RST headset-Val tranceiver compatibility
Old June 28th 06, 03:40 PM posted to rec.aviation.homebuilt
Default RST headset-Val tranceiver compatibility
I have not been able to use my RST kit headsets with my Val radio.
Transmission is so low as to be unreadable, reception is not a problem.
I've used the headsets with a Micro Air transceiver, a Collins and a
Icom handheld and the headsets work fine with these radios.
At present I am using a loaned ASA Air Classics HS1 headset with the
Val and am transmitting loud and clear, the Val also transmitted fine using
a loaned David Clark H40 headset.
Has anyone had any experience, good or bad, with this radio-headset
combo? Any ideas?
Old June 28th 06, 05:15 PM posted to rec.aviation.homebuilt
"Stew Hicks" wrote in message
news:jxwog.105250$IK3.30843@pd7tw1no...
a Icom handheld and the headsets work fine with these radios.
the Val and am transmitting loud and clear, the Val also transmitted fine
using a loaned David Clark H40 headset.
combo? Any ideas?
Somehow I bet this one is for Jim. Paging Jim Weir grin
Old June 28th 06, 07:01 PM posted to rec.aviation.homebuilt
I have had the oppisite problem. If I do not speak softly the Val is
overmodulated and garbled.
Lyn
Old June 29th 06, 02:50 PM posted to rec.aviation.homebuilt
Lyn
You are using RST headsets??
Old June 29th 06, 06:55 PM posted to rec.aviation.homebuilt
Yes, they may be an earlier version, have had them about 14 years.
Lyn
Old July 22nd 06, 03:00 PM posted to rec.aviation.homebuilt
Stew Hicks
Default RST headset-Val tranceiver compatibility for Jim Weir
combo? Any ideas?
Headset Noise Jonathan Goodish Owning 31 April 19th 06 01:18 PM
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 07:54 AM
Panther C.A.T. headset. Ross Taylor Products 0 October 22nd 04 11:59 PM
Bose makes good on my wife's headset. Kyler Laird General Aviation 3 March 10th 04 02:08 PM
Bose makes good on my wife's headset. Kyler Laird Piloting 3 March 10th 04 02:08 PM
