Capstone
Old May 27th 04, 08:06 AM
Scott Moore
Default Capstone
http://www.avweb.com/eletter/archive...ll.html#187369
How much longer are we supposed to be happy for a bunch of frozen
piper pilots on government technological welfare ?
If ADS-B saves lives, deploy it. Or shut the hell up. Just my
2 cents.
Old May 27th 04, 08:37 AM
Scott Moore
2 cents.
More stupid stuff that ****es me off:
http://www.faa.gov/asd/ads-b/06-07-0...B-Overview.pdf
The "final link decision" is "in", in a document that has the ability to
"copy" (cut and paste) disabled (thanks):
o Two ADS-B technologies are selected for use in the NAS: 109ES and UAT
o Aircraft that fly in high altitude airspace would equip with 1090ES
o General Aviation aircraft that are not capable of high altitude operations
would equip with UAT.
o Interoperability between the links will be provided within coverage of the
ground ADS-B infrastructure using the multilink gateway service provided via the
TIS-B uplink (ground to air).
Translation: BIG AIRCRAFT AND SMALL WON'T BE ABLE TO TALK TO EACH OTHER. Instead,
the data will all go through the FAA radar site.
Gee, I thought the whole idea of ADS-B was to get a system that didn't need to
depend on radar !
Further, this moronic doublespeak ignores that UAT is installed, let me think,
oh yea, NOWHERE OUTSIDE OF GOVERNMENT FUNDED TESTS IN GODDAM FROZEN NOPLACE.
Whereas a lot of us foolishly bought mode-s to get TIS DATA, which is how, by the
by, the "gateway" service the radar terminal provides is supposed to work.
This means: you bought mode-s to get TIS ? Yea, TIS is a good idea, but mode-s
ain't it. You messed up ! That'll teach you to try and predict what the FAA
will do !
Finally, yes you MAY use your mode-s for ADS-B - if you can prove you can fly
high in that thar airplane. Or perhaps private planes are supposed to carry
both, and switch over at a certain altitude ??!!!
Heres what really happened:
FAA: we want you all to use UAT. We spent big bucks funding it.
AIRLINES: No way. We already believed your last insipid line and bought
mode-s for everyone. We are staying mode-s.
FAA: well, we need SOME little defenseless aviation group to jam it to,
lets see.....
Typical beaurocrat nonsense. Try and give everyone what they want, and end up
screwing everyone.
Hey airlines, you didn't make out so good on the deal, either. You have
TWAS in spades to detect other large peices of metal, and even small
peices of metal. Say, does it make sense to make sure the little peices
of metal can't see you, even if you can see them ?
Also, yes, you big airplanes come and go with radar. How sure are you
that you will never encounter a light airplane outside the radar sphere ?
Radars go on the blink, as well, and they get shadowed by other airplanes
and mountains.
Old May 27th 04, 12:39 PM
Dave S
So what do you recommend? whats the solution?
Dave
2 cents.
operations
via the
Instead,
need to
depend on radar !
think,
NOPLACE.
how, by the
mode-s
will do !
can fly
lets see.....
end up
screwing everyone.
and mountains.
Old May 27th 04, 09:36 PM
Scott Moore
Dave
I cleaned up my language a bit, then sent my tirade off to Phil Boyer :-)
He gave me a short note, then promised me an "in depth" note from their
staff expert on the subject. I believe the gist of it is that the AOPA
has fought tooth and nail to keep the mode-s requirement out of light
airplanes due to individual airplane ids and their potential for for
fees and misuse (imagine the "stop the noise" zelots having the ability
to get an N number automatically).
I don't mind adding a UAT, if that is what it takes. I mind the apparent,
from reading the FAA material, dogma that light airplanes shall have
UAT and big airplanes shall have mode-s, and the FAA shall act as the
bridge between the two (ha !).
All kinds of "what to do" things occur to me, but each seems to be
centered around a group with an interest who does not want to move.
o Allow "anonymous mode-s", and so remove the light pilot/AOPA objection
to mode-s ? This has been proposed many times in many places. Apparently
the FAA would rather die than this, but why are they (apparently) going
to allow UAT to so do, but not mode-s ?
o Require UAT on airlines, so that everyone speaks the same language, and
UAT eventually replaces mode-s as a more advanced method ? I could hardly
blame the airlines for fighting that one. The FAA just got through requiring
them to buy into mode-s. It would put the airlines into the position
of buying the "black box of the month" as the FAA changes with the wind.
o Require light airplanes to have both ? Time for us to scream, I guess, but
that is where I am headed anyways, since I was stupid enough to buy mode-s
(for TIS).
In any case, it appears that the FAA, the AOPA and the airlines have all
already come to the solution:
o Airlines have mode-s, we have UAT, and the friendly FAA will translate
between the two, but only under radar control (neatly severing the non-radar
reliant feature off ADS-B). The theory is, I guess, that airlines allways
travel under radar so it won't matter in any cass.
o Light airplanes unlucky enough to have high altitude capability would
need both mode-s and UAT. This would also apply to a huge number of
jets and even heavy aircraft, since there are a lot of light jets and
passenger aircraft servicing smaller, non-radar fields.
In short, it will be a mess, and the FAA has a plan, the beauty and
simplicity of which clearly escapes me.
"Say Tex, wasn't that a heavy that nearly ran us down ?"
"why yes, we need to turn our mode-s on ! And I think the UAT off ?
or is it mode-UAT ?"
"which one of them switches is that ?"
"never mind, they are gone anyways..."
Old May 27th 04, 10:44 PM
Bob Noel
In article yjstc.9901$Ly.7087@attbi_s01, Scott Moore
Mode-S doesn't have a provision for "anonymous." And changing
the specs for Mode-S would be, ahem, challenging. It's not
actually an FAA issue.
requiring
bingo. The airlines had to install expensive tcas systems and
have to have Mode-S for that and other systems (for flight in Europe
and other areas). The airlines will fight tooth-n-nail requirements
to install duplicative systems.
not much of a solution...
Bob Noel
Old May 27th 04, 10:55 PM
Scott Moore
Well, I do understand the issue, but not why anonymous is so hard. The
shop programs the N number, right ? What is to prevent them from declaring
a "universal" N number (the equivalent of 1200) and just programming all
"protestants" with that on request ?
requiring
Old May 28th 04, 01:44 PM
Richard Kaplan
"Scott Moore" wrote in message
news:yjstc.9901$Ly.7087@attbi_s01...
This is already possible at least for IFR flights if you sign up for
www.fboweb.com and do an "Area Track" -- just enter a zip code and desired
radius and you will see all the IFR flights and their altitudes,
destinations, and registered owners.
Richard Kaplan, CFII
www.flyimc.com
Old May 28th 04, 01:51 PM
Richard Kaplan
Do you know the definition of high-altitude capability?
A turbocharged piston airplane may very well be capable of flying above
FL300 although it is rare for piston airplanes to actually do so.
www.flyimc.com
Old May 29th 04, 02:56 AM
Gerry Caron
True. Cost is also an issue.
It's not FAA dogma. It's a reasonable compromise to gain concensus from two
diverse groups, each of which has its own needs within the airspace. The
FAA actually hasn't mandated either one for any specific group. The
statement that GA will have UAT and airliners have 1090ES, is merely a
generalization of expected market response. There is nothing that requires
anyone to select one over the other. Nor is there anything that prevents
you from equipping with both.
Mode-Select (Mode-S) was designed twenty years ago for a very specific set
of needs. It does that very well. It is an addressed communication system.
Trying to make it do something for which it wasn't designed could compromise
the system or at best add a lot of expense and complexity.
UAT was created about 8 years ago specifically to support ADS-B, TIS-B, and
FIS-B. Note the "-B" in all the systems -- that stands for broadcast. UAT
is a non-addressed broadcast system. Basically it's a half-duplex radio
modem. When you transmit, you have no ability to determine who is
receiving. Likewise, in receive, you'll receive anybody within range.
requiring
Airlines have Mode-S because it's a required part of a TCAS system, which is
mandated. TCAS will not be going away. ADS-B may augment TCAS, but it
won't replace it. Adding ADS-B to the Mode-S system is the most
cost-efficient route if you already have the Mode-S/TCAS equipment.
but
(for TIS).
As I said before, you're not required to have either one. And I wouldn't
say you are stupid for buying into Mode-S for TIS. TIS is a very good
service. While it is limited to areas of Mode-S radar coverage, it allows
you to see any aircraft the radar is capable of tracking. While ADS-B
doesn't need radar, if the other guy isn't equipped, he's invisible.
non-radar
Major point here. The ADS-B repeater/translator is NOT radar based. It is
a 1090MHz receiver and a UAT receiver to "collect" ADS-B broadcsts from
aircraft in the vicinity. The data is then broadcast out on both 1090 MHz
and UAT (this broadcast is called TIS-B -- this is not the TIS you currently
have.) These are relatively cheap (a couple orders of magnitude cheaper
than a radar) autonomous ground stations that can be stuck pretty much
anywhere, including places where there is no radar coverage. This is
exactly what they did in Alaska for Capstone.
No. You can pick one, or neither, or both. While you may need a basic
Mode-S transponder for some high altitude airspace (RVSM), that does not
mean you have to have a 1090ES ADS-B system.
A fine point here. Your GTX330 is a long way from a 1090ES ADS-B system.
It currently provides only elementary surveillance support. It would
require an upgrade to support full ADS-B broadcast. Once you did that, you
could provide ADS-B broadcasts, but you'd still have to get a 1090 MHz
receiver to be able to receive ADS-B or TIB-B over 1090. (Your TIS data
comes up from the ground radar on 1030 MHz using the Mode-S comm-b
protocol.) Adding that receiver will not be cheap. The receiver and
transponder upgrade will likely cost as much or more than a UAT.
Gerry
Old May 29th 04, 07:16 AM
Scott Moore
mode-s ("squitter") is also designed with these properties. The proposal to
add ads-b to mode-s originally had the mode-s transmitter start transmitting
asyncronously if the unit was not swept within a given period of time. Ie.,
lacking radar, the unit would switch to true ads-b mode.
I would say that at this state of the technology, that mode-s is going to be
the most cost effective for everyone. UAT is brand new, untried technology.
mode-s already has a lot of units and support. UAT is simply going to cost
more, for a while.
Having a defacto requirement that you need both mode-s and UAT on a light
airplane is certainly not going to help costs for light airplanes. And it
will be the defacto requirement once pilots find out they really should
have both to prevent being run over by a transport aircraft under all
conditions, including no radar and radar shadows.
Still means that you need a ground based translator to get from light airplanes
to transport aircraft. ADS-b's best feature was that it didn't need to depend
on ground stations. That ground station adds a new point of failure to the
system, as well as being a fickle one. I don't care how high tech digital
you get, that signal is not going to go through a mountain, whereas I have
never heard of a midair collision where the colliding aircraft went through
a mountain, ie., generally you have line of sight for an aircraft you are
colliding with.
When ADS-B is required on class A airspace, then high altitude light planes
are going to need it as well. Unless you can think of a class A requirement
that was excepted for light aircraft ?
Gerry
Good point (didn't know that), but it isn't going to change the fact that you
will need both systems. No, the airlines are not going to care, they simply
want uncontrolled airplanes out of their way no matter what. But as the
ramifications of having two "separate but equal" ADS-B systems work in,
its going to be understood that you better have both systems to be really
safe.
I disagree that it had to be this way. The FAA cannot even create one standard
for a brand new system ? No, what they did is throw a special interest party,
and give everyone what they wanted (even though they don't work together).
It stinks. Sorry, it just does.
"We like standards. In fact, we like them so much we think everyone should
have their own..."
