How to file XXX to XXX?
Old May 18th 04, 02:57 AM
Nicholas Kliewer
Default How to file XXX to XXX?
If I just want to do IFR approaches at my class D airport of origin,
how should I file? One FSS person suggested that I file McKinney (TKI)
direct to a 5 mile on a 360 radial from the airport (which has no VOR)
and then back to TKI -- putting "multiple approaches" in the comments
section. Any other thoughts?
Old May 18th 04, 03:06 AM
Bill Gamelson
Unless they've changed the rules recently, you don't have to file if you
plan on staying with the controller of your origin airport. You just get on
clearance delivery if you have one and tell them you want to do approaches
and they will give you a squawk. You then go from there. I think you could
file if you want to but it would only be to let the controller know what
approach you plan on doing if you lose comms.
Old May 18th 04, 03:20 AM
Dan Luke
(which has no VOR) and then back to TKI -- putting
"multiple approaches" in the comments section.
Well, that's one way to do it. If there's no VOR or NDB within a few
miles, look on the low altitude chart and pick any nearby intersection
to put in the flightplan. You never really have to go there, it's just
so you'll have a route to fly in case you lose comm. Do put "multiple
At my class D airport the tower controller will ask which approaches I
want and pass them on to the TRACON controller, who will sometimes
actually remember them.
Dan
C172RG at BFM
Old May 18th 04, 03:25 AM
Steven P. McNicoll
"Nicholas Kliewer" wrote in message
origin, how should I file? One FSS person suggested that I
file McKinney (TKI) direct to a 5 mile on a 360 radial from
the airport (which has no VOR) and then back to TKI --
putting "multiple approaches" in the comments section. Any
other thoughts?
That'll work. The flight data processing computer will accept a direction
and distance from any stored fix.
Old May 18th 04, 03:26 AM
Andrew Sarangan
Nicholas Kliewer wrote in
Just file TKI to TKI and add multiple approaches in the comments box. Your
clearance will be something like "cleared to TKI, climb and maintain ...."
Old May 18th 04, 03:32 AM
Paul Crawford
"Andrew Sarangan" wrote in message
. 158...
Actually, you have to file to some point (VOR, NDB, intersection, etc.) away
from the airport and back, otherwise their computers won't accept the
flightplan as there is no actual "route". (I've tried this before and had
to file to a VOR and back...and once airborne I didn't neccessarily have to
go to the VOR).
Paul Crawford
Old May 18th 04, 03:41 AM
Steven P. McNicoll
. 158...
box. Your clearance will be something like "cleared to TKI, climb
and maintain ...."
That'll work over the phone to FSS, but the computer will reject it. The
error response is "zero distance" or something like that.
Old May 18th 04, 11:06 AM
Ron Rosenfeld
On Tue, 18 May 2004 02:41:06 GMT, "Steven P. McNicoll"
That's interesting. I've only filed without a fix via phone, so it must
have gotten "fixed" by the person entering the flight plan into the
computer.
Old May 18th 04, 02:55 PM
Andrew Sarangan
"Steven P. McNicoll" wrote in
hlink.net:
. 158...
and maintain ...."
The
I just tried this on DUATs with the route block empty and it accepted the
flight plan. However, it appears to have automatically inserted the
lat/lon co-ordinates of the airport in the route block. The route is
still zero distance.
Old May 18th 04, 11:23 PM
Steven P. McNicoll
. 158...
accepted the flight plan. However, it appears to have
automatically inserted the lat/lon co-ordinates of the airport
in the route block. The route is still zero distance.
It's probably not actually zero. Lat/lon coordinates are entered in flight
plans only to the nearest minute, fixes stored in the computer are entered
at a higher accuracy. Using the Route Readout function of ARTCC radar data
processing, which draws out the route on the scope, you can see the little
wiggle caused by a route like ..DDMM/DDMM..VOR.. , where DDMM/DDMM
represents the coordinates of the VOR.
Lycoming CAD file wanted Dave Driscoll Home Built 1 July 1st 04 01:30 AM
Ron Wantaj?? XL file Jerry Wass Home Built 9 March 3rd 04 03:22 AM
how I map my flights Snowbird Instrument Flight Rules 10 November 30th 03 11:26 PM
Don Brown and lat-long Bob Gardner Instrument Flight Rules 30 September 29th 03 03:24 AM
Reflections on first trip to Canada from US Mike & Janet Larke Instrument Flight Rules 1 August 9th 03 12:57 AM
