KRMN ILS 33- Interesting Approach
Old May 21st 04, 12:00 AM
Brad Z
Default KRMN ILS 33- Interesting Approach
http://www.naco.faa.gov/d-tpp/0405/09743IL33.PDF
I haven't come across an approach with two separate missed approach
procedures before. Is this even remotely common?
I think I'll add this to my instrument students' training regiment due to
some additional interesting features- teardrop course reversal, intersection
identification using ndb bearings (not using DME), and a lot of stuff to
brief. Some of the approaches down here in central VA are pretty boring.
Old May 21st 04, 12:44 AM
There are lots of IAPs with alternate, non-radar missed approach procedures.
But, the alternate procedure is normally provided only to the controlling ATC
facility. You've come across one of the first, if not the first, IAPs to
include the text of the alternate missed approach procedure on the chart. There
is some resistance to charting the alternate, even just textually, so this
concept may or may not take hold.
Old May 21st 04, 04:41 AM
J Haggerty
FAA has been adding alternate missed approach procedures to ILS
approaches to allow the ILS procedure to still be flyable even when the
VOR or VORTAC used in the procedure is INOP. They don't normally publish
this on the procedure though. I like it though, because then a NOTAM
doesn't need to be sent listing the alternate missed approach procedure
when BRV is INOP.
If there are a lot of military TACAN equipped aircraft that use this
particular procedure, then having the other missed approach procedure
published is required, since TACAN aircraft cannot hold directly over a
VORTAC or TACAN (unless they also have a VOR). In that case, it would
normally be published as shown on this procedure at Chippewa MI;
http://www.naco.faa.gov/d-tpp/0405/00810I16.PDF
Old May 21st 04, 02:16 PM
Roy Smith
Why not?
Old May 21st 04, 04:23 PM
Why not?
He's right in the case of a TACAN, wrong in the case of a VORTAC.
Old May 21st 04, 04:35 PM
Steven P. McNicoll
wrote in message ...
Why not?
Why? What difference does it make to a TACAN-only aircraft if the navaid is
a TACAN or a VORTAC?
Old May 21st 04, 04:52 PM
Why not?
I misread it; I thought it was a VOR aircraft.
Old May 21st 04, 10:51 PM
J Haggerty
Has something to do with the cone of ambiguity, or no-course signal
zone. It gets wider the higher the TACAN aircraft is. There's a chart in
the holding pattern manual that shows the distance vs. altitude, and a
DME fix can't even be used if it's within the specified distance,
because the TACAN-only aircraft won't ever receive it while he's in that
cone.
JPH
Why not?
Old May 21st 04, 11:53 PM
Max T, CFI
The text "DME or ADF required" is a lot smaller than I'm used to seeing it
and in a different place..
I had just glanced at the chart wondering how one would identify RMN
until I found the text. Great chart--thanks for posting it.
Max T, CFI
Brad Z wrote in message news:NT9rc.85411$536.14236711@attbi_s03...
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 05:19 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
Why an NDB approach with a miss to an intersection? Ben Jackson Instrument Flight Rules 10 March 25th 04 04:53 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 06:22 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
