personally can find no evidence which supports his claim that a) GPS is optimised for sea level, or b) GPS coordinates obtained at a few hundred metres above (mean) sea level are affected by his alleged altitude-induced error. I replied (verbatim quote - please excuse the sarcastic tone!): "This is really bad news. Modern aircraft - many of which rely heavily on GPS for navigation - are in big trouble then, aren't they? I mean, if the error at just 467 metres above MSL is ''at least up to 100 metres'', then surely it must be several kilometres by the time we get up to altitudes like 30,000 ft., right?" His reply (with some non-essentials removed): "Aircraft ... are using a map optimised to the GPS system and this is the key point which seems to be passing you by." What's behind your questions; what are you trying to get at? If you posted that, you might get more suitable answers. I hope that that is sufficiently answered above. I didn't want to burden this group with extensive background information and endless quotes from this slightly silly debate! Regards, David, England. |
In article 0o_ig.19660$8q.17433@dukeread08, "Mark Manes"
wrote: You need at least 3 satellites in view to get an accurate 3D position. 4 satellites unless you already know GPS time or know your altitude. -- Bob Noel Looking for a sig the lawyers will hate |
Mark,
You need at least 3 satellites in view to get an accurate 3D position. 4. You need to correct for receiver clock error. -- Thomas Borchert (EDDH) |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
ADF/VOR navigation question | John Bell | Simulators | 0 | December 23rd 03 04:30 PM |
