few pre-checkride questions
Old May 19th 04, 01:01 PM
Baron Man
Default few pre-checkride questions
1. what's a VDP and how does one compute it.
2. how many phases of an approach (IAP) and how do you tell each from the
other
3. what's a GRID MORA
4. what's a THINGS
5. what's the min ATC separation under IFR
6. drift-down?
Old May 19th 04, 01:19 PM
Dave Butler
Visual Descent Point. If there's one published for the approach (ie. on the
chart), don't descend visually below the MDA until you pass that point. If
there's none published, you can compute one for yourself as a convenience. How
to compute it is a matter of personal preference. You probably want to compute a
VDP that will give you about a 3 degree descent.
other
Initial, intermediate, final, and maybe missed(?). Are those considered
"phases"? Dunno.
Minimum Off-Route Altitude. Don't know about the "GRID". Probably a reference to
the lat-lon grid on your enroute chart. There's a MORA for each quadrangle.
4. what's a THINGS
Don't know.
Good question. I should know this, but I don't.
6. drift-down?
What a feather does. :-)
Dave
Remove SHIRT to reply directly.
Old May 19th 04, 08:32 PM
Teacherjh
4. what's a THINGS
Probably the name of an intersection. They are five letters long, and are
supposed to be pronouncable. An intersection is (usually) defined by two VOR
radials, or a VOR radial and a DME (distance) from that VOR. Intersections are
used as waypoints - upon reaching such a waypoint, you can do something (like
descend) as charted in the approach procedure.
Jose
Old May 19th 04, 11:17 PM
Teacherjh
There is a fix named THING, but not THINGS. Could it be some kind of
acronym, like GUMPS?
http://www.acronymfinder.com didn't have it as an acronym. Maybe it's a fix
named THNGS? I'd have to see what you are looking at in context to say more
(and be coherent).
Jose
Old May 20th 04, 12:45 AM
John R. Copeland
"Andrew Sarangan" wrote in message =
. 158...
There is a fix named THING, but not THINGS. Could it be some kind of=20
Hey, they've moved THING!
It used to be a radar fix near Worthington, OH, on the NDB 27L approach
to KOSU, and Columbus approach would normally call it out for us.
It disappeared from there years ago, and I didn't know until now
that it's been redesignated elsewhere.
Thanks, Andrew. It's like finding a lost old friend :-)
---JRC---
Old May 23rd 04, 06:20 PM
Casey Webster
"John R. Copeland" wrote in message ...
---JRC---
its a fix east of dallas now, on the dodge 3 arrival
Old May 20th 04, 11:15 PM
AirVespa
"Dave Butler" wrote in message
How
compute a
other
"phases"? Dunno.
First is "arrival" then those 4.
reference to
quadrangle.
The GRID MORA is the MORA defined for a square/sector marked in the chart.
In the Jeppesen Low Altitude Charts is a green number marqued in the center
of the square/sector. It provides 1000ft minimum obstacle clearance.
4. what's a THINGS
Don't know.
Depends on the context. Vertical, time or for radar vectoring?
6. drift-down?
nice! :-))
Dave
Old May 19th 04, 02:02 PM
Andrew Sarangan
"Baron Man" wrote in news:E0Iqc.130638$WA4.21924
@twister.nyc.rr.com:
This is in the AIM Chapter 5. The missed approach point of most
nonprecision approaches are at or past the runway location, making it
impossible to descend and land if you sight the runway at the missed
approach point. For this reason, a visual descent point (VDP) is sometimes
designated using a normal desent angle (typically 3 deg). It is intended to
provides terrain clearance below the MDA. It also means that if you don't
see the runway by the time you reach the VDP, you should start getting
ready for the missed approach procedure.
other
Initial Approach Segment, Intermediate Approach Segment, Final Approach
Segment and Missed Approach Segment. This is just a guess.
Don't know, but I suspect you are referring to Off Route Obstacle Clearance
Altitude (OROCA), which are the large bold numbers in each lat/lon
quadrant. It gives you 1000' obstruction clearance.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
IFR Checkride Checklist BTIZ Instrument Flight Rules 0 April 18th 04 12:06 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
