Stick grips
Old July 18th 03, 10:48 PM
John Nicholson
Default Stick grips
Hi
I am building a Lancair 360 and have reached that point in construction
where I need to take a decision on the best stick grips. I have two
questions on which I'd welcome your views?
(1) What is the best configuration? That is, what should and shouldn't be
on the grip?
(2) Any thoughts on which is the best commercially available grip that meets
the criteria for (1) above?
Thanks
John
Old July 18th 03, 11:56 PM
B2431
on the grip?
I do believe your hand should be on the grip.
Dan, U. S. Air Force, retired
Old July 20th 03, 05:30 AM
Scott VanderVeen
I plan on making the grip ambidextrous as it would be a bit more
convenient, although less comfortable. There are a number of "Game"
joy sticks that would be ideal for the right hand, but they are very
uncomfortable when used with the left.
The gaming industry got it backwards there...although a right hand one
for the right seat and left for the left seat would be the way to go.
Like these? I bought a pair (left and right), though I am planning to use
them as a pattern to duplicate them in wood. They are cheap.
http://www.arrow4graphics.com/Vision...%201/controls1.
htm
Scott V
Old July 21st 03, 11:22 AM
Andre
At night when I get home I sit in my Sonerai and make engine noises
ocasionally alternated by machine gun fire noises when I press the PTT
button. I think it would be really cool if I could find a device that will
make the machine gun fire noises while I'm doing a beat up of the club
house! I'd like the activation button for that on my stick! :-)
Andre
"Roger Halstead" wrote in message
be
on the grip?
That's a good start...:-))
"For me", I want the radio PTT, trim, and autopilot disconnect. There
are maybe some I've missed, but those three are my primary choices.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Old July 21st 03, 04:48 PM
Big John
Andre
Don't they (or didn't they) make some 'guns' that use propane to make
the gun noise? Seem to recall that method of playing WWI Ace G
Talk to Confedrate Air Force (they changed their name I think) on what
they use on their 'Zero's in their Pearl Harbor airshow.
Went to Google and searched "simulated aircraft machine gun". On that
site I found at least one propane/Oxy firing machine gun
(http://members.tripod.com/ReplicaMDL/bigguns.htm. There may be
others?
The one I found (50 Cal) was pretty expensive but there may be other
cheaper ones on Internet if you spend some time looking.
Rots uve luck, boyson. (Well known Japanese expression G)
Big John
Andre
be
on the grip?
Old July 22nd 03, 04:27 PM
Andre
Hey John,
Yes the expensive part obviously makes it slightly less attractive for an
enthusiastic home builder on limited budget... so I'm thinking... what would
any decent home builder do?
The answer is scrounge of course, is it not?
So here's my first my first idea for a Home Made Machine Gun Fire Sound
Device Ver. 1.0.
Take one second hand automotive radio/cassette player and obtain an
amplifying unit to match. Tape some machine gun fire onto a casette, (can
use Pearl Harbor, the movie as a good source...) and install the whole
contraption into one standard home built aircraft with a button on the
joystick grip (to make this post relevant to the thread) and Bob's your
uncle...
What do you think?
"Big John" wrote in message
Andre
others?
Big John
will
Andre
shouldn't
be
on the grip?
Old July 19th 03, 02:02 AM
Ernest Christley
John Nicholson wrote:
Hi
on the grip?
Thanks
John
And to piggyback on John for just a second...
I see these grips advertised for upwards of $100. What do you get for $100?
My stick is a piece of 4130 tube. Well, my airplane's stick is a piece
of tube. Mine is made of a somewhat softer material. Be that as it
may, I don't see where these guys get the idea that I'd pay $100 for a
couple switches and a piece of plastic. My plan has been to make a mold
of my grip with some playdough and then duplicate it in a piece of
hardwood. Another option is to go with a logiteck joystick grip, but I
have a lot of trouble finding one that fits my hand.
----Because I can----
http://www.ernest.isa-geek.org/
Old July 19th 03, 05:38 AM
Jerry Wass
I put a rubber bicycle handlebar grip(kinda hard to find these days,everything's
plastic) and squeezed a push to talk switch into the existing hole in the grip.
Hi
on the grip?
Thanks
John
Old July 19th 03, 11:32 AM
Del Rawlins
On 18 Jul 2003 08:38 PM, Jerry Wass posted the following:
everything's plastic) and squeezed a push to talk switch into the
Motorcycles and ATVs use rubber grips; I believe most of them fit a 7/8"
tube, which just happens to be the size used for the Bearhawk's control
stick. If you buy a set of grips meant for a machine with twist
throttle, one of the grips will have a slightly larger inside diameter
to fit over the throttle tube.
Coincidentally, I am hoping to finish welding on the stick assembly
tomorrow. 8^) The only switches in my control sticks will be for push
to transmit.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
First Two Aero Lessons This Weekend (Long) David B. Cole Aerobatics 12 December 3rd 04 01:18 AM
inverted spin recovery explanation Alan Wood Aerobatics 18 August 19th 04 03:32 PM
Stick and Rudder's 'Safety plane' Barnyard BOb -- Home Built 31 July 12th 03 04:13 PM
